Old 16th April 2007, 15:43   #1
neo_trace's Avatar
Thanked: 38 Times
Default Rear wheel drive honda CRV
hi
friend of mine has 2005 honda CRv ..thats come with real time 4wd
he want to know that removing front axels can make CRV only rear wheel drive or not?
bye
neo_trace is offline   Reply With Quote
Old 16th April 2007, 15:57   #2
Rtech's Avatar
Thanked: 221 Times
NO!! For heavens sake, please tell him not to even think of something like this!
Old 16th April 2007, 19:59   #3
EVO6's Avatar
Whats the reason for him wanting to do so.. If there are any sensors on the axle and tyres the ABS and Traction control ( if available ) will have..
And ppl die to have 4wd.. Please let the drivetrain be as it is....
EVO6 is offline   Reply With Quote
Old 16th April 2007, 21:58   #4
jesal's Avatar
since when does crv come in awd option....
jesal is offline   Reply With Quote
Old 16th April 2007, 23:17   #5
Stratos's Avatar
Thanked: 1,217 Times
I suppose it always came with AWD option in india.
Stratos is offline   Reply With Quote
Old 17th April 2007, 01:24   #6
Shan2nu's Avatar
Thanked: 89 Times
The CR-V has always been an AWD since it's launch in India. Except that the AWD system activates only when the car senses loss of traction on the front tyres.
Shan2nu
Old 17th April 2007, 03:05   #7
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by neo_trace View Post
hi
bye
Just removing the front axles will not do the job. You have the also lock the front diff and also lock the viscous coupling (somehow)
After you manage to do this some thing to keep in mind.
The rear axle to start with is not designed to take 100% torque which means it might snap if you launch it really hard and 2ndly not designed for full time operation (low duty cycle since its part time 4wd) which means it will wear out quickly. Have you seen the rear halfshafts, skinnly as hell. Good Luck though.
Front Wheel Drive v/s Rear Wheel Drive Revvhead Technical Stuff 269 3rd August 2017 15:48
From a 4 Wheel drive to a rear wheel drive. My Contessa kittigadu Test-Drives & Initial Ownership Reports 16 7th November 2011 14:28
How do front wheel drives and Rear wheel drives behave in a skid adrian Technical Stuff 10 29th June 2011 17:51
Front wheel drive Vs Rear wheel drive ivar1951 The Indian Car Scene 2 17th March 2010 15:08
Rear wheel drive or Front wheel drive : What is your choice ? adrian Technical Stuff 1 25th January 2010 16:26
