Old 5th April 2007, 02:26   #1
Lightbulb Palio Instrument Cluster
Hi all,
Has anyone changed or tried changin the front instrument cluster for the Palio? The green-LED instrument cluster is one of the few annoyances that I face in the Palio. It's very readable .. doesn't hurt the eye at all but it's boring and seems out of place and dated. I much prefer the back-lit cluster a-la Corolla etc. Even simply changing the green LEDs to white would make a world of a difference.
For instance, try imagining the instrument cluster in this -
with white LEDs instead of green.
Do let me know in case anyone has done this on his/her Palio/Adventure. Much appreciated.
etchemkay is offline   Reply With Quote
Old 5th April 2007, 10:42   #2
rishibravo's Avatar
you can change the green LED glow to some other colour like red by simply putting some red transparent caps on the PCB of the instrument panel. As per me I love this instrument panel especially at night so I wont want to change that but i want double din space on the dash very badly
rishibravo is offline   Reply With Quote
Old 5th April 2007, 11:34   #3
esteem_lover's Avatar
Thanked: 386 Times
Cant you change those LEDs to a different colour ?
Old 5th April 2007, 11:50   #4
rishibravo's Avatar
I think you can . Note the specs of the diode and get a different colour in the same spec and remove old ones and solder the new one. putting the desired colour cap on the LED is a cheap solution but it will surely decrease the brightness
Old 5th April 2007, 12:26   #5
zakaaaaasss's Avatar
Check out Ankur's post.....
http://www.team-bhp.com/forum/diy-do...tml#post355437 (Car PC setup, install and some fabrication)
or
http://www.team-bhp.com/forum/355437-post113.html
hez already done it for his Innova
zakaaaaasss is offline   Reply With Quote
Old 5th April 2007, 14:38   #6
Ankur's solution seems simple to do but, my problem is that I want white light .. not colored. So, a change in LEDs is the only option I guess. I'm guessing this will void my warranty, right ? Any electrical engineers in Pune wanna take a shot at this ?
Old 5th April 2007, 17:54   #7
16v100bhp's Avatar
Arrow
I dont think you would be able to do these with colour LEDs. The green shade you see in the panel are not exactly coming out of green LEDs, its actually the result of a green shaded plastic on the instrument panel. The LEDs doesnt exist in palio panels, they are small bulbs in fact and when the light passes through these coloured plastic, gives it gives it a greenish tint on th other side (the viewable side). If you change these to coloued LEDs the coloured light will actually pass through these green shaded plastic to give it an unexpected result
16v100bhp is offline   Reply With Quote
Old 6th April 2007, 03:19   #8
v1p3r's Avatar
Thanked: 9 Times
They're small press-in bulbs. You can try and source the covers for them in different colours, but that will only change your green light to blue/white/yellow/amber/red. We did it for a couple of Balenos. If you want the Corolla type backlit cluster, those are electro-luminescent dials. You'll have to look around on the net for EL dial makers for the Palio.
Old 6th April 2007, 11:57   #9
HAFI's Avatar
i had tried changing the color and wasnt able to do so...because it was not the colour of the LED but the the colour of the film stuck behind the instrument panel..you could notice a green shade even when the lights are switched off..the colour of the LED is just plane yellow..to change the colour you wil have to dimantle the instrument panel and remove the green film and put another colour which ofcourse is a very difficult job...u might would damage it too doing it...
HAFI is offline   Reply With Quote
Old 6th April 2007, 12:48   #10
If it's just the color of the plastic panel covering, then shouldn't it be easy just t replace it with a color-less cover ?
Also, the electro-luminescent dials would be awesome !! But, I'm willing to settle for white light dials too.
Once I'm back to India, I'll be trying to take the instrument cluster apart. Will post progress here.
Old 6th April 2007, 13:17   #11
Just found these - here, here and here, it says that the Palio 1.6 Sports and Palio 1.6 GTX have "Sporty white dials in instrument cluster" (last linky also has a blurry snap). I tried looking for a shot of the GTX's interiors but came up with nada. Could someone post pics of their 1.6 Sport or GTX's instrument cluster - preferably in daylight and night-time ? That would be greatly appreciated.
If this is what I think it is, I'll just have to source an instrument cluster (or at least dial) of a used GTX and I'm done.
Old 6th April 2007, 13:22   #12
Thanked: 9 Times
We can live with green lights but what about electronic trip and odo meters ? Even the new palio hasnt got them.
swathyd is offline   Reply With Quote
Old 6th April 2007, 13:24   #13
moralfibre's Avatar
Thanked: 1,361 Times
You took the words out of my mouth. Fiat should have implemented digital trip and odo meters long long ago!!
Old 6th April 2007, 14:11   #14
rishibravo's Avatar
post nv palio 1.2 ELX and 1.6 sports have white dials exactly what is shown in the beginning of this thread. About the digital odo I too miss it. Even bikes have them these days.
Odometer / Instrument Cluster Repair? Palio_2005 Technical Stuff 19 17th September 2012 10:38
Is it possible to change the instrument cluster display? passion4cars Modifications & Accessories 41 15th March 2009 22:54
White instrument cluster on a baleno w/pics! binz Modifications & Accessories 53 15th March 2009 21:43
Used Parts (Instrument cluster- dials) ..? gary_yuen42 Modifications & Accessories 37 15th February 2006 22:58
Instrument cluster light change nikibusa Motorbikes 7 10th September 2005 09:26
