Old 22nd May 2007, 10:02   #1
Thanked: 245 Times
Thumbs up Security Devices to protect your Vehicle
What are the various types of car security systems available nowdays and which ones are most effective ???.
I was reading an article about how a Scorpio was traced and recovered using this intelligent GPS security system and the vehicle was found parked in a Mall in Haryana, since this system sent constant SMS to the owner of its location.(he had forgotten to switch it on, in the first place). Read about this device here
Then now maruti has come out with Key based security/engine immobilizer i.e. ICat read about it launch here. Under this system, a transponder is in-built in the car key which has a unique identification code that matches with the code in the Ecu. This makes the car start only with its own key and no other key/ direct wire connections can force the car to start.
And then who can forget the Autocop/Blackcats etc i.e. our personal door openers and that what I call them since the protection is bare minimum with these and have seen many car's being stolen despite this security toy.
Old 4th June 2007, 14:33   #2
Maruti's immobilizer is the best.Though maruti install's it before purchase its a third party company.I cannot recall the name but I have fitted it in my Indica xeta along with autocop dx.iT WORKS GR8.aND i TOOK AUTOCOP COZ WHEN i PRESS lock button on the remote all the windows are rolled up ( I have power windows).Other manufacturers dont have this system!
neel12345 is offline   Reply With Quote
Old 4th June 2007, 16:04   #3
rjstyles69's Avatar
Thanked: 795 Times
Is there a device which can deliver 10000 volts and kill the imbecile on the spot whilst trying to steal or damage ?
Old 4th June 2007, 17:03   #4
cheap_deal's Avatar
this would be great, but i'd need a lot more volts 100,000 should do fine.
cheap_deal is offline   Reply With Quote
Old 4th June 2007, 17:10   #5
tsk1979's Avatar
Thanked: 16,420 Times
Prodding Car Thieves to Reform
This article has the details. 250$ only
Old 4th June 2007, 23:12   #6
theMAG's Avatar
Thanked: 1,572 Times
Personally, I'd settle for that flame thrower from South Africa - triggered by remote even. If that shouldnt deter the cunning thief with fireproof clothing, I'd settle for the electric shock system. If India is too politically sensitive for any of these, I'll settle for the Autocop with touch sensor that I currently have
Old 5th June 2007, 14:08   #7
gd1418's Avatar
Thanked: 656 Times
Talking
Although my truck is fitted with M&M OEM remote central locking, automatic windows roll-up, Gear lock and Amsaki SMS tracker, I too am inetersted in this device if at all it exists.
If you can find one let me know too..
Old 17th June 2007, 10:22   #8
sabret00the's Avatar
Thanked: 45 Times
what about Xenos from Pricol?
sabret00the is offline   Reply With Quote
Old 18th June 2007, 22:40   #9
Xenos, it's the best in class. But the highest model with all those atttractive features is pretty expensive.
Old 18th June 2007, 22:52   #10
binz's Avatar
Thanked: 412 Times
Ok,..now there are ways of starting the car without turning the ignition.There are also ways of turning off the security alarm.You should be knowing that.
Even with a fake key you could start the car,..just put the key in,turn it into "on" or whatever and keep a spanner ready.
Very very low tech way of starting the car.
Old 19th June 2007, 05:59   #11
Thanked: 45 Times
I wanted to get a car with the "engine immobiliser" feature that all new ALTOs have...but since I bought one of the last few "xFun"s hence I had to compromise...the xfuns were manufactured before the "engine immobiliser"funda came into existence....duh
Old 19th June 2007, 11:11   #12
gd1418's Avatar
Thanked: 656 Times
Come again..Can you elaborte more on this?
Old 19th June 2007, 11:21   #13
abhilashvk's Avatar
Thanked: 31 Times
Can you fix only the immobilizer to an old car which has remote locking ? Can the old Marutis be fixed with the new iCAT immobilizers?
abhilashvk is offline   Reply With Quote
Old 19th June 2007, 11:28   #14
Thanked: 245 Times
Yes, even I want to know how would you drive a car without the ECU being engaged.
Old 29th June 2007, 20:10   #15
Ketan's Avatar
Thanked: 179 Times
Hey guys,, I just got the AutoCop>XS 8500/8550 model.
Can someone tell me whether the proximity lock/unlock feature is ON by default?? if not how to get it activated? an online resource would do.. if someone can point me to there website,, I'm also searching..
Thanks in advance..
Ketan is offline   Reply With Quote
How do you protect your car from rats? speedsatya Technical Stuff 1363 9th July 2018 15:33
ARTICLE: How to protect your car from THEFT Dippy On owning a car 250 28th May 2018 08:42
How to protect your car on 'Holi' akash_m Technical Stuff 15 21st March 2008 23:30
