Old 24th April 2007, 15:34   #1
lohithrao's Avatar
Thanked: 163 Times
Default Info required to modify/upgrade the OHC suspension??
Hello folks... am planning to get my OHC's suspensions upgraded....unfortunately both "Koni" and "Pedders" dont manufacture suspensions for OHC(dont know why)... so is there any other options??....
lohithrao is offline   Reply With Quote
Old 24th April 2007, 16:51   #2
payam's Avatar
as you ar based in bangalore i think your best option is pm psycho,he can give you a complete package of suspnsion at a very good price.
payam is offline   Reply With Quote
Old 26th April 2007, 22:41   #3
Default Any Alternative to Deccan Honda?
Need suspension and steering assy work done on my 2000 OHC
Whom to turn to? Some one other than deccan honda.
any suggestion welcome
Getting a thudding noise all the time esp on rough roads. front end is too soft. The front spoiler hits the speed breakers if i am above 40 KMPH :(. Guess there is some play in the rack pinion assy.
Pl. help.
Shri
nfs250 is offline   Reply With Quote
Old 30th April 2007, 11:39   #4
lohithrao's Avatar
Thanked: 163 Times
HI Shri....
for the noise which you are getting on ruff roads... guess your steering bushes have worn out???
Anout the bumper touching the speed brakers... just het a higher profile tyre if you are running 13inch rim or get a bigger rim... i used to hav this problem but sinc ei got the higher profile tyres its solved....
About the servicing center would always suggest to go to the authorised service centers....
Old 30th April 2007, 12:55   #5
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Lohith , I suggest you send me a PM regarding your requirements for the suspension .. Psycho does a beautiful job at this , and we all are reaping his benefits on cars like OHC , zens and baleno's .. Ajmat , a moderator here has got his suspension modded by psycho here and is extremely happy .. Read the following :
http://www.team-bhp.com/forum/364882-post85.html
Ohc 1.5 Vs Ohc Vtec narayan Technical Stuff 137 24th January 2015 12:15
OHC Suspension Problem EDIT : Solved! KSM-Vtec Technical Stuff 101 13th January 2014 21:08
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 5 22nd June 2012 17:00
Lowering the OHC and other suspension queries manveet Modifications & Accessories 38 8th April 2011 13:16
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
