Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 5th May 2007, 21:04   #1 (permalink)
rahul_intlad's Avatar
Default Matiz making sound as though a K&n filter is present
There is this strange noise from my car[daewoo matiz],somewhat like a K & N filter kind of noise when I am accelerating.This noise is not felt when the car is just idling.The first thing I did was get the exhaust checked by a mechanic ,he did not find anything wrong so I went to a person specializing in car exhaust's and he too did not find anything wrong with the exhaust and said that maybe the air filter was clogged.
This is the OE air filter replaced on a very recent service[3 months back],anyways my mechanic had the air filter cleaned by getting air blown on to it.But that too did not solve the problem and the car still makes noise.
I don't feel any drop in mileage and so also no problem with accelerating,however there is no improvement[just for the record].The source of the noise is a mystery for both my mechanic and me ,could anybody help.
rahul_intlad is offline   Reply With Quote
Old 5th May 2007, 21:06   #2 (permalink)
mclaren1885's Avatar
Its quite hard to identify the noise you are talking about .. Do check if you in any case have alternator whine due to stereo or something ..
__________________
Phoenix!
Old 5th May 2007, 21:13   #3 (permalink)
Thanks Rahul, I am kind of illiterate when it comes to technical details of car's so please forgive me if this sounds foolish.
Is it possible to have alternator whine even if the stereo is switched off,also what exactly is alternator whine.
Old 5th May 2007, 21:21   #4 (permalink)
Maybe this should help :
Noise Prevention
__________________
Phoenix!
Old 5th May 2007, 21:47   #5 (permalink)
From the above linky,I am slightly confused it does not sound like a siren,the sound is more on the grounds of leaking exhaust kind,but yes the sound does increase with the speed of the engine and also when the car is driven for a while.
For those of you who are lucky enough never to have been exposed to alternator whine, it sounds like a miniature siren that rises in pitch with the speed of the engine
Old 5th May 2007, 23:53   #6 (permalink)
hvkumar's Avatar
Are you sure that this is not (a) a wheel bearing wear-out hum, or (b) worn out timing bearing, or (c) Timing Belt tensioner.
The last-named can cause noise at higher speeds. I have run a Matiz for 2,60,000 kms (still my second car) and I have chnaged the tensioner at least 3 times. Exhaust noise is very tell-tale, you will have to diagnose whether this is a metallic, plastic, scraping or air noise.
Kumar
hvkumar is online now   Reply With Quote
Old 6th May 2007, 00:20   #7 (permalink)
Looks like a wheel bearing problem. You will not hear the noise at low speeds or when idling. But when you accelerate it will sort of sound like a sports car !! Had the same problem and got it replaced. After that it was fine.
__________________
Everyone is born right-handed, only the gifted overcome it.
This is my car and I have my wife's permission to say so.
csentil is online now   Reply With Quote
Old 6th May 2007, 02:12   #8 (permalink)
elf
elf's Avatar
Rahul, it seems that you may have an intake leak.
Check your intake hose, airbox & finally, your filter element. The service chappie may have blown a hole or torn the element in some way whilst cleaning it, leading to the intake growl you hear.
elf is offline   Reply With Quote
Old 6th May 2007, 02:43   #9 (permalink)
tsk1979's Avatar
Rev engine at neutral, listen for sound.
Switch on AC and then rev, listen for sound.
If the sound lessens or sounds muted with AC on, or changes note, its the AC compressor bearing.
__________________
Reclaiming.....!
Old 6th May 2007, 11:18   #10 (permalink)
Thanks everyone,today being an off day cannot get anything done.So will report in a few days time.
Old 6th May 2007, 11:32   #11 (permalink)
Rahul, best thing to do would be to take it to a Chevy Spark dealer and have it checked. Chevy India had claimed that they will offer support to Matiz owners also. Going to the right place will save you a lot of time eventually.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 6th May 2007, 13:40   #12 (permalink)
Sankar's Avatar
From the description it does sound like an intake leak. It could be that the plumbing could have developed leak due to loose fitting or crack. The leak might be after the filterbox or before.. since you can't hear it at idle it might be before the airbox.
I had a similar sounding Maruti when i cut the round airfilter box to exposed the round filter.
Old 13th May 2007, 12:54   #13 (permalink)
Sorry folks but I just Did not get any time the whole of last week,the car was unused for this period will go to the garage tomorrow.
Old 16th May 2007, 05:58   #14 (permalink)
mithun's Avatar
I'm having the same problem on my 6 year old Alto(40K KMS) and the service center is insisting for the complete replacement of the exhaust system. Should I go for it since the vehicle is about 6 years old ?
The sound is present both during idling & running.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 5th June 2007, 13:18   #15 (permalink)
adman77's Avatar
Check for holes on your throttle pipe or hose. Maybe the problem lies there.
adman77 is online now   Reply With Quote
Thread Tools
Autopsyche & Manish Arora on Discovery Travel & Living present - Life is Beautiful autopsyche Shifting gears 31 24th April 2008 22:38
What Engine & Body for making a Custom SUV ? mamba24 Modifications & Accessories 11 17th March 2008 17:18
Swift : Making metal rubbing sound : Help manjubp Technical Stuff 8 14th July 2007 13:02
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 19:33
..car making booming kinda sound.. ns_jughead Technical Stuff 2 26th June 2006 02:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
