Old 7th May 2012, 18:07   #106
satyamkaushik's Avatar
Thanked: 120 Times
Originally Posted by Behemoth
Hi Satyam,
I also got my film removed from my Laura and also from the rear windshield too. I found something which works to help remove the glue from the windshield. I was experimenting with different chemicals and finally tested with a 50:50 mixture of thinner and Turpentine oil. This helps remove the glue, but has a very pungent smell and one can get giddy just from the fumes. It still requires a lot of effort to remove the glue and I had another guy to help me and it took us almost 30 min to remove the glue. This mixture also does not damage the defogger.
The only drawback is the smell will take a few days to go away!
Behemoth
Will try this too
And tell u the results.
I have almost lost hope on it and the next thing in my mind is to use a blade to do the thing
Any idea how much would a defogger cost for a santro ?
satyamkaushik is offline   Reply With Quote
Old 7th May 2012, 18:16   #107
n_aditya's Avatar
Thanked: 2,780 Times
Default Re: How to remove sun film from windows?
Note from Support - Please see the DIY section. There are a couple of threads which our members have posted for sun film removal from windows and windshields.
Old 7th May 2012, 20:57   #108
Thanked: 120 Times
Finally got rid of all the glue
Used vim liquid an scotch bright (used for cleaning utensils).
It took me more than 2 hours just to take off all the glue from the rear glass, but it was worth the effort to save my defogger
Old 10th June 2012, 12:09   #109
Pri2's Avatar
Thanked: 88 Times
After waiting for another deadline in Bangalore or a stay order on the sun film ban, I finally removed my sunfilms.
The process was simple. Just used a steam iron, steamed the SunFilm and started peeling. It came out in one piece, without any glue residue whatsoever!
Let the pictures do the talking:
Pri2 is offline   Reply With Quote
Old 10th June 2012, 12:28   #110
Pri2's Avatar
Thanked: 88 Times
Forgot to attach this picture :
Btw, that's my mom helping me with the iron.
I was surprised to see 2 layers of SunFilm.
I also helped my neighbours remove sunfilms with the same method and almost all sunfilms came off in one piece without leaving any glue residue. But there was one 3M SunFilm that was installed as a freebie by the car dealer left a lot of glue. Suspiciously fake.
Pri2 is offline   (1) Thanks Reply With Quote
Old 12th June 2012, 10:46   #111
samm's Avatar
Thanked: 97 Times
Removing the film as such has not been a problem for many! Even if it turns out a little difficult, there are ways to soften it up by baking under the sun, etc.
The real issue has been getting rid of the residual glue. There are lucky ones who escaped without any residual glue, though! This is for the not so lucky ones like me!
The best method (in my experience) to get crystal clear window panes without any risk to the glass or defogger lines is to rub using cotton cloth liberally dampened with surgical spirit (400ml costs 65 INR, avl in any medical store). The glue simply melts off and comes out on to the cloth. Some areas might require little more rubbing, though! Finally, spray a fine layer of colin and wipe using a clean cloth.
Results are amazing!
Using just colin and razor blade, it took about 3 hrs for me to remove 5 films (Santro). This colin/razor blade method is extremely difficult for the windshield with defogger. With the surgical spirit/colin method, I removed 7 films for Innova in less than 2 hrs time.
samm is offline   Reply With Quote
Old 1st July 2012, 02:09   #112
Thanked: 191 Times
Following up a 8th December 2007 post! Couple of weeks ago finally removed the sun film from two of my cars since Chennai police started enforcing the ban. Paid INR 500 for the first car and INR 400 for the second one, an INR 100 discount!
Murugan is offline   Reply With Quote
Old 7th July 2012, 13:10   #113
praful's Avatar
Thanked: 442 Times
After grounding the car for nearly two months I decided to go ahead with it. as it is I drive an outside state registered vehicle don't want further trouble.
Took one knife, generous amounts of Mr. Muscle, Colin, one whole newspaper and one hour of sweat...and its off
My car feels so naked now :( and I am not looking forward to the increased fuel bills!
The 7 year old garware films came off pretty easy and dint leave too much of adhesive behind. Whatever was left behind was easily removed with Mr. muscle spray. The "key" is to be very gentle in pulling out the films, else it leaves bits of adhesive left behind. There is no need really of wet newspapers or heating the film it comes off just like that!
praful is offline   (1) Thanks Reply With Quote
Old 25th July 2012, 13:17   #114
Thanked: 63 Times
Default Re: YOUR reaction to the Sun Film Verdict?
Need your inputs guys
Removed the sunfilm last sunday with lots of efforts. Large amounts of glue could not be wiped with Windshield cleaner. Had to use "Thinner" to remove the same. Cleaned it thourough with cleaner and now its totally film free.
My query is : Thinner I got from a hardware shop was in a plastic bottle, similar to 500 ml water bottle, and it costed me INR 40. Half of it is used now.
Can the thinner be stored in the same bottle for longer durations ?
Need your inputs
lambuhere1 is offline   Reply With Quote
Old 25th July 2012, 13:47   #115
Thanked: 137 Times
Need your inputs
Thinner can be stored in airtight bottles for long time. You can use if for household cleaning needs.
carbookie is offline   (1) Thanks Reply With Quote
Old 23rd October 2012, 11:15   #116
Night_Hawk's Avatar
Thanked: 68 Times
The deadline set by Hyderabad Traffic Police for removing tints is 24.10.2012. From 25.10.2012 special drive starts for penalising the violations.
Yesterday I got the tints removed from my Scorpio at Reliance Auto zone. Guys there did a good and neat job. Residual glue which was in small quantum, was thoroughly cleaned off by the guys using liberal sprays of colin and a small squeezee
I had 3M on sides & rear; and Garware ice cool on windsheild. Rs 500/- were the charges for removal and thorough cleaning. It took about one hour forty minutes for two guys to complete the process.
Night_Hawk is offline   Reply With Quote
Old 24th October 2012, 20:35   #117
Desmosedici's Avatar
Thanked: 410 Times
I too removed all my films over the weekend. However the glue is still there. Since i didnt get time that day and the Mumbai RTO being at every nook and corner, i just decided to remove the films for that moment. Will try using the surgical spirit and see if the glue comes off easily. I tried using Pril mixed with water but then i had to use something sharp like a blade to remove the glue so i backed off after removing just a little bit.
Desmosedici is online now   Reply With Quote
Old 24th October 2012, 21:09   #118
ranjitp1's Avatar
Thanked: 1,801 Times
Pril or normal tide with scotch brite will do the work for you easily.There were doubts expressed about scotch brite leaving behind scratches but nothing of that sort happened on my glasses.perfect cleanup and hardly any time
ranjitp1 is offline   (1) Thanks Reply With Quote
Sun Protection, without sun film - Options? tsk1979 Technical Stuff 55 17th December 2015 23:24
Sun Film or Security Film? lambuhere1 Modifications & Accessories 18 21st May 2013 11:57
V-KOOL sun film dealer in Bangalore? manishk13 Modifications & Accessories 3 1st February 2007 13:23
Sun film LandCruiser Technical Stuff 4 6th April 2006 08:55
