Old 23rd March 2007, 01:54   #1
Thanked: 59 Times
Question Dukkar fiat - what engine choices
folks,
(and gurus of engine mods and swaps)
which currently available engines can be transplanted into a dukkar fiat ??
I know the 118NE engine can. but what about something with some more juice ??? nothing obscene....just enough to cruise comfortably at around 80-90 kmph in the dukkar.
what about the amby 1.8 ISZ ??? it won't fit, will it ??? what other options ???
hell_rider is offline   Reply With Quote
Old 23rd March 2007, 02:41   #2
Mpower's Avatar
Thanked: 1,687 Times
The Gypsy engine will be a smooth operator. Omni engine will also fit and makes the same power but wont sound as good. Other choice is the Conti 1.8.
Are you planning to keep the trans?
Old 23rd March 2007, 02:46   #3
ananthkamath's Avatar
Thanked: 63 Times
I second what Mpower said....although if you can find the Gypsy king engine and gearbox its a much better choice.
contessa engine will require you to either cut the firewall or extend the nose of the car. cutting the firewall is tough because the steering system sits there. however if you put in the rack and pinion box from a cielo or similar sized car that problem is solved to an extent.
the other thing you need to do when doing an engine swap is to change the differential gears to 3.8 from the 118ne (bolt-on fit) from the 4.3 that comes in the stock 1100.
ananthkamath is offline   Reply With Quote
Old 23rd March 2007, 17:51   #4
Thanked: 92 Times
Hehe.. Suddenly we have three threads running simultaneously on Fiat 1100
You can try this link
http://www.team-bhp.com/forum/modifi...r-padmini.html (What replacement engine for FIAT-1100D (premier padmini))
Also, there is a post of karlosdeville of dukkar fiat with a 118NE engine in this thread
http://www.team-bhp.com/forum/modifi...0-awesome.html
salilpawar1 is offline   Reply With Quote
Old 23rd March 2007, 21:40   #5
v1p3r's Avatar
Thanked: 27 Times
Just plonk a V6 in it.
Old 24th March 2007, 03:36   #6
V-16's Avatar
Thanked: 862 Times
[/url]
Just wait till i get my hands on a padmini with the sole intention of hybridising her...(er is there such a word..??)
V-16 is offline   Reply With Quote
Old 24th March 2007, 07:14   #7
tsk1979's Avatar
Thanked: 16,420 Times
A toyota or Daihatsu diesel pumping out around 50-70bhp. This is the most common mod up north. If you are adventurous, you can look for somebody who has bought something like a OHC 1.3 for an engine swap, and get the gearbox along.
Tyres for Dukkar jubin Tyre & Alloy wheel Section 4 25th December 2009 13:26
Wanted : dukkar fiat paras211 Shifting gears 0 9th July 2007 00:27
Buying Help Reqd.Current Monthly Cost Rs 2500/-.Choices Fusion (petrol/diesel),SX4etc subscrive Sedans 7 12th June 2007 22:14
Choices, choices! shekharlele Hatchbacks 12 18th December 2006 11:26
New car choices jesal Sedans 32 7th September 2004 20:00
