Old 29th March 2007, 18:01   #16
supremeBaleno's Avatar
Thanked: 580 Times
Originally Posted by gigy
i have one bought from marks & spencers,uk (cost 5pounds). which has a switch to select the pump or a light, working fine till now, every week i check air in all four tyres. you do have to hold it while operating
Sounds pretty much like the one I have, which is a "Campbell Hausfeld" product. Pretty useful to have in the car. Will try to post a snap.
Old 29th March 2007, 20:02   #17
aah78's Avatar
Thanked: 183 Times
Default michelin digital inflator
Originally Posted by speed0mania View Post
i think the compressor and tubeless tyres is the best solution!!
Originally Posted by akshay1234 View Post
this is a bit of a stupid suggestion but why not check out tubeless tyres. ater they get punctures u can still drive around for a bit. at least till the nearest tyre repair shop.
you guys are referring to run-flat tires here. tubeless tires deflate the same as a tubed tire - maybe at a slightly slower rate but they still will deflate.
run-flats, on the other hand are designed to maintain tire-pressure, in the event of a puncture, for as long as the tire is rolling.
air begins escaping once the vehicle haults.
@DiverR: i've been using a 12V Michelin Digital Tyre Inflator for a while now. it plugs into the cigarette lighter socket and runs off the battery. you can program the desired psi and the pump fills to the desired mark and turns-off automatically. it's a small package so it does take a while to fill a fully-deflated tyre but it's easier to store.
aah78 is offline   Reply With Quote
Old 29th March 2007, 20:52   #18
revtech's Avatar
Thanked: 13 Times
i had one years back which used to work really well..it also had a pressure gauge but it wasnt digital.eventually it got lost and since then have been looking out for a good one but couldnt in india.
recently i got on down from the USA its got 2 air pressure settings, light pressure gauge.works fine.
my advise to you is ask someone coming down mrom USA, UK, Malaysia to get it for you and dont but some cheap one from india cause they arent very reliable and may not work very long.
revtech is offline   Reply With Quote
Old 29th March 2007, 21:24   #19
I got one of the 12V air compressors from ebay india (with gauge and torch).
It cost about Rs 900 (I think)
The product claims to be made in Taiwan, fit and finish is crude--but it works ok. Terribly noisy though, and vibrates like hell during operation.
The gauge on it is quite accurate--I have compared it to a digital tire pressure gauge.
Topping up air in tires is quite easy, but I have not tested how long it would take to fill a completely deflated tire.
giri is offline   Reply With Quote
Old 29th March 2007, 22:28   #20
v1p3r's Avatar
Much slower. Tubeless tyres can deflate for over a week and you still won't be in a life-threatening situation.
Old 29th March 2007, 22:38   #21
v1p3r's Avatar
Will find out, but I think it's in that 3-3.5k price range anyway.
Old 30th March 2007, 08:33   #22
DriverR's Avatar
Thanks for all the information. I'll see if I can source one from abroad. Or maybe as a quick-fix ,try out the Ebay ones.
DriverR is offline   Reply With Quote
Old 30th March 2007, 10:42   #23
Thanked: 580 Times
Snaps of the tyre-inflator I use. Pretty handy. Was a gift from the company I work for.
Old 30th March 2007, 12:25   #24
gd1418's Avatar
Thanked: 432 Times
Invisible snaps...!!! Oops, sorry. On a refresh the snaps loaded...
Old 30th March 2007, 16:05   #25
akshay1234's Avatar
Thanked: 1,580 Times
nope. im talking about tubeless tyres. your wrong over there. tubeless seal themeselves after a puncture. they do leak air. no doubt about that but at a much slower rate than tube.
akshay1234 is offline   Reply With Quote
Old 7th January 2010, 17:05   #26
Thanked: 580 Times
A friend was coming down from the US and he got me another inflator - for my Dad's Swift. This was a Slime inflator - pretty compact. Did not try it out yet though. Costs 24$.
More details at SLIME - Worldwide Leader in Tire Care - NEW Slime Quick Spair & Slime Shield
Old 29th March 2011, 10:59   #27
lordofgondor's Avatar
Thanked: 68 Times
Default Re: Regarding electronic jacks and air inflators
Hey fellas, I was in the market yesterday looking for a good quality air compressor. A shopkeeper recommended going for one branded as Linus. I was told that it'll easily bring from zero pressure to 32 PSI in 3 minutes and the quoted amount was INR 3000.
Now the questions:
1. Has anyone has had an experience with Linus air compressor? If so, any feedbacks?
2. Does the cost seem right? Am slightly in the dark side cause there was no price printed on the box!
EDIT: The product comes along with a 1 year warranty.
lordofgondor is offline   Reply With Quote
Old 27th April 2011, 15:33   #28
amitwlele's Avatar
Thanked: 290 Times
Now the questions:
No experience with Linus but recently purchased a LIMI Digital Tyre inflator in Pune. The price on the box was Rs.2900/- but got it for Rs.2475 (inclusive of 12.5% tax). The inflator also has a emergency light with it. This one also has a one year warranty.
amitwlele is offline   Reply With Quote
Old 27th April 2011, 15:51   #29
Swanand Inamdar's Avatar
Thanked: 506 Times
Amit, that looks like a pretty decent infaltor that you got. Could you tell the name of the shop you picked it up from?
Secondly, sorry for sounding naive, but how does this work? If you need to connect it to the power outlet (ciggy lighter), isnt the line provided a bit short?
Swanand Inamdar is offline   Reply With Quote
Old 27th April 2011, 20:47   #30
cooljai's Avatar
Amit, would you know how much time it takes to inflate a new tyre?
And can we set the required pressure and will it cut off after that?
Also, is there any chance of the car battery getting drained by running this in the morning to check all four tyres?
cooljai is offline   Reply With Quote
Hydraulic Jacks swathyd Modifications & Accessories 47 8th October 2011 12:56
CAI will suck only cold air: even if sucking in air just next from the engine :-) khan_sultan Street Experiences 19 30th June 2008 09:29
Best air filter or cold air intake for Skoda RS Kartik9500 Modifications & Accessories 9 7th February 2008 02:43
Logitech's X Air Mouse Works on the Desk and in the Air !!! cypher Gadgets, Computers & Software 4 10th September 2007 07:47
