Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 6th April 2007, 13:02   #16 (permalink)
nitroxx's Avatar
Infractions: 0/1 (5)
chetan,I think somewhere..on the other side of the planet you've flapped your wings,thats created a butterfly effect....so much for the tuners in india,goin on about hp increase by plugs and wires...keep up the good work!
__________________
"Aerodynamics is for those who cannot manufacture good engines"
- Enzo Ferrari
nitroxx is offline   Reply With Quote
Old 6th April 2007, 13:17   #17 (permalink)
Team-BHP Moderator
ported_head's Avatar
Originally Posted by ananthkamath View Post
can you post the link or something.
Here is a link showing comparisons for some D series engine headers, they have dyno charts for some of the headers. Some make 10 whp peak. Of course dynos can be manipulated...
D-Series Header Comparison
ported_head is offline   Reply With Quote
Old 6th April 2007, 13:28   #18 (permalink)
rdkarthik's Avatar
Temperature signal modifiers - They cannot give 15% to 20% bhp gains. They do make a small difference, but not in significant percentile gains.
Map sensor signals modifiers - They can better part throttle peformance, but again cannot give 15% to 25%
ECUs- Tuned for the specific engine, gains can vary from 5%(stock engine) to more than 30% (fully worked on, with all mods).
rdkarthik is offline   Reply With Quote
Old 6th April 2007, 14:03   #19 (permalink)
chetanhanda's Avatar
Infractions: 0/1 (4)
3] Air filter/CAI
this may help but depending upon how u have installed it and if u have installed it correctly are you really making use of the extra air with a stock engine.. ?
most common setup done is
(a) removal of stock air box
(b)removal of the stock pipe and repalcing by a metal tube(this metal tube is not considered so important by 99% of people, its the colorful conical filter which gets the most attaraction)
(c) attach the conical filter at the tip
as a result the filter ends up located somewhere near the position where the stock air box was ..
guess whats wrong ?
(a) u are sucking in hotter air from the engine bay.
(b) as seen in some engine bays there is lack of space so the tube from the air filter to the Throttle body is routed above the engine block or very clsoe to it without any heat sheilding/wraps..
so u r further increasing the air temp.
(c) rerouting the air intake to the oustside box but with a very convulated piping also will not be that useful as we need to make sure the air flow is straight..with minimum twists..
also the pipe should not have kinks in it , the hi end systems come with mandrel bent pipes to make sure the flow of air is smooth as possible.. but do the budget ones have these kind of smooth flowing pipes
extreme cases MAF sensor to be upgraded to handle extra flow of air but thats in extreme cases...
in many setups the stock pipe and air box provide more heat sheilding and insulation than these CAI setups
Ok even if this setup is done right by rerouting to some where below the front bumper or front tyre then .. what next ?are u really
going to make much BHP ? say max 1 or 2 BHP.. dont think its going to make more than that in any stock indian engine... which is detuned for 84 octane and bad fuel..
hey but the intake growl is worth the install but at expense of what ? make sure ur not sucking in hot air from a convulated pipe snaking around in ur engine bay and may be make 1-2 bhp on ur stock engine which can be negligble.. but plz dude dont expect more..
chetanhanda is offline   Reply With Quote
Old 6th April 2007, 15:03   #20 (permalink)
Team-BHP Moderator
Is this what the Tri-Phase module does? Maybe you guys and Viper can explain better. Thats what I could make out from the excerpt given on the website:
3: Tri-Phase Performance Module
To quote:" In short, when the engine compartment heats up, some sensors that relay pertinent fuel curve contingent information to the ECU begin to lose accuracy due to heat absorption into the sensor. The ECU then reads these incorrect signals, and leans out, or otherwise incorrectly alters the fuel curve, which hampers performance. These errors cannot be corrected from within the computer, there must be an independant unit to correct these errors. The Tri-Phase is designed to automatically compensate for these signal errors."
Maybe it connects to more than one sensor. Hence makes bigger difference. If Viper could tell us what all sensors it hooks upto and modifies their signals.
I could be wrong, I'd just like to know.
Old 6th April 2007, 15:04   #21 (permalink)
gigy's Avatar
Finally things are straightening up , i can say. At many times my points were ignored about actual performance increase. i think this thread will bring all facts together in one place and help all Tbhpns to actually gain some performance.
__________________
Baleno1.6,Carputer:AMD Athlon 3000+,2gbram,80gb HD,centerfuse FE,satguide gps.
