Old 6th June 2007, 15:24   #1
invincible7's Avatar
Thanked: 154 Times
Default Esteem Suspension
I need to know how can we improve the suspension of Esteem for better city rides..within a minimum budget... what are the options and if i can get the cost as well would be great.... the current suspension is ok.. but i want to enhance it a lil bit.. so am looking in that direction..
invincible7 is offline   Reply With Quote
Old 6th June 2007, 15:39   #2
kpzen's Avatar
Thanked: 1,655 Times
You mean, u want a suspension for the bad roads right? aka soft suspension. If thats what u want then it will increase the body roll & your car's handling will go for a toss.
I would say its better to stick to the stock suspension...Also Dont think there are good enough mechanics in Delhi who can tune the suspension as per your needs.
If there's a good budget & u want to improve the complete dynamics of the car then u can think of Koni's
Old 6th June 2007, 16:11   #3
Hellcat's Avatar
@invincible7: I would advice you to PM Psycho, he had fine tuned my Esteem
suspensions and it worked wonders for me.
Hellcat
Hellcat is offline   Reply With Quote
Old 6th June 2007, 16:46   #4
lohithrao's Avatar
Thanked: 163 Times
invincible7: You can get the suspensions hardend depending your comfort level, this will help you in cornering and also will be able to take some ruff roads comfortably(cost will be around 6k). other option is Kony, this will cost you around 30k for the 4 set but its worth it.
I got my suspensions hardend, Fazal "FRK Racing" did it for me. Am pretty happy with it.
lohithrao is offline   Reply With Quote
Old 6th June 2007, 17:13   #5
Thanked: 154 Times
well as of now the suspension is average .. i wanted to improve it.. while keeping things soft as its going to be a city ride always.. moreover Konis are way too expensive and i dont think i need to at this moment... how about adding the front struts .. will that help to some extent.. and what can be the cost... i did Pmed Psyco long time back.. i guess he is busy these days...
Old 6th June 2007, 18:38   #6
Psycho's Avatar
Thanked: 95 Times
I have a few questions:
1) How many km have the existing suspension run?
2) What is the status of the suspension bushes?
This will help in diagnosing and recommending the right approach.
Old 6th June 2007, 18:55   #7
Thanked: 154 Times
The car has run more than 80K kms.... but its overall a well maintained vehicle.. never had any issues with the suspension... i really cant comment on the suspension bushes as havent checked them but i guess you can make out what conditions they can be after such a long runup..
Old 6th June 2007, 19:12   #8
Psycho's Avatar
Thanked: 95 Times
In that case would reccomend that you just go ahead and get yourrself the complete stock replacement of your suspension kit and bushes. This would solve your problem. Typical problems you will face if you try doing piece by piece is that the handling of the car will never be perfect hence better to do the whole thing in one go.
Old 6th June 2007, 19:14   #9
Thanked: 154 Times
how much would that cost... and i would also like to know what effect does the front struts add up to the front suspension...as i am not too clear on that part from what i got to know...
Old 6th June 2007, 19:19   #10
kpzen's Avatar
Approx prices
Front Suspension arm - Rs 1200
Front shocks - Rs 1400
Old 6th June 2007, 19:27   #11
Thanked: 154 Times
thanks guys.. especially psycho for the valuable suggestions...
Old 6th June 2007, 19:58   #12
Thanked: 154 Times
@kpzen thats for the front.. any ideas on the rear kit and bushes..
Time for Suspension Re-do for my Esteem esteem_lover Technical Stuff 26 3rd March 2010 01:42
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Hardening esteem suspension techn0l0gist Modifications & Accessories 1 29th April 2008 21:52
95 Esteem Engine, suspension and chassis good condition IronWolf Shifting gears 0 2nd July 2007 02:25
Kindly Advise - Esteem Done 80k Needs Suspension + Cluth Plate passion4cars Modifications & Accessories 4 8th December 2006 02:13
