Old 27th June 2011, 10:46   #436
swiftboost's Avatar
Thanked: 43 Times
Default Re: The Maruti 800 Mod Thread
Where are you located in Kerala? I can speak to some people I know to help you out. Hopefully, they will be able to sort things out for you.
swiftboost is offline   (1) Thanks Reply With Quote
Old 27th June 2011, 13:52   #437
glomus123's Avatar
Thanked: 47 Times
Thanks !! Anywhere in and around Palakkad / Thrissur / Calicut / Coimbatore will be helpful!
With thanks and regards
glomus123 is offline   Reply With Quote
Old 10th December 2012, 22:33   #438
Vivek Jayan's Avatar
Thanked: 30 Times
Hey guys, I was thinking of refurbishing the old maruti 800 which my grandpa bought some 26 years back. I don't want it to be sold off to anyone as I feel it's part of my grandpa's "legacy". She still runs pretty decently for an old bird but has the occasional coughs and whistles. The interiors are really beat up and look absolutely pathetic. I'm willing to spend a good 2 lakhs or more in refurbishing her, but I need some solid advice on where to start and what to expect. I don't want anything gaudy like spoilers and stuff. I would like a decent set of wheels, maybe an engine overhaul, new interior parts, a new paint- job, new lights, stereo and maybe central locking. I was also thinking if it's possible to put the new k10 engine into the 800. All your help would be much appreciated.
Vivek Jayan is offline   (2) Thanks Reply With Quote
Old 25th February 2013, 18:17   #439
B.R.S.Rao's Avatar
Thanked: 56 Times
I have Maruti 800, 2010 model. I have fitted brake booster (KBX) and Stebel horn. Works well. Original ceat tyres crossed more than 42,000kms. Planning to fit alloys and 165/60/R12 tyres. Its a good car and never let me down till today.
B.R.S.Rao is offline   (5) Thanks Reply With Quote
Old 27th February 2013, 00:58   #440
Thanked: 98 Times
Kindly detail the process.
Digital clock & volt meter, both are looking nice.
(Alok) is offline   Reply With Quote
Old 27th February 2013, 10:42   #441
B.R.S.Rao's Avatar
Thanked: 56 Times
Hi, Alok.
KBX Booster kits are available in major auto parts dealers. Earlier Maruti 800 ( 5 gears model) used to come with factory fitted booster kit. KBX is the direct replacement for Maruti 800. If you have Old model Maruti 800, vacuum connection should be taken from the inlet manifold by drilling a small hole and fitting with small hose nipple. If you own latest Maruthi 800, vacuum pipe of the booster brake should be connected as per the picture I have posted below. ( red hose pipe) I have used brass type gas nipple (3 way) which is freely available with domestic gas stove repairer. Please use good type of hose for vacuum outlet as well as good quality hose clips. Also drain old brake fluid and use good quality brake fluid (TVS Girling Dot 3), see that there is no air-bubble in brake lines, cylinders. A good mechanic will help you in this process. Please note that after fitting brake booster unless the engine is in on condition, you won't get the pedal power and while driving the down hill you should not off the engine.
Stebel is a high quality horn, should be fitted with horn relay. I really like it.
B.R.S.Rao is offline   Reply With Quote
Old 4th March 2013, 13:45   #442
Thanked: 73 Times
Does anyone have a set of steel rims available for disposal? My rims are all beat up and looking to change them.
I am located in Bangalore.
Prajwal
prajwalkashyap is offline   Reply With Quote
Old 6th March 2013, 12:06   #443
swiftboost's Avatar
Thanked: 43 Times
I have a sparingly used set of rims in very good condition. Let me know if you are interested. Iam also at Bangalore.
Prajwal
swiftboost is offline   Reply With Quote
Old 6th March 2013, 16:00   #444
Thanked: 73 Times
Have sent you a pm.
Prajwal
Old 7th October 2013, 18:06   #445
B.R.S.Rao's Avatar
Thanked: 56 Times
Hi, One of my close friend Mr.Varun of Bangalore successfully modified his Maruthi 800 with power steering. Amazing..
B.R.S.Rao is offline   (2) Thanks Reply With Quote
Old 8th October 2013, 00:43   #446
josejoseph's Avatar
Thanked: 319 Times
Can we have more info about the installation such as the make and cost?
josejoseph is offline   Reply With Quote
Old 8th October 2013, 11:46   #447
B.R.S.Rao's Avatar
Thanked: 56 Times
Mr.Varun fitted EPS unit of Alto. You can contact him through email for further details. His email is varun560061@gmail.com.
Here is more pictures of his superbly maintained 10 year old Maruthi 800. Now it has power steering, power windows, power brake system, free flow exhaust, K & N filter, strobe lights, rear wash and wipe, remote fuel cover opener, extra power alternator, super cool A/c., wide tyres,excellent ICE system, etc.,
B.R.S.Rao is offline   (4) Thanks Reply With Quote
Old 8th October 2013, 12:57   #448
saket77's Avatar
Thanked: 4,867 Times
Some serious mods there BRS Rao by your friend, particularly the power steering & power brakes. Ask your friend to join TBHP so that many other petrol heads can be aided by his advice.
Thanks for sharing it all,
Saket
saket77 is offline   (2) Thanks Reply With Quote
Old 14th December 2013, 18:24   #449
Maverick79's Avatar
Thanked: 527 Times
Guys,
I am looking for a good Mechanic/ MASS in and around Dilshuknagar area in Hyderabad for my '98 M800.
Pls suggest based on your experience.
It's Odo is reading 1,20,000 now.
Thanks in Advance.
Maverick79.
Maverick79 is offline   Reply With Quote
Old 1st May 2014, 15:45   #450
You are confused. 5-speed or mpfi or a carb does not have any link in not able to fit a brake booster.
You can fit a brake booster to almost all the cars on earth from any era.
1) Fit the brake booster.
2) Fix a T joint to the intake manifold (provided with the KBX kit)
3) Connect the vacuum pipe to it.
The whole set-up should cost around 3K including all spares and the mechanic labour.
I have a Maruti 800 SS 1985 model. Can a brake booster be fitted in this car? Any garage in Bangalore where this can be carried out?
sanjayrmenon is offline   Reply With Quote
Maruti 800 : Tyre & wheel upgrade thread Ram Tyre & Alloy wheel Section 247 24th February 2018 17:24
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Figo Suspension - to mod or not to mod KiloAlpha Modifications & Accessories 18 13th May 2013 19:00
Old model Suzuki 800 mod questions. Sankar Modifications & Accessories 61 6th May 2009 23:40
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 19:26