Old 6th April 2007, 16:06   #22 (permalink)
mclaren1885's Avatar
I guess the mods can make this a STICKY and move it to the BEST THREADS ??
Chetan , even worse case is most of them get these HUMONGOUS conical air filters though there is no use specially when a smaller one could suffice .. I have seen some really bad installs most of them on swifts (including a few TCed ones) .. More than improving performance the engine sucks in hot air and hampers whatever gain one is expecting ..
__________________
The gas she exhales is meeting a new friend!!!
Old 6th April 2007, 22:29   #23 (permalink)
Sir,
I'm sorry, but you are misleading TBHP users on several points, this one, I must address. You may indeed be correct regarding percentage gains, though no one that is serious about dyno testing, or selling a product, should be quoting in percentage gains. For example, a 5% bolt-on gain on a Nissan 350Z is nearly impossible for a single mod. 5% of 306 hp is over 15 hp, and just not going to happen. Why? Because the car is tuned fairly aggressively from Nissan. The exhaust is free flowing, the ECU tuning is aggressive, the intake is efficient, etc. Yet, some companies are quoting gains in terms of 15, 20, 25%, and even more.
Onto the products you mentioned above...both Temp and MAP piggybacks have the potential to increase power gains in the 15-20 hp range, sometimes a bit more, depending on the vehicle. Is that typical? No. Most gains are in the 8-14 hp range, but making it seem like both are rather ineffective is not correct. It is true that reprogramming your ECU is going to give you the most flexibility, and like a slightly higher gain...you have a lot more to work with, but you also have a higher price (generally). You also have a mod that is permanent. You can't turn it off, and you can't unplug it. Pros and cons to both...the right application depends on the person who is doing the mod, and what their needs are. An ECU flash should yield a higher gain than a piggyback module, and a full set of underdrive pulleys should yield a higher gain than just a crank pulley...but the higher power gain is not always the correct choice for a particular person, and shouldn't be considered the default choice.
A good rule of thumb -> anything that seems to good to be true, usually is.
You can "fluff" the issue anyway you like it. The goal, regarding ECU tuning, is changing the air/fuel ratio, and the appropriate timing adjustments to compensate. You can use any flashy terms that you want, but that's the goal. With a piggyback unit, you have to keep the oxygen content in the exhaust, post mod, within a range that is acceptable by your o2 sensors, or else you will get a check engine light, and in a late model car, the gains will begin being tuned out by the ECU, to bring the exhaust oxygen content back to an acceptable level (this is where MAP piggybacks usually fail - the MAP signal has such a profound input on the a/f ratio, the fuel mix becomes too rich, and is tuned out after a few hours of driving). Same goal with reprogramming the ECU, the only difference is that you can alter what the "acceptable range" of exhaust oxygen content is within the ECU...this "cheat" isn't unlimited...the range programmed by the automaker is for emissions - you are still limited by what is physically effiicient (i.e. going further than 13:1 on a naturally aspirated car is just going to lower your fuel economy, cause a knock, make the exhaust black, and cause power gains to being to fall off, since the car can't combust the fuel thoroughly). Now, if you want to kill your rev limiter or speed limiter, reprogramming the ECU may be the way to go - don't push the car more than a few hundred RPM over the factory rev limiter, and going past the speed limiter is just unwise - but if thats your goal, that's your call.
Sorry for being wordy, just had to dispel this myth. It doesn't matter how you do it, just so that you stay within a) the tolerance of the o2 sensor, and b) the limits of physics - Temp, MAP, and ECU Flash all have the potential to do it.
And here's another -> someone made the comment about a car working as a "system" - good advice. The better a car breathes, the better off you will be in your modding endeavors. Start with intake and exhaust, then go with something to bring your a/f ratio back inline (it will most likely be running lean after those mods), either a piggyback Temp or MAP module, or an ECU flash, whichever fits your goal and your budget. Then go from there. If you want to go further, underdrive pulleys are usually a good buy. If your budget is in the $3,000+ (USD) range, you might as well go forced induction - just keep the boost reasonable to prevent engine damage, unless you have a serious budget, and are going to build your engine first.
Spark plugs, plug wires, grounding kits -> mostly creating imaginary gains. Yes, they do provide some benefit, but in terms of whp, they are quite small.
nextlevel350z is offline   Reply With Quote
Old 6th April 2007, 22:33   #24 (permalink)
Team-BHP Moderator
Ok, so what all sensors does the Tri-Phase modify the signals from?
