Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 10th April 2007, 01:07   #76 (permalink)
v1p3r's Avatar
With a TB spacer, you will get some swirl into your charge mixture IF the spacer is placed AFTER the fuel and air is mixed. So the thing is slightly effective for TBI and carbed cars. For an MPFI car, it just pushes the airfilter an inch or so further away from the intake valves.
__________________
Peace is a lie, there is only passion.
Old 10th April 2007, 01:53   #77 (permalink)
The Wolf's Avatar
V1p3r, there are throttly body spacers that dont have the grooves at all! The grooves thingie is just a value add to the product... The main idea of a tb spacer is to increase the cc of plenum chamber...bigger the plenum chamber, lesser the charge required to suck maximum air in due to pre available air in the chamber...resulting in what?? well, more torque at higher rpms but marginal drop at low rpm!
The one which has grooves as you mentioned would function best if placed after the runners/carb as it slows down the velocity of air giving the fuel more time to mix(atomize) before entering the combustion chamber...
p.s: OE plenum chamber is designed(cc calculation) to support maximum air flow throughout the rpm band. Custom ones enhance one range on the rpm band at the cost of another one.
__________________
I cried coz I had no turbo, till I met a man who had no VTEC!!!
The Wolf is offline   Reply With Quote
Old 10th April 2007, 03:33   #78 (permalink)
chetanhanda's Avatar
Thumbs up
exactly and some of these are so thin that they would hardly increase the cc at all...or even create a swirl effect
yes, exactly and again it would be doubtful if these spacers are going to help as the intake runner length of a stock engine would be optimised for that engine for that particular intake valve timing for that cam..
yes , and possibly these spacers being of the generic type may even not be suited to the type of cams or header design the engine is being tuned with, they could be in some cases going against the other mods done..
chetanhanda is offline   Reply With Quote
Old 10th April 2007, 03:41   #79 (permalink)
Thumbs up
yep..right.. somewhere downstream in the runner after the injector... but who knows ..there may be better ways to acheive the same.. like playing with injector spray pattern, runner design which may have already been taken care of by the manufcturer or the aftermarket intake plenum designer..
e.g. a aftermarket Skunk intake on a Honda may have been already so well designed that a spacer in the runner would be most unecessary...
I would call TB spacers as the most useless concept in a MPFI system upsteram or downstream of the injector in the runner...
Old 10th April 2007, 05:13   #80 (permalink)
Originally Posted by ported_head View Post
Does the output voltage of the IAT sensor rise as temperature goes up?
the lower the temperature, the higher the resistance.so higher the resistance lower the voltage ..I think its what u call a "thermistor"
Old 10th April 2007, 05:37   #81 (permalink)
ananthkamath's Avatar
I think they're pretty handy if you want to inject nitrous into the engine.
__________________
Miata Turbo Is GO!!
ananthkamath is offline   Reply With Quote
Old 10th April 2007, 06:29   #82 (permalink)
I would call TB spacers as the most useless concept in a MPFI system upstream or downstream of the injector in the runner...
then even sparkplugs, plug wires are very handy if you are using NOS becoz an engine capable of using NOS will definately benefit from these..
so whatever we have discussed in the last few post makes no sense.
so that means plug wires and sparkplugs are pretty usefull to mantain a 100 shot of NOS ..
dont you think this is in wrong context ?
Old 10th April 2007, 06:39   #83 (permalink)
again they maybe handy only in case of "wet" or "direct port" type of Nitrous delivery but not in a "Dry" system as we are spraying NOS upstream of the injector on/near the MAP...
a dry delivery system has to be upstream of injector to influence te MAP sensor so it wont be useful here..
