View Poll Results: Noise?
Oi chupp! Bahut ho gayaa aawaj. I want silence. 27 36.99%
Noise, noise & more noise 11 15.07%
Don't care, as long as the noise translates to faster movement. 35 47.95%
Voters: 73. You may not vote on this poll
Old 5th May 2007, 22:05   #31
Vid6639's Avatar
Thanked: 21,086 Times
Originally Posted by iraghava View Post
Dynamat, sound absorption & damping material. Check the ICE section for more details.
kya yaar you telling me what is dynamat that i know. I wanted who or what is dynamate.
Busa pls. give more insight how do we get a dyna-mate inside the car.
you can try growling back when your intake growl to scare it.
you were thinking about some spray na rubber based what happened to that. why not ask rubber wallah NC.
Old 5th May 2007, 22:10   #32
condor's Avatar
Thanked: 4,908 Times
Originally Posted by hydrashok View Post
Sorry Elf, but this got me rolling on the floor. Y'know, read out of context... <wink> <wink>).
Originally Posted by elf View Post
hydrashok, you're a pervert! And it's a typo. It's supposed to read as "cylindrical", not "conical".
Doesnt make much of a difference, does it ? Come to think of it, it just got better ..
Old 6th May 2007, 00:23   #33
CAI helped me to regain silence when i replaced K&N conical with K&N CAI on my Skoda.
Desert fox is offline   Reply With Quote
Old 6th May 2007, 00:27   #34
BUSA's Avatar
Talking
Sorry guys, it was a typo. Dynamat not dynamate.. :(
@ Elf - Your best solution to re-route the KnN to the rear bumper so intake noise wont be much or better still hire theFag as your driver and sit in the rear couch, you wont hear much
Et tu, Busae?
Then Fall Elf???
I meant most diesels have some covering inside the hood in black colour to prevent noise from reaching out, my Optra too has it though its not a diesel, its for sound deadning.
why dont you flick Sam's and put in your huge cylindrical/conical one in his car
Shouldn't have bought a Lancer then, na?
Old 6th May 2007, 01:48   #35
Fuelled's Avatar
How about trying a bigger filter?
Why I'm suggesting it cos two Delhi members aZa and Faithless run huge and normal size air filters in their Xings. While faithless's car growls across all the rev range, aZa'a car starts growling only at higher revs.
Which leads me to belive that the growl is related to the X amount of the air being sucked per Y area of the filter. And if the filter is bigger the X/Y is lesser. Hence less noise.
Any experts take on this?
Fuelled is offline   Reply With Quote
Old 6th May 2007, 01:56   #36
elf
elf's Avatar
Thanked: 9 Times
Dude Fuelled! You haven't seen the size of the cylinder I've got.
It's a 4.5" dia & is at least 12" long. It's so long & thick it needs to be oiled before it's inserted, to ensure a good grunt & maximum bang for the buck. Makes the recipient noisy as hell, which is a darned pain sometimes when you wish for quiet companionship instead of a wild, grunty, growly, drooling, chest-thumping, screaming ride.
Bigger isn't always better. As all have seen with my shortened shifter.
elf is offline   Reply With Quote
Old 6th May 2007, 01:57   #37
gr8guzzler's Avatar
Thanked: 38 Times
Elf this is something that i noticed last drive in Ford Rocam's car to Pune. Gr8 sound for an adrelaine rush but to live with ikt on a daily basis is hell. Go back to the stock option for regular usage, that's the only option you have.
gr8guzzler is offline   Reply With Quote
Old 6th May 2007, 02:16   #38
Fuelled's Avatar
Wasnt any pic of it in the garage. So didnt know how big ur cylinder was.
So either insulate the firewall and the bonnet inside, or go back to the stock box with a replacement filter.
Finally think of stuffing ur ears with some nice earplugs(not music ones, just plugs.. like swimming plugs). I've seen some nice ones out there meant for reducing ambient noise delivered to ears.
Old 6th May 2007, 02:30   #39
elf
elf's Avatar
Thanked: 9 Times
I can't stuff my ears with sound deadeners! I use my bluetooth headset whilst driving, & I make & receive most of my calls then.
Yes, I know I'm not supposed to.
Old 6th May 2007, 02:40   #40
Fuelled's Avatar
Stuff one ear only then, Send the other one to me
I too use a headset
Old 6th May 2007, 02:42   #41
elf
elf's Avatar
Thanked: 9 Times
So why do you need three ears?
And where will you place the ear that I send you?
1. Behind your left ear?
2. In front of your left ear?
3. Behind your right ear?
4. In front of your right ear?
5. On your forehead?
I need to know because I'm a bit concerned where people place the ears that I send them.
I had a bad experience the last time with one Dr. H. Lecter.
Old 6th May 2007, 03:01   #42
Fuelled's Avatar
I Meant regards the earplugs.
Old 6th May 2007, 09:19   #43
viper's Avatar
Thanked: 9 Times
Oye Elfy,
Just returned from Goa last night and saw this thread. Have a solution for you get the car over and we shall solve it for you. Will not eliminate the sound completely but will definitely reduce it by approx 50%.
Viper
viper is offline   Reply With Quote
Old 6th May 2007, 15:50   #44
Hi elf why do you want to make it silent yaar your car sounds like a real sportscar! You should enjoy the sound of the power and the looks of jealousy from others
speedweednitro is offline   Reply With Quote
Old 7th May 2007, 01:28   #45
elf
elf's Avatar
Thanked: 9 Times
speedweed baba, I'm now an old man & just want silence & power, as I've explained elsewhere on this thread.
Looks of jealousy be damnned. For me these days, Om Shanti Om's where it's at.
And all you ICEr boys, that's Om. Not Ohm.
Ractive growl!! hellspawn Modifications & Accessories 30 2nd July 2010 11:54
Why can't we shut the heater off? santosh.s Technical Stuff 58 23rd March 2009 14:06
Fiat India : How much longer before they shut down? GTO The Indian Car Scene 378 12th February 2009 13:35
Diffrence between an ordinary cold air intake and a ram air intake?? Vys De BlUR Technical Stuff 24 1st April 2008 12:59
Someone created a membership for me @ *****shut.com jkdas Shifting gears 3 20th June 2006 13:52
