Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 14th June 2008, 18:49   #886 (permalink)
viper's Avatar
Originally Posted by cyneverdie View Post
Not sure whom you bought the springs from but i would love to here an "official" reason or explanation for this .
Hell yes your real lucky man , if it let go on a high speed corner it wouldn't be fun , need to google this out of curiosity . Were the springs under rated or something?
Are you replacing all of them ?
cheers man
They were bought directly from Krupesh Patel of Electra Automobiles. I shudder to think what would have happened had I been on expressway with family.
He is replacing only the broken spring. I will be getting the other spring checked before reinstalling both.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 14th June 2008, 19:18   #887 (permalink)
V-16's Avatar
Lucky Viper I will say. This is the first time I have seen or heard of such a problem on a non rally spec car.
Thank God it was not on the move when it snapped.
__________________
SINGH IS KING!!!!
V-16 is offline   Reply With Quote
Old 15th June 2008, 20:42   #888 (permalink)
Tool's Avatar
hey Viper baba,
Any word yet on why this happened ? Any explanation from them ?
This is really scary.
Just super happy you were not on the road and with family.
Thank god for that.
__________________
Why Drink And Drive When You Can Smoke And Fly ??.
Front Wheel Drive Is The Work Of Satan !!!
Tool is offline   Reply With Quote
Old 15th June 2008, 22:25   #889 (permalink)
hkanitkar's Avatar
Lucky you, viper ! Thank god it didn't happen when you were driving.
My doubt : What material are these springs made of ? I am sure its not usual Mild Steel.
In mild steel, this happens mostly in case of a manufacturing defect and sometimes, due to fatigue failure.
__________________
एक सात पाच पाच
hkanitkar is offline   Reply With Quote
Old 16th June 2008, 00:54   #890 (permalink)
Team-BHP Moderator
Mpower's Avatar
Actually it, happened on our mid-90s TATA Estate front.
Viper, since its a Macpherson strut, the damper is still connected from body to wheel even though the spring breaks. It will collapse and sit on the jounce bumper. Its not as disastrous as for example breaking a steering tie rod or ball joint at high speed.
Coil springs need a special steel alloy called 'spring steel' . Regular cheap grade MS will not have the kind of fatigue performance. What make is the spring. Chinese?
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 16th June 2008, 07:10   #891 (permalink)
iceman91's Avatar
as far as i know pedders is australian.. But you never know with the origin of manufacturing
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 16th June 2008, 07:15   #892 (permalink)
1self's Avatar
Exclamation
Hi Viper!
You ARE lucky! I am really glad you were not on the road! I second the above opinion! I wonder if they were of "Indian" origin? Unless your mechanics were having "fun" with the vehicle when you are not around?
__________________
I'm not into exotica & badges, just horsepower & handling!
1self is offline   Reply With Quote
Old 16th June 2008, 08:56   #893 (permalink)
Team-BHP Moderator
The most probable cause is that the spring was an "open toe " type,(ie did not finish with a closed coil at each end).
Chances are that the fracture was three-quarters of a turn from the open toe - the exact position of the stress concentration that occurs if a spring does not finish with a closed coil. Apparently all such springs are made with open ends these days - and they all fracture in the same place. Although it might seem as though an open toe gives a greater active length, hence a reduced working length, owing to the stress concentration caused by the open toe, the reverse is always the case.
__________________
I love the whoosh, but i miss the bellowing
Old 23rd June 2008, 11:18   #894 (permalink)
viper's Avatar
Default Update
Just got the replacement Pedders spring on Saturday evening. Will go and get it refitted today. Just hope that nothing goes wrong with them again.
Viper
__________________
Old 23rd June 2008, 12:08   #895 (permalink)
razor4077's Avatar
Am pretty shocked to see this. Never heard of a spring letting go like this. And I have additional cause for concern, since I use the same springs on my car!
razor4077 is online now   Reply With Quote
Old 23rd June 2008, 13:19   #896 (permalink)
iraghava's Avatar
Jiggy bhai - One suggestion, if you're not using the stock ECU, I suggest moving the RD ECU to that position. Reason being, last Sunday, water entered my car when she was standing in a heavy downpour & passing cars probably raised the water height to that of the door sill & the entire left side floor was wet to the point where you have your RD ECU kept right now.
Surely, you don't wanna take that risk.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 23rd June 2008, 16:24   #897 (permalink)
crazydiablo's Avatar
I dont think jiggy will leave it on the floor. It will be either behind the glove box or in it.
crazydiablo is offline   Reply With Quote
Old 23rd June 2008, 16:48   #898 (permalink)
shazikon's Avatar
One more reason to stick to reputed after market parts!
__________________
Cheers,
shaz
shazikon is offline   Reply With Quote
Old 23rd June 2008, 17:14   #899 (permalink)
razor4077's Avatar
Well, Pedders in general have a pretty good reputation.
Old 23rd June 2008, 19:06   #900 (permalink)
The Wolf's Avatar
Touching the VTEC activation speculation, Viper I think the ecu Karthik initially gave you did not have a VTEC controller, meaning which, you cannot change your VTEC activation point, thats it. It doesnt mean that the VTEC isnt kicking at all!!! Your VTEC point will be your original VTEC point set by the company, where it wouldve functioned normally.
You "cant" clock on dyno what you have on the primary lobes alone!!!
Hope this helps...
__________________
I cried coz I had no turbo, till I met a man who had no VTEC!!!
The Wolf is offline   Reply With Quote
Thread Tools
Wanted Urgently- Engine harness for B16A2 viper Shifting gears 3 6th January 2008 20:56
Palio 1.6 Turbo Charged BUSA Modifications & Accessories 120 6th December 2007 16:38
Tuning turbo charged engines. drpullockaran Technical Stuff 8 7th May 2007 04:35
Turbo charged INDIA Vulken Auto Modifications & Accessories 24 19th May 2006 11:00
Turbo Charged City!! iomega Modifications & Accessories 13 17th March 2005 15:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
