Old 6th April 2007, 08:38   #16
Godfather's Avatar
Thanked: 65 Times
Use this in India, and by the time you get to your car....someone else would have driven away in it.
I dont think so.. This came as a standard feature on my BMW in the US..
The vehicle will start but the doors remain locked.Also only the A/C controls can be accessed..
The same setup is also available for the Mercs.. See if you can get it. Very usefull. I am planning on getting on for My safari also.
Also you cannot drive away in the vehicle as there is no ignition key..
Godfather
Godfather is offline   Reply With Quote
Old 6th April 2007, 08:46   #17
Thanked: 38 Times
Infractions: 0/1 (5)
Default a must in canada
Remote ignition is a must in Canada. It's operated by pressing the lock key followed by the circular arrow key pressed till the vehicle starts.
The remote ignition has internal timer, it can be used only in 2 sessions of 10 mins each. After that it must be reset by inserting the car keys into the starter.
ownerofazkaban is offline   Reply With Quote
Old 6th April 2007, 09:12   #18
Godfather's Avatar
Thanked: 65 Times
Hmmm..thats weird.. I never had this issue.. Is it specific to brands??
are you referring to aftermarket installations or the ones pre installed in the cars from manufacturers?
Godfather
Old 6th April 2007, 09:13   #19
cheap_deal's Avatar
it can be installed in manual transmission cars, i had it on my jeep. it did have to be left in neutral with handbrake on which was a problem as i parked on a slope which turns real icy during the really cold days
but getting into a warm car when its -40 C outside sure felt good
edit:yes car would turn off it not moved in 15mins, was an aftermaket system.
cheap_deal is offline   Reply With Quote
Old 7th April 2007, 08:43   #20
rpanicker's Avatar
Default Remote start
I'd purchased an after-market kit while in the US and installed it in my Honda Accord. Wasn't successful though. The engine would crank but wouldn't catch. After a lot of research I learnt that to prevent hot-wiring, the cars onboard computer sends a signal to the key in the ignition and if doesn't find the specific key of the car, it wouldn't allow the car to start! (What was amazing to learn is that the cars key has a digital signature embedded in it so leaving another key or metal strip in the ignition wouldn't work - great security feature.) Have brought the kit back to India and it would be nice to see if this would work on my 2003 Accord (AT) here.
rpanicker is offline   Reply With Quote
Old 22nd April 2007, 18:35   #21
Thanked: 38 Times
Godfather
It's from standard factory fitment. I read about the 10 min timer in the manual of chevy Malibu, one of my rental cars in Canada. It said that was there as a security feature.
But the basic security feature is, you need to press lock and follow by remote ignition key,... which makes sure the car doors are locked.
Old 27th May 2007, 22:43   #22
kartikkumar's Avatar
Great feature but I have to agree with GTO on this one. Will be much too scared someone would have made away with my car by the time I get to it after remotely starting it. Prefer getting to the car, starting it, switching on the A/C leave the windows open for 3-4 minutes, roll them back up, and stand outside the car for another 3-4 minutes while it cools down.
However, out of curiousity I would love to know where in Bangalore I can get this system and how fool-proof it actually is. Any idea anyone?
kartikkumar is offline   Reply With Quote
Old 20th September 2007, 10:13   #23
thefreak's Avatar
Does this in any way impact warranty?
thefreak is offline   Reply With Quote
What to do if remote key fob fails and vehicle is equipped with Start-Stop button? arjab Technical Stuff 33 3rd February 2018 22:39
Remote Engine start system Dr.Vikas Modifications & Accessories 19 11th June 2017 09:49
Bike Security system with remote start. nikkibike Motorbikes 19 26th August 2014 03:38
DIY: Adding a Remote level control/ Bass remote to your Amplifier HimuraKenshin In-Car Entertainment 8 11th April 2012 16:59
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
