Old 20th May 2011, 12:11   #421
Jaizcrzy's Avatar
Default Re: The Maruti 800 Mod Thread
Originally Posted by mycarhasablower View Post
the single biggest deciding factor when it comes to fuel economy is the driving style. this is assuming that the car is in perfect shape. So get it serviced(excluding the oil change) my 1988 maruti gives 18+kmpl and sometimes upto 23 in delhis traffic, without a/c ofcourse.Hell my esteem too has averaged abt 18kmpl in the city, without a/c again. You should get 14-15 without the a/c assuming your wife isnt the best of driver provided your car is tuned well.
@ mycarhasablower : I am driving the car for the moment. As, my wife has to complete her driving lessons before getting into this one.
I travel 40km every day office to home and in weekend the odo clocks 50-60km. Trafiic is not B2B adn it runs mostly on AC.
My dad has a '99 model M800, it gives us 14 in City with AC and gave us 17 with AC on highway(Hyd to Vizag).
Not sure sure why is this one give so low FE. as advised i will get it tuned once. Is there any thing else that has to be checked? So that i can walk to the service station with all checks to be done at one go.
Thanks in advance
Jaizcrzy is offline   Reply With Quote
Old 20th May 2011, 12:33   #422
silversteed's Avatar
Thanked: 1,667 Times
I would suggest checking the fuel lines, clutch assembly and spark plugs - thoroughly.
10-11kmpl mileage is pretty low for an M800... My 2002 model gives 18kmpl on LPG, on highways, with AC on.
silversteed is offline   Reply With Quote
Old 20th May 2011, 14:01   #423
Jaizcrzy's Avatar
@ Silversteed: Thanks, sure will get them checked and post an update soon.
Old 20th May 2011, 21:00   #424
josejoseph's Avatar
Thanked: 319 Times
Originally Posted by josejoseph View Post
There is always some white residue near the coolant tank cap.
Thanks guys. I'll do an engine compression test and find out the reason why the coolant level goes down so often.
Ideally if there is any leakage, would it not be visible on the ground where car is parked?
I gave my car for service last week. Changed engine oil, gear oil, timing belt, spark plugs, oil filter, air filter, etc.
The car feels much better now.
I had asked for an engine compression test and the M.A.S.S. confirmed that there is nothing unusual with engine compression.
There was some problem with the connection of radiator fan which resulted in improper working. This could be the reason for over heating and coolant leaking. The is issue is fixed for now, I haven't had a chance to check this.
The mileage was very poor before service, but now I feel it's improved. I'm yet to confirm that.
Total bill came to 7.3K .
Originally Posted by chanakya79 View Post
I have a 2009 Feb M800, I have got suncontrol film done on all the window glasses except the front windshield. However the heat inside the car is unbearable while driving without the a/c. The heat is so miserable (im from Hyderabad) that I get drenched in sweat thoroughly. However with the a/c the story is only slightly better! But my question is should the car get so hot? is it because the body of 800 is thin? No modifications of any sort have been done and the car is in perfect condition with 10,250 KM. I wonder what i should be doing to make the car a bit cooler. Obviously the sun control film which doesnt have any brand name isnt working. Please any advice and suggestions are welcome.
Drive safe.
chanakya79, I'd suggest you to take you car to service center and ask them to clean the AC ducts. I did the same to my 10 year old car 2 months back and the AC is much better now. Cost me 650 bucks for AC cleaning. Even if that doesn't satisfy you, go for a better sun film brand including the front windshield. This would set your poorer by around 8K, but it's really worth.
Thanks in advance
Jaizcrzy, give your car for servicing. You may need to filters, oils, etc. This would definitely solve the problem. Also get the wheels balanced and aligned. Check the brakes as well.
Keep revving.
Jose.
josejoseph is offline   (1) Thanks Reply With Quote
Old 30th May 2011, 14:59   #425
Jaizcrzy's Avatar
@josejoseph : Thank you for the inputs. am back today after a 10 days vacation. Will check the above and update
Old 7th June 2011, 14:13   #426
josejoseph's Avatar
Thanked: 319 Times
Guys, due to poor illumination of headlights in my M800, I'm planning to go for aux. lamps in my car. What I have in mind is something like this:
Fix the lights on the bumper. I've narrowed down on Hella Comet 450. But the problem is that when I took the car to a fabrication shop for welding clamps, the workshop guys were unwilling to do the job as they did not find any suitable place to weld the clamps. Can any one guide me on mounting the clamps on the body/chassis to fix the lights?
