Old 24th April 2007, 13:02   #31
chetanhanda's Avatar
Thanked: 44 Times
Originally Posted by elf View Post
Moving the fulcrum upwards would need a complete refabrication of the gear lever, facility access to which I didn't have.
The feel's very mechanical, very non-rubbery, effort slightly on the higher side, but very 'connected' as I mentioned in one of my PMs to another member. All in all, I now feel I'm driving a car, not a BEST bus. The OE shifter was huuuuuge!
wow chopping off 4 inches made such a big diff..
chetanhanda is offline   Reply With Quote
Old 24th April 2007, 13:09   #32
razor4077's Avatar
Thanked: 258 Times
As anybody will tell you, it's not the length of your shaft, it's what you do with it. Mine was too long, hence I shortened it. Now I get less boring hand movement & more action.
ROFL!!!!!
PS: This post has nothing whatsover to do with a Short shifter. I am writing this post script because I had to fill in at least 20 chars!
razor4077 is offline   Reply With Quote
Old 24th April 2007, 13:22   #33
Bullfrog's Avatar
Thanked: 24 Times
That's Vintage elf in action.
Bullfrog is offline   Reply With Quote
Old 24th April 2007, 22:03   #34
Thanked: 44 Times
isnt that too much of an exaggeration.. chopping of 4 inches is equivalent to simply holding the lever close to the base of the gear lever and applying more effort.
why do people buy short shifter kits if simply chopping off the lever makes it a short shifter.
I know you didnt have access to facility but dont exaggerate so much also even when you know its not the real thing.
the taught and precise feel of a short shifter is sometimes due to the extra weight added to reduce the effort in the lever action, also they also come with newer bushings which reduce the rubbery feel also...chopping of 4 inches is not a real short shifter kit
elf slow down and plz dont make any personal remarks this time..
Now go back quietly to your 25BHP thread & bother somebody else with your great knowlege about all things mechanical.
Old 24th April 2007, 22:36   #35
Vid6639's Avatar
Thanked: 21,042 Times
why do people why short shifter kits if simply chopping off the lever makes it a short shifter.
the taught and precise feel of a short shifter is due to the extra weight added to reduce the effort in the lever action, also they also come with newer bushings which reduce the rubery feel also...chopping of 4 inches is not a real short shifter kit
he may not be exaggerating. I think theres a better way to ask. If you notice a few posts back i asked him if he has really chopped of the stick cause i dint believe him. have you seen the lancer gear stick here. It's huge. the length from the base part popping out of the console is like 6-7inches. It has a long throw and it's very high up.
Also, he has clearly mentioned he chopped of nearly 4".
Pls' go to his gallery and have a look. you can see the shroud wrapped around tightly since the stick is chopped.
And the Lancer's gear is very slick and smooth so the effort increase may not be much.
Old 24th April 2007, 23:00   #36
16v100bhp's Avatar
Ok googleboy, at least credit the source you whacked your explanation from.
Here it is:
What is a Short Shifter
OK, the soap's been dropped. You know what to do.
ROFL...
I have been to that link before. That explains well.
@Manveet, you could have posted the gifs from that link man, it really does the work...
16v100bhp is offline   Reply With Quote
Old 24th April 2007, 23:40   #37
16v100bhp's Avatar
@chetan: I think you were pretty clear on what you had to convey in the 31st post itself....
There can be multiple reasons why people go in for the above technique. Availability of an SSK is just one reason. If chopping the gear lever is a step closer to SS, then thats that at least right??
Even putting a shorter dia steering wheel does the same thing. No body ever told that chopping of the lever makes an SS, but chopping the lever does the work for elf and thats what he wrote...
Why dont you actually try this "holding the lever close to the base of the gear lever and applying more effort" and see if it makes any difference to you ??
Old 25th April 2007, 00:19   #38
manveet's Avatar
Thanked: 586 Times
Apart from reducing the throw of the hand, the SS also shortens the shifting mechanism internally.
for e.g. a friend of mine has a custom built SS on his OHC that translates to a hand shift of only 0.75" from say neutral to 1st gear.
manveet is offline   Reply With Quote
Old 25th April 2007, 01:43   #39
elf
elf's Avatar
Thanked: 9 Times
Hey chetan, open invitation the next time you're down - come drive my car. Drive a stock Indian 1.5L Lancer first. Apart from the shortened gearshift, nothing else has been done to the transmission. Absolutely nothing. Yet.
Then we'll yakk. And either you or I will go home with a black eye. And the both of us will go home very drunk.
For the rest of you guys who stood up for me today, I would like to thank you. And buy you a drink at the chetanhanda meet.
elf is offline   Reply With Quote
Old 25th April 2007, 03:03   #40
Thanked: 44 Times
I like that response ..sure dude.
I liked the drunk part better , man you sure have lots of people standing up for you..
Old 27th April 2007, 14:48   #41
Ricky_63's Avatar
Thanked: 394 Times
The series of "interesting dialouges" has inpired me to get the stickshift of my lancer "pruned" to atlest 3" less than stock & then make an "informed " comment on the debate ........As I cannot afford to buy a short shifter after having spent what I did re-doing the Lancer........ He he he he !!!
Old 27th April 2007, 22:48   #42
Thanked: 44 Times
dude ur signature says redlining at 3500 RPM, what do you drive ?
an aircraft carrier ?
seriously, just curious how come u redlining so low? Is your ECU running in "limp home" mode or something ? MIL on or something ?
Old 27th April 2007, 22:53   #43
Vid6639's Avatar
chetan, he's just had his entire engine rebuilt and overhauled so he's taking it easy and running-in all his new parts. more details here:
http://www.team-bhp.com/forum/modifi...tml#post406780 (Newly Modded Lancer)
ps:he's not online so thought i'll post.
Old 27th April 2007, 23:08   #44
theMAG's Avatar
Thanked: 1,572 Times
Great - nice to see the cross of the short shifts. I'm confident that a clear verdict will be reached after this meet with chethanhanda properly testing elf's stick.
Old 28th April 2007, 00:34   #45
elf
elf's Avatar
Thanked: 9 Times
Shortened shaft, Maggie. It was huuuge earlier. Now stop drooling & behave yourself. It's smaller by four inches.
Snaps were clicked a coupla days ago, shall upload them tomorrow.
DIY: The Short Shifter racerdabba DIY - Do it yourself 18 12th December 2015 19:41
Indy-cator shifter knob? maven Modifications & Accessories 24 30th August 2013 12:05
short shifter for my corolla diven_b Modifications & Accessories 8 12th August 2011 16:36
