Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 17th February 2007, 12:02   #16 (permalink)
BUSA's Avatar
Post
Originally Posted by Mp421b View Post
wat do you guys think of the 185/70/14....thats wat comes with the zxi. all i wanna ask is that is the above size not good enough for the vdi considerin its approx 60 kg's more nose heavy.... and wat will be the diff in the grip, ride and fe as compared to the 195/60/15....?????
Guys any input on this??
__________________
thecarsandmore.blogspot. com
Old 17th February 2007, 12:09   #17 (permalink)
vid6639's Avatar
Well between the 2 the mileage wont differ. the 185/70-14 is a decent size. Only if you find the grip lacking with these you should upgrade to the 195/60-15. For everyday driving the 185/70-14 will suffice.
But I think that the mileage will go down when upgrading to 195/60-15 from 165/80-14.
one thing being 30mm increase on each tyre so total contact patch increase is 120mm (6") more.
Secondly the new tyre will generally be a softer compound providing better grip and more sticky types.
Rather than 0.5kmpl i would say 1-1.5kmpl decrease in mileage.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 17th February 2007, 15:51   #18 (permalink)
BUSA's Avatar
Thanx vid6639 The Petrol version does have 185s but grip levels are not that good. With the diesel being much more torquier as well as heavier i think 195s are a must.
What will be the diffrence in ride between 185/70/14 and 195/60/15
__________________
Old 17th February 2007, 15:54   #19 (permalink)
Tech's Avatar
Congrats BUSA for booking the Vdi. I drove that dream machine and found it quite torquier than the petrol one. I could feel that kick feeling when you try to rip the Suzuki.
When are you getting the delivery? How much time did they quote to you in Mumbai?
Tech is offline   Reply With Quote
Old 17th February 2007, 16:09   #20 (permalink)
ramie2400's Avatar
how much does the pete's tuning box costs approx.
__________________
"Whenever I find the key to success,..... someone changes the lock.
ramie2400 is online now   Reply With Quote
Old 17th February 2007, 16:11   #21 (permalink)
vid6639's Avatar
Yeah, ride quality will differ but not by much. Unless you drive on really bad roads.
For normal roads you wont feel much difference. Only a little harder.
Just remember you lose 1inch of rubber to cushion your ride so it's bound to get a little harder.
__________________
(o.o)
( X )
Old 17th February 2007, 16:35   #22 (permalink)
Team-BHP Moderator
theMAG's Avatar
FYI, its 75 kgs heavier not 60. An educated guess will say that the suspension will be slightly stiffened else it'll wallow like sinking boat. With that extra weight, the ideal petrol Swift upsize 195/60 R15 will still apply, but you'll need to keep a higher psi of atleast 31 for city and 32 for highways.
__________________
If you lose your temper, you’ve lost the argument
Old 17th February 2007, 17:12   #23 (permalink)
vid6639's Avatar
Just drove the VDi. The tyres are definitely sad and not at all reassuring.
The car does feel nose heavy. The suspension on the front has been stiffened.
The brakes were also not as reassuring as the petrol probably due to the extra weight.
You definitely need 185 for better ride and handling. For even better handling get the 195/60-15 but since the suspension on the front is stiffened I think it may be a little harsh.
__________________
(o.o)
( X )
Old 17th February 2007, 18:20   #24 (permalink)
BUSA's Avatar
Post
Thanx theFag and vid6639
Getting the delivery in the next month. They are saying it will take atleast one month as it is with ABS.
Around 33K, but will become lower from the 1st of March, thats what Peter has told me.
You mean the ride will be a liltle harsh?
__________________
Old 17th February 2007, 18:45   #25 (permalink)
vid6639's Avatar
Yup but obviou will become harsh. i found it already has a stiffened front suspension, the rear feels the same but the front is definitely more stiffer than the petrol.
Add to that 15" rims compared to 14" it has to become more stiff.
__________________
(o.o)
( X )
Old 17th February 2007, 18:59   #26 (permalink)
Abix's Avatar
Guys, ive had 17's on my swift with 205/40 rubber! Yeah the ride isnt the same as the puny 14's that the swift comes stock with, but to be very honest didnt make much of a difference on delhi roads! As for performance if u do spend money on decent performance alloys which obviously will be higher priced than the taiwanese ones you get here but are quite lighweight. Fuel efficiency i seriously believe depends on how you drive your car! So if you are goin for 15's then go for it its actually the correct upsize! hope this helped!
Abix
Abix is offline   Reply With Quote
Old 17th February 2007, 21:02   #27 (permalink)
BUSA's Avatar
Thanx Abix, that really helped. I am more inclined towards 15 inchers, but my other car is a Optra which has excellent ride even on 50 profile rubber, so dont want the Swifts ride to be bad. Would want the best mix of ride and handling. I want such tyres that the Swift should handle better then the 1.6 Palio.
__________________
Old 17th February 2007, 21:13   #28 (permalink)
Abix's Avatar
Busa, as far as rubber goes, i use Hankook's Ventus rubber, its got a very good grip and is noiseless!
Old 17th February 2007, 23:29   #29 (permalink)
Team-BHP Moderator
theMAG's Avatar
I got the same rubber, and while its grip is great its not entirely noiseless
__________________
Old 18th February 2007, 09:20   #30 (permalink)
HAFI's Avatar
hey is petes tuning box out only for swift vdi?...is it available for the petrol versions and others models of maruti like zen?..
__________________
2004 MODDED ZEN |--| FIAT PALIO 1.6 GTX|--| 2002 BOLERO |--| 2006 LANCER |--| 2001 OMNI |--| 97 M 800 |--| 2004 HONDA UNICORN
HAFI is offline   Reply With Quote
Thread Tools
Swift it is! But ZXI or VDI? itwasntme Hatchbacks 47 23rd September 2007 23:32
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 1 16th August 2007 14:21
How to Get a Swift Vdi with ABS? rrnsss Indian Car Dealerships 22 14th August 2007 14:05
SWIFT - VXi or VDi?? ajinkyapose Hatchbacks 53 5th April 2007 12:15
Swift Vxi or Swift Vdi or New Ikon Flair nikunj_cal Hatchbacks 16 4th April 2007 02:40
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