Is it possible to directly fix the lamps onto the plastic bumpers?
Thanks in advance.
Jose.
josejoseph is offline   Reply With Quote
Old 7th June 2011, 14:23   #427
longhorn's Avatar
Thanked: 337 Times
@ Jose the lamps cannot be directly fitted onto the bumper. There should be a metal base that can be bolted on for the lamps. You need to have another metal rod( something like a ruler) placed under the bumper so that the lamps can be bolted onto that metal rod. I suggest you look at the space on the bumper below the front indicators for the lamps. That will not restict the airflow to the radiator.
longhorn is offline   (1) Thanks Reply With Quote
Old 7th June 2011, 14:37   #428
josejoseph's Avatar
Thanked: 319 Times
longhorn, I do not want to place the lights below the indicator/number plate level as I fear water logging or damaging of the units.
Re. the metal base you have mentioned, how is it connected to the car chassis/body? Any pictures or diagrams on the install?
Please help.
- Jose.
Old 7th June 2011, 14:45   #429
longhorn's Avatar
Thanked: 337 Times
The metal base need not be connected/welded to the car's body. The base is there only to enable the lamps to be bolted onto them and hold them in place. The bumper will support the metal base when the lamps are bolted onto it. The metal base should have two holes to align the lamps and pass the bolt(that will hold the lamp) through them. It can be placed on top of the bumper too. I mentioned below the bumper for aesthetic purposes alone. Unfortunately I don't have any pictures. Just make sure that the height of the additional lamps is less than that of your headlights else you will be inviting trouble.
Old 7th June 2011, 15:32   #430
josejoseph's Avatar
Thanked: 319 Times
Thanks once again longhorn. I'll go to a metal fabrication shop and get this done.
I believe it's illegal to put aux. lamps above the HL level; there is no problem to have the lights in the same level as HL.
Thanks,
Jose.
Old 27th June 2011, 08:03   #431
glomus123's Avatar
Thanked: 47 Times
Smile Re: The Maruti 800 Mod Thread
Sorry for bumping an old thread. We have one MPFI M800, which has some issues with ECU, the fuel pump is not working. Seems we have to replace the ECU. My father being an old school person, we are thinking of removing the ECU and fit a carburettor (convert fully to the conventional type). Is this practical and is there any risk?
Thanks in advance for any kind of input!!
glomus123 is offline   Reply With Quote
Old 27th June 2011, 09:38   #432
swiftboost's Avatar
Thanked: 43 Times
@ glomus123 - Yes, you can convert your MPFI M800 to run a carb setup. Having said that, I think it would be easier to fix your present issue rather than going for a carb swap.
Its not very often that the ECU goes bad. Even is it does, it may be the smaller things like the resistors/capacitors etc and not the main processor/s in most cases.
swiftboost is offline   (1) Thanks Reply With Quote
Old 27th June 2011, 09:59   #433
glomus123's Avatar
Thanked: 47 Times
Thanks a lot for the info. If it cant be rectified with any minor work, I am going for changing to Carb.
With thanks and regards
Old 27th June 2011, 10:24   #434
swiftboost's Avatar
Thanked: 43 Times
@ glomus123 - MASS may not be able to fix the issue if its ECU is at fault (other than replacing the ECU). Im sure someone here on the forum can suggest you a place to repair ECUs.
I have been able to salvage quite a few ECUs in the past except for cases when the ECU motherboard/ processor/ other vital components failed.
Getting to run the M800 on carb shouldnt be difficult once you have all the hardware in place.
Old 27th June 2011, 10:29   #435
glomus123's Avatar
Thanked: 47 Times
Thanks again!! Unfortunately that is a problem again. MASS is not able to fix the issue, and my dad couldnt find a place to do it. Some info about any shopw who can rectify this issue in and around Kerala / Coimbatore will be much much helpful.
Thanks in advance!
Maruti 800 : Tyre & wheel upgrade thread Ram Tyre & Alloy wheel Section 247 24th February 2018 17:24
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Figo Suspension - to mod or not to mod KiloAlpha Modifications & Accessories 18 13th May 2013 19:00
Old model Suzuki 800 mod questions. Sankar Modifications & Accessories 61 6th May 2009 23:40
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 19:26
