| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | My Palio 1.2 completed 8,500Kms so I thought I should start doing some mods to improve performance. Called up a few people including some BHPians and almost everyone told me that the order in which one should go for the mods is : K&N --->Iridium Spark Plugs -----> FFE -----> keep going until you are satisfied So I got the K&N xtreme filter installed (No cold intake ...used the OEM filter box hosing) [img=http://img352.imageshack.us/img352/706/img0110md1.th.jpg] The roaring sound of the air intake is awesome but it seems it gives a false sense of power increase. I think my filter is sucking in hot air and hence no improvement in performance. Now my query is : what should I do to get the maximum out of the filter (I know I cant make my 1.2 into a GTX ). getting a mandrel bend pipe work is one of the option. Would it help? should the filter be intalled at the same location where the OEM box sits. Read in an article that cutting a hole into the bumper and placing the filter near this hole is the best location. They defined this type of installation as a cold intake (Refer to the article),though it will make it impossible to protect the filter from splashed during monsoons. Guys Please suggest what I should do? I noticed three slits in the left side of the front bumper which arent there on the right side. Can any one tell me why is it so. Is that a provision made for Air intake for Palios outside India or something [img=http://img399.imageshack.us/img399/5282/50763231ij9.th.jpg] [img=http://img354.imageshack.us/img354/6062/46051223kr4.th.jpg] I hope I will not be redirected to a closed K&N thread because i am posting this when I couldnt find the answer to my questions in the existing threads
__________________ Boyz will remain Boyz.......Only their Toyz change |
| | #2 (permalink) |
| BHPian | Your filter's location seems to be fine. The cold air intake you've seen posted on the net where you put the filter behind the bumper is not a good idea on our roads and especially in the monsoons. You can route a pipe from the bumper to where your filter is located and see how it works. An oversized filter can also hurt your throttle response, bigger is always not better. If you get an intake pipe made for your filter, don't get it done in 3", try 2.5" dia and get it specifically made for your car. Got mine made in aluminium 2.5" tubing with velocity stack. |
| | #3 (permalink) |
| Senior - BHPian | The current location of ur conical filter is the ONLY location for a Palio apart from the dangerous bumper location. We've done this setup before and it works really well! Nothing to worry.
__________________ hindu.com/mp/2008/08/25/stories/2008082522220200.htm |
| | #5 (permalink) |
| BHPian | I used to have the same problem which you are facing now. My filter was located in the centre of the engine bay and was drawing in hot air. In the mornings when I used to leave for college at 8am the car was very responsive. I used to drive from DLF, gurgaon to DCE, Rohini everyday. As it was cold in the morning the car was very responisve, however during the day I felt the car was more sluggish than stock. So I manufactured a new CAI pipe out of aluminium in 2.5" dia and welded a custom made velocity stack at the mouth of the pipe. the filter has a 3" flange. Here is a pic of the same. http://www.team-bhp.com/forum/indian...?do=big&p=3074 Will try routing a pipe from the front of the bumper towards the filter once I finish my exams next week. |
| | #7 (permalink) | |
| Senior - BHPian | Quote:
That's pretty interesting. My 2002 Palio ELX doesn't have these extra slits. I guess yours is an NV from the fogs and the colour. Maybe the slits are from the NV onwards. Anybody know what they are there for?
__________________ Coming soon: Balls of STEEL! Last edited by hydrashok : 16th March 2007 at 21:08. | |
| | #9 (permalink) |
| BHPian | went to this place called Engineers corporation today ( they sell and fit K&N and FFEs ) and the owner of the place told me that the set up is perfect and adding a pipe wont make a different and if I still wanna empty a few bucks from my pocket then its my wish. I have seen a few K&N setups in Palios and almost everyone including Subzero have the similar kind of setup. I am trying to put a hose routing from the bumper to the Filter to create a semi Ram setup. About the slits , i still havent figured out why they are there and Hydrashok is right I couldnt find these slits in pre nv models
| | #10 (permalink) | |
| BHPian | Quote:
| | #13 (permalink) | |
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) | |
| | #15 (permalink) | |
| BHPian | Quote:
Relocating IAT Sensor - This is a very simple modification that will work on a great deal of fuel injected vehicles. The IAT sensor (“Intake Air Temperature”) tells the computer how hot or cold the incoming air is. The computer will then adjust the amount of fuel being injected, as well as make minor adjustments to timing based on that reading. The problem is that in many vehicles, the IAT sensor is located in the intake manifold, near the cylinder head. Therefore the air that the IAT sensor “reads” is much hotter than the air, say, in the intake arm. The idea with this mod, is to relocate the sensor to the intake arm. Use JB Weld or similar to patch up the old port for the sensor. This will cause the computer to believe that incoming air is slightly cooler, causing it to inject more fuel and advance the timing a tad
__________________ Boyz will remain Boyz.......Only their Toyz change | |
| Thread Tools | |
Similar Threads | ||||
| Cleaning a K&N conical filter | rishibravo | Modifications & Accessories | 60 | 23rd May 2008 10:31 |
| Performance Conical Filter and Sparkplugs for Pulsar 150dtsi..??? | ramie2400 | Motorbikes | 43 | 12th March 2008 17:02 |
| K&N Conical Extreme Air Filter for Sale | Slash | Shifting gears | 5 | 26th November 2007 18:12 |
| 15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. | karthik247 | Shifting gears | 9 | 24th January 2007 19:33 |
| Fitting K&N Conical Filter. | MexXxentric | Modifications & Accessories | 10 | 14th June 2006 12:37 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
