Old 5th March 2015, 12:21   #451
Thanked: 24 Times
Default Re: The Maruti 800 Mod Thread
My 2005 model new M800 AC BS3 is giving me trouble. The car is consuming coolant. No leakages as I never find any fluids under the car. Suspect a blown head gasket. But I have no over-heating issues at all. The car is running perfectly, almost as good as new.
Going for a compression test tomorrow. Can someone tell me what are the things to be kept in mind? Is it advisable to go for compression test? Somewhere on this forum I have read that the compression test may make matters worse. It may actually give birth to the problem where there was none.
The car was neglected for a while but there were no signs of engine trouble. Except a tappet change and leaking engine oil there were no other problems at all.
Ashok Naik is offline   Reply With Quote
Old 30th July 2015, 15:03   #452
Thanked: 84 Times
I found my much elusive Auto transmission kit, all working from a 1995 M-800.
Any update on this? Did you finally pick up the unit. I understand you have sold your M800.
Live To Jive is offline   Reply With Quote
Old 26th December 2016, 16:17   #453
Maverick79's Avatar
Thanked: 524 Times
Guys,
I am thinking of converting the Manual transmission to Auto box on my '98 M 800 DX.
Just don't want to sell the vehicle at 1.32 Lakh Kms.
Pls share any leads, experiences of searching/ sourcing/ buying/ changing the same.
Mechanics references in Hyd and Chennai are welcome.
Thanks in advance.
Maverick79
Maverick79 is offline   Reply With Quote
Old 28th July 2017, 16:05   #454
Maverick79's Avatar
Thanked: 524 Times
Originally Posted by Maverick79 View Post
Guys,
Thanks in advance.
Maverick79
Just trying to understand if the old Zen( Jelly bean shape) Auto box will be a straight fit to '98 M800?
Also, got a quote of 20K for changing the entire AC kit with latest refrigerant from a MASS. Pls share your valuable inputs on the same.
Maruti 800 : Tyre & wheel upgrade thread Ram Tyre & Alloy wheel Section 235 28th November 2017 12:40
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Figo Suspension - to mod or not to mod KiloAlpha Modifications & Accessories 18 13th May 2013 19:00
Old model Suzuki 800 mod questions. Sankar Modifications & Accessories 61 6th May 2009 23:40
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 19:26
