Old 30th March 2007, 11:13   #1
manveet's Avatar
Thanked: 586 Times
Unhappy Help Me: my new HID's are aiming at the sky !!
Hi Guys,
I installed HID's in my OHC Type1 yesterday and the problem is as follows:
Initially, after installing the HID's, only the top half of the headlamp was glowing with no light falling on the lower half. Also, the light beam was falling high up instead of on the road.
This problem was solved after removing the steel "topi" used on the HID lamps for anti-glare purpose - The result is that the light is atleast 3 times brighter than before.
However, at Low-Beam, the light is barely falling on the road. At night-time I can actually see see the beam going way upwards. On High-beam, the light actually falls on the tree tops and light beam on the road/traffic reduces almost to a nil.
Notes:
  1. The problem has not been solved by adjusting the nut behind the HL - that leads to more like Left/Right adjustment. However, there is only 1 such "adjustment nut" visible on my HL's - shouldn't there be two?
  2. my HL's are only 3 months old bought from the Honda showroom
What do I do??
Is adjusting the direction of the complete HL Unit by a denter the only option left?
manveet is offline   Reply With Quote
Old 30th March 2007, 11:22   #2
zakaaaaasss's Avatar
AFAIK, the beam adjustment is to be done with the Low Beam always and not with High beams. (applicable only for HLs using a single bulbs for both the lighting).
try readjusting your beams using only the low beam.
and yes, the HLs should have two adjustments screws (L-R and U-D)
zakaaaaasss is offline   Reply With Quote
Old 30th March 2007, 11:36   #3
Thanked: 294 Times
Hmmm....xenons on a non-projector setup.....this is the main problem...thats why the beams are pointing on the tree and the balcony of the houses.......
any ways there is a UL adjuster like there is RL adjuster....use it......
Old 30th March 2007, 11:53   #4
manveet's Avatar
Thanked: 586 Times
Are you guys SURE that the OHC has this?
As far as what was visible, there was only one adjustment knob.
There may be one placed where it was not visible, but I would need to dismantle the entire HL to check. Can anyone confirm the presence of such a knob on the OHC Type 1? I know some new cars have this, but its the Type 1 OHC which is what I am concerned about.
Old 30th March 2007, 11:57   #5
gd1418's Avatar
Thanked: 656 Times
Hello LBM, can you please explain this a bit in detail?
Old 30th March 2007, 12:00   #6
Vid6639's Avatar
Thanked: 21,060 Times
here we go again...
http://www.team-bhp.com/forum/modifi...t-failure.html (Xenons for Swift - Is a failure ?)
the above thread explains this in very deep detail.
Old 30th March 2007, 12:08   #7
manveet's Avatar
Thanked: 586 Times
Please refer this thread .. it's amongst LBM's favorite ones .. I'm sure it would clarify more than just a bit
http://www.team-bhp.com/forum/modifi...failure-2.html (Xenons for Swift - Is a failure ?)
LBM >
I have used a non-projector setup being cognizant of the fact that it is less efficient than a reflexive setup.
However, I have seen non-projector setup HID's aiming the light in the general vicinity of the road surface which is not happening in my case.
I'm sure the projector has nothing to do with this - unless you tell me that the setup in your Swift also aims the light on rooftops
Missed your post due as I was composing mine. Couldn't agree with you more
Anyways, my humble request is that lets not hijack this thread like the Swift one, I would appreciate constructive suggestions from all pertaining to the specific problem at hand.
Please Note, forgot mentioning this earlier > I am using Bi-xenons with a motorized system that moves the bulb front-back as per High-beam and Low-beam conditions
Old 30th March 2007, 12:14   #8
Thanked: 294 Times
Hmmm.....mine setup is perfectly working fine.....aiming on the road and can be adjusted for the roof ...as it has head light leveling device.....
Old 30th March 2007, 14:19   #9
tsk1979's Avatar
Thanked: 16,421 Times
Your OHC has just one nut, then its the same as indica, which has just U/D adjustment nut. Aim it to lowest possible by doing the following
1. Park against a wall, 5 feet
2. Move the nut to the lowermost position, if its still high up, then nothing more can be done, all you can do is move the projector lamp forward or backward such that the aiming is low.
You may need to do some jugaad if normal screw adjustment cannot aim the lights.
You can also try rotating the HID bulb.
HID bulbs give light in an arc pattern, it seems your arc is causing this.
So rotating your HID bulb will result in your beam moving in a circular path. Currently you are at the top of the circle, rotate it 180 degrees to come to the bottom.
If this fails(i.e the bulb cannot be rotated) then you can go to the road next to airport and spot airplanes.
Old 30th March 2007, 22:59   #10
harsh87's Avatar
me too having the same problem , not as severe as manveet's
low beam is now high beam and high beam is vvveerry high beam as manveet mentioned.
imagine 4300k hids that too on a santro reflector coming straight at you
harsh87 is offline   Reply With Quote
Old 30th March 2007, 23:30   #11
Thanked: 294 Times
good one tanveer.......the solution you have just answer is the best way to get rid of this problem.....so maveet how many planes you have spoted.....
so you are facing the same problem....I think there is a adjuster in the head light asmbly...which can be used to correct his problem.....further I would say if there is a meet tomm try to come there and we can discuss it then and there....as I have the same kit but I have no problem like this with mine setup....
Old 31st March 2007, 00:11   #12
faithless_1984's Avatar
Thanked: 217 Times
@ manveeteh - first of all congrats yaar , hey look on the bright side ,now that the light is falling on the Trees (and some balconies) at night it will make it easier for you to see the birds
good idea....what say manveeteh ?
faithless_1984 is offline   Reply With Quote
Old 31st March 2007, 00:59   #13
cheap_deal's Avatar
retro fit a good pair of projector headlamps to ur OHC, not only will the light fall properly on the road, it will also help the other drivers by not blinding them at night.
cheap_deal is offline   Reply With Quote
Old 31st March 2007, 01:57   #14
iraghava's Avatar
Thanked: 156 Times
Projector Lamps are not available for the OHC neither Type I nor Type II.
Old 31st March 2007, 06:42   #15
cheap_deal's Avatar
thats why i said retro fit one, something from another car maybe?
Maruti aiming for double digit sales growth every year till 2020! RavenAvi The Indian Car Scene 23 10th May 2016 11:42
Those blue eyes always reminded me of the sky! JRD who else? ECM Shifting gears 22 13th August 2010 15:21
NEWS: Toyota is aiming to cut car prices 30% by 2013 HammerHead The Indian Car Scene 18 22nd June 2010 10:50
Please help identify this import - It is in Bahrain EDIT - Its a Saturn Sky Srini76 The International Automotive Scene 10 23rd June 2009 20:17
Help me out with XENON / HID lights fb1 Modifications & Accessories 16 19th May 2007 02:55
