Old 15th October 2014, 19:17   #406
supremeBaleno's Avatar
Thanked: 1,648 Times
Default Re: Tyre pressure gauge and portable inflator pump / foot pump
Originally Posted by rk_sans
Picked a Campbell Hausfeld Inflator from Amazon. Works very efficiently, has a inbuilt cut off when the desired PSI is reached. Paid around $22.Attachment 884772
I can vouch for this one. Have been using the same one for 10+ years now without any issue at all. Got it as a ServiceAnniversary gift from my organisation and am glad I chose it fromthe gift-catalogue.
Old 24th November 2014, 15:49   #407
Thanked: 129 Times
Originally Posted by dass View Post
Has anyone tried using this one?How accurate is this?
http://www.ebay.in/itm/Origenal-New-...item27e8c6904d
I got the exact same one, but from a different buyer and had the same question, how accurate are these? I tested the pressure a week after I filled nitrogen from one of the pumps, and all of them were showing on an average 2PSI less than the desired level. How do I verify the accuracy of these products?
ILTDrive is offline   Reply With Quote
Old 19th December 2014, 00:21   #408
Is anyone using this motocop model? I am looking for one, for my Duster.
http://www.snapdeal.com/product/moto...4#ReviewHeader
This has an auto cut-off feature which I have not seen with most of the other models, but not sure if the price of 2.6k is justified.
Swift is offline   Reply With Quote
Old 19th December 2014, 08:16   #409
zenren's Avatar
Thanked: 1,724 Times
I'm thinking of purchasing a portable tyre inflator for my bike. Any feedback on any of the Coido 12V inflators? I see different models too, though I've no idea as to why something is double the price of another model.
http://www.ebay.in/itm/100-Original-...item462f20bd87
http://www.ebay.in/itm/Electric-Car-...item3ceedf5f43
http://www.ebay.in/itm/Coido-12V-Ele...item2598948b95
Read a review on Amazon that the car charger has to be 15A to use this. Id the charger port in Maruti/Swift 10A or 15A?
zenren is offline   (1) Thanks Reply With Quote
Old 25th December 2014, 17:58   #410
mithun's Avatar
Thanked: 49 Times
Originally Posted by Simhi View Post
Finally took the plunge and bought an tire pressure gauge to start off with. This week the petrol pump guy was trying to convince me that the pressure is fine even though I did not hear the beep when air was filled.
So bought a COIDO #6705 tire pressure gauge from snapdeal. Tested all tires of scooter and car and as I suspected one of the tire was having less air pressure.
Not sure how accurate the device is but plan to use it regularly.
Not able to decide whether to buy tire pressure pump, though I short-listed LIMI portable from http://www.emporis.co.in/ based on reviews and feedback from members.
Attachment 1299299
Attachment 1299300
Have you compared it to other gauges ? I bought the same piece and it's showing 2 PSI lesser than my old one. Maybe the old one is faulty, not sure thorough :-)
Old 25th December 2014, 18:12   #411
Thanked: 372 Times
No I have not compared it with other gauges. But, yes it shows reading which is almost same as that is shown at the petrol pump air filling station.
Simhi is offline   (1) Thanks Reply With Quote
Old 10th January 2015, 09:17   #412
moralfibre's Avatar
Thanked: 6,222 Times
Picked up this very compact and useful tyre inflator and digital tyre pressure gauge from Sears. Thankfully had a relative coming down from the states.
Tyre pressure gauge and portable inflator pump / foot pump-img_7586.jpg
Tyre pressure gauge and portable inflator pump / foot pump-img_7587.jpg
Tyre pressure gauge and portable inflator pump / foot pump-img_7588.jpg
moralfibre is offline   (2) Thanks Reply With Quote
Old 10th January 2015, 11:10   #413
zenren's Avatar
How is the performance of the inflator? How long does it take to fill a tyre? How much did each item cost?
zenren is offline   Reply With Quote
Old 10th January 2015, 11:28   #414
theredliner's Avatar
Thanked: 859 Times
I bought these two for my bike
1. Coido twin cylinder foot pump - 800/-
2. Coido digital gauge with torch - 550/-
Used foot pump on my bike's tyre. With 25 pumps, it took the 90/90-17 front tyre from 23 PSI to 33 PSI. So, it's pretty effective on skinny tyres found on the puny bikes. Will be very helpful for motorcycle tourers.
theredliner is offline   (1) Thanks Reply With Quote
Old 10th January 2015, 15:36   #415
RSR
RSR's Avatar
Thanked: 4,542 Times
Coido is a Taiwanese company that makes good quality products and you won't go wrong with them (but beware of cheap Chinese fakes!) I have one and it works flawlessly. I believe the different models have different inflation capacities and some have some additional features like warning lights etc.
