Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 23rd May 2008, 10:23   #856 (permalink)
ssjr0498's Avatar
Question
Originally Posted by viper View Post
As per Karthik the Vtec cannot function on the ECU in the car(white ECU)as the wire is not connected and the software does not support Vtec.
Viper
now this is even more confusing! Has he given you a different model of the ECU?
I know of several Vtec's having his ECU's (white in color) which work perfectly fine and the Vtec also engages!
Cheers,
Shrey
__________________
Did you just say, VTEC!! Oooo yeaaah!!
ssjr0498 is offline   Reply With Quote
Old 23rd May 2008, 20:41   #857 (permalink)
chetanhanda's Avatar
Originally Posted by sujaylahiri View Post
What I meant to say before is that by altering the Variable Valve timing (VTEC in case of Honda) to kick in at an earlier rpm and altering the valve overlap(s) sequence, the engines could be made to generate more lower end torque without sacrificing specific power output, which Honda seems to have done in the recent years.
I hope Im not going OT on this thread because we are still discussing B series engines and why they should be kept hi revving.
Person buying a si with a b16 or a teg with a b18 is not interested in low end torque at all.
Typical customer for a B series guy is someone who wants absolute hard revving engine.
Its like saying why doesn't Harley Davidson make 10,000 rpm hi revving 4 cylinder engines ?
Answer to that is - its meant for a different audience who want a lazy easy going cruiser, same with B series engines - anyone who wants low end torque should go for a different car, there are plenty out there.
Its absolutely funny that you are looking for low end torque in a Jap tuner engine and explain to us how Vtec should be programmed ?
Why dont you look somewhere else for lazier engines ?
If you are having problems on a freeway overtaking a truck with the vtec engaged at 7000 rpm you are driving the wrong car or not driving it right.
You should be driving a 4 litre 6 cylinder mustang...leave the Honda engines to those freaks who love hi revving engines.
Nothing more to say.
chetanhanda is offline   Reply With Quote
Old 24th May 2008, 00:45   #858 (permalink)
V-16's Avatar
Originally Posted by Ford Rocam View Post
Set your vtec at 7000 rpm & do a pull, then set your vtec at 3500 rpm & do a pull, you will get the answer.
plus you will get your best vtec shift point, where torque from low speed cam starts falling & high speed cam increasing both the graph(torque curve) will come to an interception point, thats where you set your Vtec.
Thats a good suggestion Jitu and worth trying.
__________________
SINGH IS KING!!!!
V-16 is offline   Reply With Quote
Old 24th May 2008, 03:01   #859 (permalink)
sujaylahiri's Avatar
Honda's VTEC is so much overrated that I don't even wanna talk about it any more.
Anyway as an example, take BMW's new 5L V10 with the VANOS (BMW's version of VTEC) system. The peak power output is 507 bhp and the redline is 8250 rpm. They achieve their peak torque of 520 Nm @ 6100 rpm, but the VANOS is programmed in such a way that you get about 450 Nm at 3500 rpm, and in the rev range of 3500-5500 rpm 80% of the torque is still available and keeps increasing till you hit 6100.
So what I meant to say is that the VTEC can be programmed at different engine speeds to achieve the optimum torque output without sacrificing higher end power to a certain extent, something which was being discussed in some of the previous posts.
Also keep in mind that having a close ratio gearbox is gonna make you run out of engine speed in the higher gears thereby affecting top speed as the engine might not have enough power (or revs) left to counter the drag forces at such speeds (as drag increases significantly with velocity) .
__________________
I'm Mr. Brightside.
sujaylahiri is offline   Reply With Quote
Old 24th May 2008, 04:57   #860 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Note from Mod : Lets not go too much into a debate of the worth of VTEC in vipers build thread. There are other threads which you can continue this discussion in. Thanks.
__________________
The memory of you will ride by our side forever.
Old 24th May 2008, 11:28   #861 (permalink)
Shan2nu's Avatar
@rehaan : Why not make a new thread from where the off topic posts started. Then we can discuss this without affecting the original topic.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Shan2nu is online now   Reply With Quote
Old 26th May 2008, 16:16   #862 (permalink)
viper's Avatar
Just got myself a HKS Type-0 Turbo Timer, Set of 3 Autometer Sports Comp series guages (Oil Temp, Boost/Vaccum & Water Temp) size 2 5/8th and my long overdue Red Exhaust wraps.
This was a kind of a birthday present to myself Now I need the time to go and get these installed.
Viper
__________________
NO ONE DARES COME CLOSE
viper is offline   Reply With Quote
Old 26th May 2008, 17:32   #863 (permalink)
V-16's Avatar
Viper
Wow. That looks delicious.
You did say Red wrap, cant see the colour from the pic you posted.
Could you post a pic from another angle, of the wrap so we can see the colour clearly?
I want one too Viperbhai!!
__________________
SINGH IS KING!!!!
Old 10th June 2008, 13:01   #864 (permalink)
viper's Avatar
Default Update
Hi Guys,
Its been a while since I updated this thread. Had installed the guages, Red Exhaust wraps & turbo timer a while back but somehow did not get the time to upload pics.
Had also sent the car for a long overdue paint touch up and polishing and have swapped back to my OE bonnet for the monsoons. Attaching below some pics of the same. Sorry for the bad quality as taken from my phone cam.
The car is currently running on the stock Cams with Vtec still not on.
Viper
__________________
Old 10th June 2008, 13:03   #865 (permalink)
Cyrus43's Avatar
Post deleted by the Team-BHP Support : Please do NOT SPAM the forum. One-liners that add absolutely no value to the thread are strictly prohibited on Team-BHP.
We advise you to visit our board rules section before proceeding any further.
__________________
SUPER DUPER.... :-)....(HOPEFULLY!!!)
Cyrus43 is offline   Reply With Quote Received Infraction
Old 10th June 2008, 14:56   #866 (permalink)
pawan's Avatar
any particular reason to switching back to the stock cam?.
__________________
EZEN for sale.
pawan is offline   Reply With Quote
Old 10th June 2008, 15:17   #867 (permalink)
V-16's Avatar
Meters look great. The car will look aawesome when its ready. Cant wait to take a spin.
__________________
SINGH IS KING!!!!
Old 10th June 2008, 21:53   #868 (permalink)
nitroxx's Avatar
Viper, I think your cars gonna end up being more rev happy, if the cams go aggressive, for a daily drive i wouldn't advise on changing the cam to any particular race spec.
I'm sure with the other cam you'll notice a roughness on idle.and thats one thing I know you cant stand.
__________________
"Aerodynamics is for those who cannot manufacture good engines"
- Enzo Ferrari
nitroxx is offline   Reply With Quote
Old 10th June 2008, 22:53   #869 (permalink)
viper's Avatar
Micky,
Will be reverting back to my Comp Cams dayafter. No fun driving on stock cams.
Viper
__________________
Old 11th June 2008, 17:13   #870 (permalink)
viper's Avatar
Hi Guys,
Here are some better pics of the car after the paint touch up, installation of gauges & relocation of air filter.
Viper
__________________
Thread Tools
Wanted Urgently- Engine harness for B16A2 viper Shifting gears 3 6th January 2008 20:56
Palio 1.6 Turbo Charged BUSA Modifications & Accessories 120 6th December 2007 16:38
Tuning turbo charged engines. drpullockaran Technical Stuff 8 7th May 2007 04:35
Turbo charged INDIA Vulken Auto Modifications & Accessories 24 19th May 2006 11:00
Turbo Charged City!! iomega Modifications & Accessories 13 17th March 2005 15:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404
