Old 1st May 2007, 22:14   #16
rdkarthik's Avatar
Thanked: 11 Times
Another unique thing that will work: get a remapped ECU to fire all injectors simultaneously rather than sequentially - as in stock. You'll NOTICE a difference. But the mileage will drop atleast 35%.
Impossible. Mileage does not drop 35% in batch when compared to sequential... Performance does not increase either.. Wonder where you got that info from.
A programmable/remapped ECU with custom/modified fuel and ignition curves can increase the low end grunt ...
rdkarthik is offline   Reply With Quote
Old 1st May 2007, 22:39   #17
sbasak's Avatar
Usually for each Liter of engine size (petrol) max torque can be produced is 100 Nm
It depends on lots of factors including engine's volumetric efficiency (mainly).
It is easy to increase BHP of engine with some aftermarket apparatus but difficult to increase torque because of the inherent design of how engines work.
If you want high torque at low RPM, simply use a diesel engine (or go for the highest engine size you can afford) or electric motor (full torque at any RPM).
The design of diesel engine is such that it produces high torque (since it uses very high compression).
sbasak is offline   Reply With Quote
Old 1st May 2007, 22:42   #18
aZa
aZa's Avatar
Thanked: 17 Times
Mileage is affected because one tends to rev the car more due to the throaty sound produced by the FFE. But you can tune the FFE system to be silent. If one drives the car normally then the mileage should actually increase.
Old 1st May 2007, 23:31   #19
theMAG's Avatar
Thanked: 1,572 Times
From a Bangalore customer. We could take this offline if you'd like. I'd urge anyone not to take a defensive stance since its not my objective in life to comment unneccesarily about anything.
I know - and the reason I put it up as a solution. Its a fantastic solution - I've driven a car with the afore-mentioned ECU
Old 1st May 2007, 23:45   #20
theMAG's Avatar
Originally Posted by mclaren1885 View Post
True .. I think he got confused by SC .. Unlike TC's they dont have lag ..
Yup - my mistake. I meant SCs - and a sufficiently capable engine to churn the SC
Old 2nd May 2007, 09:58   #21
rdkarthik's Avatar
Thanked: 11 Times
Increase in performance or drop in FE (35%) has nothing to do with injection firing pattern.. Dosent matter whether you go batched , semi or full sequential..
Engine performance and FE are governed by fuel and ignition curves.. For the same curves, all types of injector firing patterns will produce identical figures for performance and FE (+/- 2 to 3%) .. Hope you get the concept..
Nothing defensive here dude, have no clue who you are talking about, either way nice to know you like it ... The car you talk about probably needs work on cruise and part throttle region of the fuel maps..
Old 2nd May 2007, 13:10   #22
Default hi
the ex pipes are not twisted ,
the 4-2-1 or 4-2 exhaust system will definately imprve the performance ...only it is well designed and well execuated
TURBOSAM is offline   Reply With Quote
Old 2nd May 2007, 14:45   #23
theMAG's Avatar
Karthik,
The afore-mentioned car's mileage drops to 9-10 kmpl while in batch mode, compared to 15 while on sequential firing; according to the owner - who's a very experienced driver. But - as you mentioned, I love that tuned ECU and the way power kicks in due to the batch mode - I wouldnt be surprised if I decide to get it for my Swift shortly.
Old 2nd May 2007, 15:05   #24
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
I hope you are considering the nature of driving as well .. Any mod to the engine will only make your right foot heavy all the time (to reap the max out of what you spent) owing to the low FE .. And I am talking from personal experience .. Also any other mods on the car ??
Old 2nd May 2007, 15:22   #25
theMAG's Avatar
I know
I know I know
Oooh - wouldnt you like to know ?!
Old 2nd May 2007, 15:33   #26
Thanked: 35 Times
Oooh - would you like to know ?!
YES !! Maybe that will enable us to make a detailed analysis for the 35% drop in FE as you mentioned ..
Old 2nd May 2007, 15:37   #27
theMAG's Avatar
Right. For the benefit of all mankind who wish to increase their low end torque, I shall take upon this with utmost responsiiblity myself - you'll be posted with the results.
Old 2nd May 2007, 16:48   #28
Thanked: 20 Times
what about porting and polishing ? Is it easier than say ffe ?
swathyd is offline   Reply With Quote
Old 2nd May 2007, 21:35   #29
rdkarthik's Avatar
Thanked: 11 Times
Karthik,
Before you confuse yourself, the performance gains or FE is NOT due to batch firing mode... It will behave the same in semi-sequential or sequential (here i go again ).... No matter who is diving, the changes are due to different fuel and ignition maps.....
Old 2nd May 2007, 23:37   #30
Thanked: 20 Times
Please come back to topic rather than debating over ecu tweaking.
WagonR knocking at lower RPMs ravi@64bhp Technical Stuff 20 6th February 2017 18:24
How to improve lower end torque.. DRC Technical Stuff 19 10th July 2012 16:50
How to Increasing torque of 97' carb Zen? buddy Technical Stuff 1 20th July 2009 10:35
What's up with RPMs? neverclever Technical Stuff 5 23rd June 2004 16:00
