Old 23rd March 2007, 18:54   #1
gbpscars's Avatar
Default HID Xenon fog / driving lamps for OHC
hi,
i would like to install a H7, 35W, 6000 K HID kit on the fog lamp location of a OHC.
but i would like to do so only with a projector housing, and also preferably of a high beam or long throw / spread lens setup.
i had been to Autograph Skoda in Andheri, Mumbai to get hold of any accident car's projector lens from a damaged headlamp enclosure.
the best one would be the high beam lens setup of a Skoda Laura.
optionally a complete decorative housing something near to what I'm looking for would be like what you can see if you google for "Hella Micro DE" or "hid projector" in motors.ebay.com
could anyone let me know if there are other options that i might not have thought about if i need a projector housing for HID?
can i get this anywhere else?
Last edited by gbpscars : 23rd March 2007 at 18:58. Reason: wanted to add 'HID' in the title
gbpscars is offline   Reply With Quote
Old 2nd June 2008, 15:32   #2
Hi
To the best of my knowledge there is no Projector set up available for OHC.
Rgds
cancerm is offline   Reply With Quote
Old 2nd June 2008, 16:04   #3
JayD's Avatar
Thanked: 2,008 Times
I don't think the laura has a projector for the high beam, its only for low.
Go thru the 2 DIY projector threads on this forum to get more info.
Old 2nd June 2008, 18:16   #4
aZa
aZa's Avatar
Thanked: 17 Times
Yep it has projectors only for the low beam! Those projectors are pretty small too. You should get a aftermarket fog lamp casing like the ones on VIPERS Honda. And then try retrofitting projectors from either laura or any other car. The problem with Projectors in the fog lights is the FOCUS and throw of the light, as the fogs are closer to the ground
Old 17th October 2008, 11:14   #5
9thsphinx's Avatar
Thanked: 467 Times
Originally Posted by gbpscars View Post
hi,
any recommendations for fitting HID Xenons for the OHC? What brand are good? What color temperatures suit best for driving in the rains? Do I need projectors or the existing casing would do?
9thsphinx is offline   Reply With Quote
HID Kit / Projector / Xenon Lamps FAQ Takumi-san Modifications & Accessories 17 12th August 2015 14:34
OHC OE Fog Lamps: Hidden treasure or Hidden trash? ankitahuja Modifications & Accessories 38 7th November 2012 00:04
Projector Lamps(Low Beam) as Fog Lamps for Ritz LDI alexpaul Modifications & Accessories 17 13th September 2012 20:23
Fog lamps without fog dushmish Road Safety 113 5th January 2012 12:51