Old 10th April 2007, 09:35   #84 (permalink)
i meant to say that a TB spacer will be useful not as a power adder, but as a means of actually fitting the nitrous line to the engine. meaning you drill a hole in the periphery of the TB spacer and attach the nitrous line there, much like a plate system. this was an oblique reference made to nitrous in a sarcastic manner, thats it.
dry, wet it doesnt matter. you still need to inject the nitrous somewhere, and the neatest way to do it is through a plate (or like i meant, a tb spacer) fitted to the plenum. an inelegant way is to pierce the rubber tube from the airbox.
__________________
Miata Turbo Is GO!!
Old 10th April 2007, 09:46   #85 (permalink)
Wink
got it late.. I have some turbo lag...
dry, wet it doesnt matter. you still need to inject the nitrous somewhere, and the neatest way to do it is through a plate (or like i meant, a tb spacer) fitted to the throttle body. an inelegant way is to pierce the rubber tube from the airbox.
direct port into intake after TB , wet shot sprayed ahead of TB..
Old 10th April 2007, 10:03   #86 (permalink)
WhiteKnight's Avatar
Well, depends on the coefficient of resistance being +ve or -ve. I presume you are refering to a -ve thermister?
__________________
"When the going gets TOUGH.....Great ones PARTY"
WhiteKnight is offline   Reply With Quote
Old 10th April 2007, 18:29   #87 (permalink)
v1p3r's Avatar
Best way of spraying nitrous is to not, and use a turbo instead.
__________________
Old 10th April 2007, 18:44   #88 (permalink)
rdkarthik's Avatar
Hotter the stuff, lower is the resistance...... If you want to play with IATs, do it with the resistance, dont worry abt voltages.
rdkarthik is offline   Reply With Quote
Old 10th April 2007, 19:40   #89 (permalink)
gigy's Avatar
what are all of you trying to do with changing resistance of sensors? when the air temperature is high it is the sensor responsibility to inform the ECU and it adjust the fuel accordingly.
so if you force ECU to think the engine is being fed cold air, are you expecting increase in power. Tecnically it is not possible. only when the correct input data is given the ECU, it can produces power as per throttle position.
if you need more power increase mass air flow( turbo), try for colder air (CAI) intake and fuel , allow faster exhaust exit within the power band possible from engine. rest all theory is pure ****.
there is one basic rule for everything, energy can neither be created nor destroyed. so there has to be more input for more output...... how much you can drag this is based on limits of the engine physical size and related things.
__________________
Suzuki Baleno
gigy is online now   Reply With Quote
Old 10th April 2007, 20:16   #90 (permalink)
or both if you are psychotic enough.
this thing of using a resistor. in parallel with the sensor. I am assuming it has been tried and is a cheap remedy to get rid of a lean condition? Someone please comment on this.
how about discussing a "sequence" of mods one can follow if one has a stock engine and would, theoretically atleast, provide the best bang-for-the-buck?
my take on this is:
Stage 1) Open filter/CAI etc. with rejetting for carburetted engines and no changes for FI engines
Stage 2) Full exhaust system from cylinder head flange onwards (not just freeflowing muffler) along with rejetting/remapping/piggyback
Stage 3) Synthetic oil if it isnt already recommended by manufacturer
Stage 4) Internal modifications like cams, head work etc.
This is for a street engine. If I were to be building a race engine, I would take a "systems approach", meaning that I would start with internal mods first (cams, head work, CR) then match the exhaust and intake system with those components.
__________________
Miata Turbo Is GO!!
Thread Tools
Any good resorts in "Karwar" & "Goa" lohithrao Route / Travel Queries 7 31st October 2007 14:10
Looking for info on good "Resorts" or "Home stays" in Madikeri lohithrao Route / Travel Queries 2 14th September 2007 11:28
Audi RS5 "M3 beater?" to be launched early next year "PICS" highwayblaze The International Automotive Scene 9 18th May 2007 01:59
The 180 bhp Smart a.k.a "The Smaruki" Steeroid The International Automotive Scene 3 3rd December 2005 12:53
Team-BHP "Tagline" Rehaan A Collection of the best threads 57 21st December 2004 13:08
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
