Old 5th June 2007, 23:49   #16
I had the same problem with my old car which was a matiz. The problem was a small crack in the exhaust system. I had it changed. Several months down the line, the same sound began to appear...however the piping of the exhaust seemed structurally intact. I was then told that it was due to some component loose in the ?catalytic converter.
I was given the option of changing it, but then was warned that the spare parts available these days are of poor quality, and the problem may recur. Since it did not affect the vehicle's performance, I did not change it. The sound wasn't too loud either.
Subsequently, over the years, I have seen several other matiz's having the same sound coming out of them!
AntibiotiX is offline   Reply With Quote
Old 7th August 2007, 19:57   #17
JayD's Avatar
Thanked: 2,008 Times
Hey... 99% this has NOTHING to do with the exhaust. check the air filter box if it has any of its mounting legs broken. This happens if we do not fix it properly. It produces a rorty sound while revving , especially when cold
JayD is online now   Reply With Quote
Old 8th August 2007, 17:15   #18
mithun's Avatar
Thanked: 59 Times
Are you sure about your advice ?
Old 8th August 2007, 17:47   #19
JayD's Avatar
As i said.. 99% Sure... my car had this problem, everyone suspected some leak but the final problem was this. just give it a try...
Old 8th August 2007, 22:23   #20
Id tend to agree with JayD since a relative's Mariz had the same problem and it was solved in the same way. Like the sound though... Felt very Sporty
ashwinsaval is offline   Reply With Quote
Old 13th August 2007, 14:44   #21
JayD's Avatar
Heh heh..i know!! Thats why i left mine as it is!!
Old 14th August 2007, 12:33   #22
rahul_intlad's Avatar
Nope jay, everything is alright there.
I even took it to a place where they specialize in exhausts only and they found no problems as well,so finally have left the problem as it is.
Waiting for Gm to start support of the matiz.Any news on that front adya.
rahul_intlad is offline   Reply With Quote
Old 13th July 2013, 14:39   #23
ahmad.007's Avatar
Thanked: 66 Times
Ok, if the sound is sporty more like an aftermarket exhaust, then surely this has to be a leak in the exhaust system. Matiz engines make a lot of water which rusts the exhaust (box) and finally it starts leaking. We have to get it replaced every year. It starts with a sporty sound, over the month it gets louder with the engine revving more freely but there comes a time when the drop in torque is too much. We have almost got it changed 3 times in 3 years.
But your mechanic says its not the exhaust. If its a whine (type of a whistle), do check the alternator and belts.
ahmad.007 is offline   Reply With Quote
Swift : Making metal rubbing sound : Help manjubp Technical Stuff 9 5th December 2010 11:17
Making The Palio Sound "Good" Being on a Strict "Diet" vinaydas In-Car Entertainment 4 6th May 2010 19:59
Autopsyche & Manish Arora on Discovery Travel & Living present - Life is Beautiful autopsyche Shifting gears 31 24th April 2008 22:38
..car making booming kinda sound.. ns_jughead Technical Stuff 2 26th June 2006 02:58
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
