Old 24th April 2014, 11:00   #346
neel911's Avatar
Thanked: 203 Times
Default Re: Tyre pressure gauge and portable inflator pump / foot pump
Did you kept the engine running while starting the compressor? It is always advisable to first start the engine and then use power hungry devices. That minimizes the load on the electricals.
If the fuse still blows, then you may need something that connects to the battery directly, but then it will be little inconvenient, as you yourself know.
I've got this more than a month back: http://emporis.co.in/html/products_c...compressor.htm
Name:  Screen Shot 20140424 at 10.55.38 am.png
It works perfectly fine. I do see error of about 1-2 psi on the analog gauge after using it for more than a month.
Here, the manufacturer/supplier clearly mentioned that there is no need for the engine to be on/running when using the compressor.
When I keep engine on/running, I see that compressor makes louder noise and also fills up air a bit faster but I'm not sure if this would damage compressor.
Off topic but see this post: http://www.team-bhp.com/forum/modifi...ml#post3420054 (Car Vacuum Cleaner)
Here, the vacuum cleaner manufacturer recommends NOT to use the device when engine is running/on as it'll decrease the life of the same.
neel911 is offline   (1) Thanks Reply With Quote
Old 25th May 2014, 11:14   #347
sabsubs's Avatar
Thanked: 40 Times
Attachment 1233842
Could you please let me know from where did you purchase? Are there any dealers in Bangalore?
sabsubs is offline   Reply With Quote
Old 29th May 2014, 12:07   #348
neel911's Avatar
Thanked: 203 Times
Just check contact info on website mentioned on my post. You need to transfer amount to his bank account and he would ship from Pune. Once payment was received, I got the pump in about 3 days.
neel911 is offline   Reply With Quote
Old 29th May 2014, 12:25   #349
dass's Avatar
Thanked: 434 Times
A Noob question on the tyre guage and pardon my ignorance.
When you just check the tyre pressure through the gauge, isnt some air leaked out when the pin is suppressed? Though the reading is shown, the tyre logically is losing air every time the pressure is checked. What am I missing here?
dass is offline   Reply With Quote
Old 29th May 2014, 12:34   #350
neel911's Avatar
Thanked: 203 Times
The pressure loss is very minimal assuming you are able to seal it fast. There are times when seal takes 2-3 seconds which can leak more air.
I've got the following and the seal is amazing http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Every 2 weeks, I just check using the above gauge and if air is less, I just fill it a bit over recommended value (by about 2 psi) and then use the above gauge to measure and deflate excess air. It is very accurate.
neel911 is offline   (2) Thanks Reply With Quote
Old 29th May 2014, 14:02   #351
Red Liner's Avatar
Thanked: 1,171 Times
I am toying between the Emporis and the Coido: http://www.amazon.in/Coido-Tire-INfa...air+compressor
Which one do you guys recommend?
And I would like to get a solid, reliable tyre pressure gauge which allows me to check pressure without losing air on contact. Reccos?
Red Liner is offline   Reply With Quote
Old 29th May 2014, 14:29   #352
ank.nsit's Avatar
Thanked: 159 Times
I have been using Coido compressor with Analogue pressure gauge for around an year now, & the gauge is not accurate. So, I have bought a digital pressure gauge, for quickly measuring the pressure w/o any loss of air.
The compressor though is solid & reliable and does the job of filling up the air pretty well but a little slowly.
There is a lock on the nozzle which prevents air loss. But during the time the nozzle lock is opened/closed the air is definitely lost.
ank.nsit is offline   (1) Thanks Reply With Quote
Old 29th May 2014, 14:32   #353
Red Liner's Avatar
Lots of hits and misses online (read good and bad reviews) on the Coido pumps...hence the concern.
Old 18th June 2014, 09:01   #354
Thanked: 163 Times
Question: which one did you go for? I am planning to buy one. Grateful if you could let know which one did you pick eventually.
Traveller Nayak is offline   Reply With Quote
Old 18th June 2014, 09:08   #355
Red Liner's Avatar
Haven't figured it out yet, the ones available locally are just not worth the dough.
Old 18th June 2014, 09:16   #356
Thanked: 163 Times
Thanks for getting back quickly. I have a Leh trip planned end of August. Most likely will go with Emporis. For whatever it is worth, I am hoping it should do for the 15 days I need the most!
Old 18th June 2014, 12:20   #357
neel911's Avatar
Thanked: 203 Times
I would also recommend Emporis over Coido. Somehow I feel the build quality is better and being a local company, it'll be easier to get parts as well. The analog digital gauge will lose accuracy over time and I highly recommend getting a separate gauge. Do invest well in the pressure gauge. I sourced it from U.S. after looking at all the reviews.
I really do not trust the pumps at the petrol pumps and I'm glad I invested here which will help my tyres stay in good shape.
There is one more thing which I recently purchased and so far I'm very happy with it as well. It gives me a quick indication if the pressure is good enough. I'm not sure if the reliability but will monitor it closely
http://www.ebay.in/itm/4x-Brass-Car-...e825934&_uhb=1
Old 18th June 2014, 12:53   #358
Red Liner's Avatar
This looks very interesting! Could you post some real pictures of the product up close and when fixed on your car please?
600 bucks, if it does its job - its a no brainer. Plus the locking mechanism. How does that work?
Old 18th June 2014, 20:22   #359
Thanked: 97 Times
I wanted to buy these as well, but was worried if they would weaken the valves in the long run as they would be continuously pressing on the valves to keep them open to monitor the pressure.
I was also a little worried about these getting stolen!
For monitoring, I have a accutire digital tire pressure gauge which I got it from the US: Amazon link
It is accurate and works pretty well on my alto, but it lets out a lot of air when used on my bike (Honda Unicorn).
A good suggestion that I found on another forum is to overfill by around 3-5psi when checking the pressure at the neighborhood fuel station and then come home and use your pressure gauge to adjust the pressure to the intended values after the tires cool down.
I follow this after finding out that even the gauges at shell and other reputed pumps are way out of line most of the time.
SR71-Blackbird is offline   Reply With Quote
Old 15th July 2014, 13:37   #360
Thanked: 163 Times
After lot of reading and exchanging emails with Emporis, I confess I am still unable to take a decision on which one to go for. Confusion has arisen because Emporis is 150 psi and Coido is 300 psi.
Recently, I was travelling on office work in an Innova and during small talk with the driver, the discussion veered off to air compressors. The driver was carrying a Coido. He said he has it for 2 years and he is happy with it. The specs which I have got from Emporis are as below:
1. Operating Voltage: 12 Volt DC
2. Maximum Air Pressure: 150 PSI
3. Maximum Current: 8 Amp
4. Air Flow: 27 ltr/min
5. Weight: 1.5 kg
6. Power Cable Length: 3 mtr.
7. Car Tyre Inflation Duration: 2.5 to 3 mins
8. Usage Temperature: -20 to +80 c
Warranty: 3 months against any manufacturing defect.
Coido:
http://www.ebay.in/itm/Coido-3326-12...-/260954569129
Does 150 psi vs 300 psi make a difference? I have a Fortuner.
Issue: Driver's foot (Accelerator foot) over a long drive joybhowmik Street Experiences 57 20th November 2017 13:13
Review: Coido 6222 12v Tyre Pressure Pump & Gauge abhi182 Modifications & Accessories 5 10th July 2014 17:10
Tyre pressure gauge vina Tyre & Alloy wheel Section 1 16th June 2011 02:25
Digital/Analogue Tyre Pressure Gauge - Which one to buy ? mithun Tyre & Alloy wheel Section 15 19th February 2009 14:47