In the meanwhile, here is a good read on performance cables.
http://asia.vtec.net/beystock/tuning/plugcable.html
Old 6th April 2007, 22:58   #25 (permalink)
ok..
lets go through each chart one by one ..and lets assume the Dyno is not manipulated for this..
1] (a)the 1st dyno chart is with a D16 engine which makes 130 BHP in its stock form with no mods none of our Indian Honda's are D16 and make 130 BHP in stock form.
(b) secondly the D16 on the Dyno is not stock, it is running bismoto cam and valvetrain,11:1 CR and RS head
(c) the fuel quality is much better in US and the ECU's are tuned for more power as compared to Indian ECUs
considering point (a) (b) and (c) if they make 6 WHP , it is feasible.
but is it feasible on a stock Indian Honda engine I dont think 10 WHP is possible..
2]
(a)The second dyno chart shows a D16 and to reiterate its more powerful in stock form than our Indian stock Honda
(b)To add to this, the D16 in consideration is not even stock it is a "Bisimoto hi compression prototype"
this "prototype hi compression D16" can make 10 WHP with those headers , but will a stock Indian Honda with normal compression also make 10 WHP is doubtful
3]
(a) The 3rd dyno chart is showing a D16Z6 which again in stock form already makes more power than our Indian Honda in stock form
(b) Its a 1600 cc engine tuned with ECU for octane in US
Its basically a bigger engine running better fuel and making more BHP so it will make more gains with a header as compared to the Indian 1500 cc engine with a ECU detuned for low octane/bad fuel making only 106 BHP ..
consider (a) and (b), do u think we can get 10 BHP with same race header bolted to our Indian Honda.. ?
I think all 3 dyno charts in the link are covererd.
guys what u think ? can we directly relate to those dyno readouts to ur stock Honda engines ? also dyno charts of same engine with JDM or USDM ECU cannot be same for our Indian ECU..
Old 6th April 2007, 23:07   #26 (permalink)
Awesome Dude !!
this is what I was trying to say all along ..
plug wires = nice looking under the hood but dont make 3+ BHP in a stock engine...unless ur original cables are borrowed from a rusted car lying in the bottom of the ocean for the past 100 yrs...
yeah...right !!
conical filter big enough to feed twin turboes in a drag spec skyline connected to a small dia tube made of tin with kinks ...
Last edited by ported_head : 7th April 2007 at 00:16. Reason: Please use edit function when posting within 20 minutes.
Old 7th April 2007, 01:07   #27 (permalink)
V-16's Avatar
This is great. I Have been not posting in "certain" Threads for want of words to say to self professed "mod dudes" I am so glad that a sensibly educating thread has been started. Keep it up guys but dont get pompous about it.
__________________
WWHHOOOOOOOSSSHH---PSSSHHCCH---WWHHOOOOOOSSSHH----PPSSSHHCCH---WWHHOOOOSSSSHH---!!!!
V-16 is offline   Reply With Quote
Old 7th April 2007, 01:41   #28 (permalink)
Team-BHP Moderator
Sirji, the intentions are good. We just need help from the Pros on this topic, all of whom have been surprisingly silent, barring a few.
Old 7th April 2007, 02:05   #29 (permalink)
Thumbs up
sure dude !! we will take care..
PM if u think the tone is not right ..
Old 7th April 2007, 02:26   #30 (permalink)
v1p3r's Avatar
JDM D15B engines, the same as our Indian Vtecs, with a different intake manifold and ECM, and some slight construction differences, put out 134 bhp.
__________________
Peace is a lie, there is only passion.
v1p3r is online now   Reply With Quote
Thread Tools
Any good resorts in "Karwar" & "Goa" lohithrao Route / Travel Queries 7 31st October 2007 14:10
Looking for info on good "Resorts" or "Home stays" in Madikeri lohithrao Route / Travel Queries 2 14th September 2007 11:28
Audi RS5 "M3 beater?" to be launched early next year "PICS" highwayblaze The International Automotive Scene 9 18th May 2007 01:59
The 180 bhp Smart a.k.a "The Smaruki" Steeroid The International Automotive Scene 3 3rd December 2005 12:53
Team-BHP "Tagline" Rehaan A Collection of the best threads 57 21st December 2004 13:08
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
