Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 28th April 2008, 17:16   #46 (permalink)
n_aditya's Avatar
Originally Posted by razor4077 View Post
but I believe the life is a tad less.
Thanks for the reply razor. Approximately how many kms did the pad's last? A rough estimate will do, so I can compare figures with stock pad's.
And 9k is for a set of 2 EBC Green pad's right?
Old 28th April 2008, 18:15   #47 (permalink)
crazydiablo's Avatar
Anything available for the baleno?
crazydiablo is offline   Reply With Quote
Old 29th April 2008, 01:43   #48 (permalink)
fiery enzyme's Avatar
Guys, How much would the EBC brake pads for M800 cost, are there any other options available for the 800 other than EBC in terms of brake pads?
fiery enzyme is offline   Reply With Quote
Old 29th April 2008, 12:43   #49 (permalink)
razor4077's Avatar
Just fitted them a month or so ago, so they're still in use Would suggest you go through EBC's website - they might have a more concrete figure about the life of the pads.
Set of 2 pairs (4 in total - 2 for each front wheel), with shims to cover the pads.
Pics:
http://www.team-bhp.com/forum/modifi...tml#post737037 (Lancer overhaul - Project Phoenix)
razor4077 is offline   Reply With Quote
Old 29th April 2008, 15:54   #50 (permalink)
v1p3r's Avatar
Suzisport Kevlar pads.
__________________
Peace is a lie, there is only passion.
Old 16th May 2008, 13:25   #51 (permalink)
Could someone shed some light on brakes issue.
Assuming car has no ABS.
Most cars will lock wheels when brake hard.
When brakes are improved/upgraded. Cars will lock wheels even more efficiently.
How does this help?
kaynmantis is offline   Reply With Quote
Old 16th May 2008, 14:13   #52 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Well kay, it does not help.
What it helps in when you are on a track or driving downhill through hairpin turns.
Stock brakes will fade quickly and you will lose braking much sooner, than in upgraded brakes which are better ventilated.
So unless you are going to have a track like situation in your normal driving, all these upgraded brakes will do is give you bragging rights.
__________________
Old 16th May 2008, 14:23   #53 (permalink)
v1p3r's Avatar
Unless of course, you drive a car with bad OE brakes, like almost all Indian cars.
How does this help?
You need better tyres with more grip to overcome this.
__________________
Old 16th May 2008, 14:34   #54 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Bad brakes?
I have driven the indica, Santro, Getz, Safari, Swift, Palio, and none of these cars had brakes so weak that hard braking would not lock the wheels.
Infact it was quite easy to lock the disks.
I think unless you have badly maintained brakes, it would be rare to find a situation where you won't be able to lock wheels in normal driving.
However after 40kms of continuous downhill stretch, OEM brakes surely go toast, even if you try to stick to engine braking most of the time.
__________________
Old 16th May 2008, 14:37   #55 (permalink)
krazydriver84's Avatar
Can somebody please suggest some good brake pads for a m800, and their cost.
__________________
Rockin to the Sound of the Engine...
krazydriver84 is offline   Reply With Quote
Old 20th May 2008, 03:24   #56 (permalink)
v1p3r's Avatar
Bad brakes?
Zen, Esteem, Baleno, to name a few. Their braking can best be described as average, and in the case of the old Zen, pathetic. And then again, I did mention, you need to upgrade tyres to appreciate good braking.
Which reminds me, aren't stock cars undertyred anyway? No wonder they lock brakes so easily.
The normal and simple (I'm not saying cheap) solution to brake fade is different discs, whether they are larger, of a different material, or cross-drilled and/or slotted. Also, using better quality brake fluid may help, and stainless steel brake lines certainly help.
__________________
Old 20th May 2008, 11:54   #57 (permalink)
razor4077's Avatar
I'd also add the Lancer to that list. OE brakes are really poor.
Old 20th May 2008, 16:54   #58 (permalink)
im_srini's Avatar
Smile
Hi, I'm not very sure about the M800 but EBC pads are available for the current Alto (the M800 & the old-Zen were just previous generations of the Alto anyway).
You get both the Ultimax as well as the Green-Stuff pads - they're available from Electra, Chennai. The Green-Stuff ones for the Alto cost a little over 5K, for a set of 4 pads. The Lancer pads are around 8.3K...
im_srini is offline   Reply With Quote
Old 20th May 2008, 17:15   #59 (permalink)
Originally Posted by Psycho View Post
Just a quick update EBC brake pads are now available in India for the following cars:
Ultimax Replacement Pads
__________________________
Esteem Front
Gypsy Front
M800
OHC 1.5
Skoda
Mitsubishi Lancer CE Front
Green Pads
Zen
Esteem
Alto
Gypsy Front
Civic
Accent/Getz
Elantra Front
Skoda RS Front & Rear
Superb Front & Rear
Mitsubishi Lancer
DOT 4 Brake Fuild
Hey man , where's the Swift ?
Ultimax available for the swift . N1 in mumbai stocks them - quite reasonable too and he s had them for quite a while too.
cyneverdie is offline   Reply With Quote
Old 29th May 2008, 21:16   #60 (permalink)
i'm surprised to NOT see the ikon mentioned in this list. does anyone know of any options for upgrading ikon brakes? any good brake pads out there that will do the job? i have a 1.6 and even though it's running stock it's a bit scary when i have to brake hard.... just not enough bite sometimes.
silver_shadow is offline   Reply With Quote
Thread Tools
Improving BASS shashankre Ask the Gurus 32 4th April 2007 00:07
Tips on improving indica FE panky12345 Technical Stuff 10 14th February 2007 10:03
Electronic wedge brakes[Lighter, better, shorter stopping distance & in cars near U] 1Day The International Automotive Scene 3 11th November 2006 22:05
Improving the Ground Clearance naveendhyani Modifications & Accessories 1 17th March 2006 09:08
Improving Rider Comfort Dovin The Indian Car Scene!! 13 29th September 2004 19:29
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