I'm not sure of the 15A requirement. It may be for some of their larger capacity models. The one I have has worked very well on cars like the Indica, i10 etc. which I believe have 10A power outlets.
RSR is offline   (2) Thanks Reply With Quote
Old 1st February 2015, 22:45   #416
S_U_N's Avatar
Thanked: 381 Times
I have lost the attachment that came with my 'Coido like' air compressor for inflating cycle tyres. I think it was a green plastic attachment.
Does anyone know where I can get that?
Secondly, Is there any air compressor that runs on 220Volts? I would prefer to fill up air in all my vehicles through that instead of using the car battery since my cars do not run frequently.
S_U_N is offline   Reply With Quote
Old 12th February 2015, 16:45   #417
Thanked: 13,390 Times
What: Need a 12V tyre inflator.
Budget: Rs 1000 maximum.
Usage: For regular top-up's and in case of emergency and I do have a bike + cycle at home so will be helpful for them too.
What I Found:
Manufacturer: Coido
Model: 3326
Specifications:
Max Output: 300 psi (Read out on the pressure gauge)
Input Voltage: 12V
Power Cord Length: 3 meters
Inflator cord length: 1 meter
A flasher and a light too provided for night time help
A ON/OFF switch for the compressor.
Verdict: Does its job without any great drama. I recommend this if it is mainly used for top-up's as the time taken would be long to fill in air from a flat.
Last but not the least, do buy a set of ear plugs too. Makes hell a lot of racket!
CAUTION: Keep the cars engine running during usage of the inflator to preserve the car battery.
Updates from my end in due course of time: Shall see how long it takes to fill to 32 psi on a flat tyre. Not going to rely on the pressure gauge given on this unit though. Have bought a separate pressure gauge already.
A few pictures to do the rest talking:
Inflator:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161122vert.jpg
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161248.jpg
Pressure Gauge:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161300.jpg
Control Switches:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161311.jpg
Light:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161321.jpg
Storage compartment:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161419.jpg
Inflator cord:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161503.jpg
Power Cord:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161527.jpg
Pressure Gauge:
Tyre pressure gauge and portable inflator pump / foot pump-20140117_185421.jpg
Owners Manual:
Tyre pressure gauge and portable inflator pump / foot pump-20150212_161211.jpg
a4anurag is offline   (2) Thanks Reply With Quote
Old 12th February 2015, 17:48   #418
Does it say in the manual that the engine needs to be running ? I have two inflators (one is Slime and the other is Campbell-Hausfield) that I have been using for 10+ years now to top up air in our cars and I have never used them with engine running. Just turn the key to the Acc setting - that's it.
P.S.: Unless maybe if you have to fill up all 5 tyres from empty, which is not a very possible scenario.
Old 12th February 2015, 17:53   #419
If the top-up isn't long then ACC mode will do it but incase of a flat then yes.
I should have put it as PRE-CAUTION rather than CAUTION.
Old 12th February 2015, 18:59   #420
Thanked: 31 Times
I have a similar inflator pump.
Other than being noisy, the only other issue I have faced is that relay inside the body of the pump detached itself loose due to vibration.
I had to open it up twice to fix it - first with a double sided tape and finally with an adhesive.
Thanks.
vaasu is offline   Reply With Quote
Issue: Driver's foot (Accelerator foot) over a long drive joybhowmik Street Experiences 57 20th November 2017 13:13
Review: Coido 6222 12v Tyre Pressure Pump & Gauge abhi182 Modifications & Accessories 5 10th July 2014 17:10
Tyre pressure gauge vina Tyre & Alloy wheel Section 1 16th June 2011 02:25
Digital/Analogue Tyre Pressure Gauge - Which one to buy ? mithun Tyre & Alloy wheel Section 15 19th February 2009 14:47
