| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Mar 2006 Location: Ahmedabad
| Hi! My S10 had already completed 35000kms and i really wanted something that can make the car a bit powerful. Then I started seraching the internet for solutions available for Fiat Palio 1.6 but to my surprise i could not find anything that is fitted bolt-on Palio 1.6.So after a lot of time searching on the net and disappointed with the results, i contacted Jyot of Nath Performance, a good friend and a car tuner regarding my query. As i wanted to play safe and wanted to avoid major modifications to the car, he advised me to go in for the Green universal intake kit, Storm. He also advised me to go in for the dynamisation kit so that the Storm would be a full fledged cold air intake kit. With lots of confusion in my mind whether to install the filter or not, Jyot gave me confidence to go ahead and install the same. He ordered a carbon fibre finished filter from Peter, but it took long for Jyot to get the delivery as the filter with Peter was out os stock and the new shipment was on the way. I was really excited when Jyot called me up and said that the filter had came and it looked awesome. I quickly went and took the delivery of that filter. Due to my busy schedule, i went to Tej Motors after a few days to get the installation done. Tej Motors is an authorised Fiat worshop, but due to close reltionship with their personnel, it has become my own performance workshop where i perform the modifications needed. With getting the modification done at Tej Motors, there are two advantages.One is that they have a through knowlege of Fiat Cars so they can do a clean job and other is that the personnel are excited enough to do a challenging job like fitting a cold air intake rather than doing a boring job. Here are the pictures of the installation, ![]() Removal of the Bumper ![]() Fender removal for better installation ![]() Fender removed ![]() Stock Air Box removed ![]() Green "STORM" Fitted with dynamisation kit ![]() An Air Sucker ![]() Installation Complete After the installation was completed, we went on a test drive to check whether everything was working fine.After the installation, what i found was that the engine note has improved and it sounds sporty. Engine responsiveness has also improved and it feels a lot smoother than before. Though you do not experience neck wrenching power, but you do notice a difference of about 6-8% in the power. Will definately keep you update on the fuel efficiency front.
__________________ May the force be with you.... |
| | #2 (permalink) |
| Super-Admin | Wicked install! How safe is it to keep the CAI under the fender? Also, isnt it recommended to have the minimum amount of curves which may amount to some restriction? Also check out any free-flow options. The Palio 1.6 engine sounds deliciously deep-throat (no pun intended) with a good exhaust.
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| | #3 (permalink) |
| Senior - BHPian | Great install Bhavit! Thanks for the pics too. You're lucky to have a co-operative Fiat A. S. S. joint handy to help. Is this one of those Green kits with forced induction (a fan-thing inside?). Real $3xy looking filter!
__________________ Seven are my colours Many are my lovers What was three will soon be two The music will again sound pure and true |
| | #4 (permalink) | |
| Quote:
Hi! Actually the original filter position was located in the fender and as i didnt want to cut metal, i thought it would be best to keep the new CAi there. Moreover, Keeping the intake pipe in the fender prevents water and small stones from entering the filter. The pipe has steel rolls inside so that the pipe does not bent from the middle thereby allowing maximum air even with more curves. I installed a Magnaflow muffler in my Palio but it wasnt a perfect fit as i wanted so i sold it off and returned to the original OEM muffler. Also have ordered Brembo brake discs from Uk and ZF Sachs Suspension from Germany..will keep you updated on this front..
__________________ May the force be with you.... | |
| | #5 (permalink) | |
| Quote:
Thanks dude. No its not a forced induction. Its just a conical filter inside a heat sheild.
| | #6 (permalink) |
| BHPian | OMG! the filter looks awsome. just a querry: wont water get sucked in through the intake pipe from the wheel-well during rainiy season(while the car is in motion)?
__________________ Planet, Sonja, ETC - "Elements of Life" Last edited by planet_rocker : 28th April 2007 at 15:47. |
| | #7 (permalink) | |
| BHPian | very good looking filter and nic job,its really hard to do any under hood mods on 1.6 but its a decent job man. Quote:
wow,what else man??these are amazing mods. ![]() | |
| | #8 (permalink) |
| BHPian | NIce install \, but CAI intside the fender and in the wheel arch is a suspect. Also the flexible intake pipe after hte pipe should not be used as it has a tendency to break with age and you wont even notice it. So engine would be breathing in all the dust from the engine bay. how much did the filter cost you?
__________________ Cheers, shaz |
| | #9 (permalink) | |
| Quote:
i dont think so. As i have installed the piping in the same position as OEM intake pipe, it should be fine. I dont know why FIAT has put the air intake pipe in the fender. I assume that they have engineerined it perfectly and so the natural think to do is to imitate them.
| | #10 (permalink) | |
| BANNED | Quote:
![]() Neat job, bhavit46. Congrats! ![]() @Mods: Could you resize the pics for visibility on 1024x768 screens please? This page is all over the place! Last edited by elf : 28th April 2007 at 19:08. | |
| | #11 (permalink) |
| BHPian Join Date: Jun 2006 Location: cochin
| cool work dude..was planning to fit in an extreme k&n filter in my 1.6....was amazed by the work done in ur ride....how much did it cost u for the entrire setup(including the installation charges?....
__________________ 2004 MODDED ZEN |--| FIAT PALIO 1.6 GTX|--| 2002 BOLERO |--| 2006 LANCER |--| 2001 OMNI |--| 97 M 800 |--| 2004 HONDA UNICORN |
| | #14 (permalink) | |
| Quote:
The filter cost me INR 6000, Dynamisation Kit cost me INR 3200 and the installation charge was INR 500. It was absolutely worth it.
| Thread Tools | |
Similar Threads | ||||
| Fiat Palio S10 | amit | Long-Term Ownership Reviews | 38 | 29th August 2007 23:37 |
| Service Report - Green Tracks / Javali Motors, Bangalore - for Fiat Palio | finneyp | Indian Car Dealerships | 14 | 16th August 2007 14:54 |
| Wanted a FIAT Palio S10 in Delhi | extreme_torque | Shifting gears | 1 | 9th January 2007 23:03 |
| Fiat Palio S10 | amit | The Indian Car Scene!! | 11 | 3rd May 2004 19:21 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
