Old 7th June 2007, 02:04   #31
kpzen's Avatar
Thanked: 1,655 Times
Where is noidaboy ??? Hey show up n let us know what have u decided finally!
Old 7th June 2007, 02:12   #32
payam's Avatar
Originally Posted by hellspawn View Post
he has a carburetted m800 so he will also need to upjet his carb if he is going to increase the throttle body.
the suspenion upgrades are necessary if you take the car on a track.
the kind of prformance upgrades he is looking for is probably beating another 800 at a drag or quick launches at a traffic light.
so finally something is released,you are right HP if he is looking for these thing no need for suspension.and dude i didnt suggest him a T.B enlargement i just told him what it is very shortly.
payam is offline   Reply With Quote
Old 7th June 2007, 10:18   #33
noidaboy's Avatar
Thanked: 260 Times
well,the T.B enlagrement is the only option i have been given. i need to work on that how and from whom it can be done. any thing else suggested??
noidaboy is offline   Reply With Quote
Old 7th June 2007, 10:20   #34
noidaboy's Avatar
Thanked: 260 Times
Do i need to change the whole brakeset to get boosters installed???
Old 7th June 2007, 10:52   #35
humyum's Avatar
Thanked: 2,503 Times
Nope.The current brake set will suffice.u will need to drill a hole in the manifold for the vaccume requirments of a booster.IT can be done for inside 5000 rupees includin the labour.
Get the booster and piping from a maruti authroised service station and get it fixed from a trusted mechanic as maruti does not do booster fittings for carb 800s.
PS:Its not an easy job so get it done from a mechanic who has done it before otherwise u ll end up with a rock hard brake pedal.
Old 7th June 2007, 13:20   #36
noidaboy's Avatar
Thanked: 260 Times
OK,thanks a alot.Is there a way to increase gear ratio's??
Old 14th June 2007, 11:38   #37
irridium plugs, automech, K&N stock replacement filters, Potenza G3, i guess this would do good for ur car.
roadntrack is offline   Reply With Quote
Old 17th June 2009, 19:39   #38
rrsteer's Avatar
Thanked: 937 Times
Default Suggestions for M800 Performance Modifications
I have a 2 year old M800 with 4 gears. I am looking to improve its performance. Since I am a novice in this field, thus request you guys for inputs. It would be great if you can suggest the specific mods along with the associated costs, its advantages and disadvantages. Also request you to please name the best workshop to carry out these mods in Delhi.
Too many questions, ain't it? Ok, will stop here. Just one more thing : my budget would be Rs 15K.
rrsteer is offline   Reply With Quote
Chensaro upgrades from M800 to Ford Fiesta Diesel 1968chensaro Test-Drives & Initial Ownership Reports 24 2nd April 2012 20:05
Performance upgrades for the Honda Civic vikram18 Modifications & Accessories 46 16th June 2007 03:49
performance upgrades... amitverma Modifications & Accessories 18 6th May 2006 23:21
Serious Performance Upgrades witnesstowonder Modifications & Accessories 8 6th May 2006 14:00
Chips n Performance Upgrades for Palio Sagarpradhan85 Technical Stuff 5 19th April 2006 13:15
