Closed Thread
Old 13th June 2007, 17:20   #1
Deepz's Avatar
Default Not happy with brakes..upgrades?
Hi guys, I have a 2001 Santro and i'm not satisfied with its braking.. tried new brake pads too.. still not happy.. Is it possible to upgrade the system? I was reading another thread and came across someone's car with 'Wilwood Brakes'.. Is it possible to get such drilled discs for 13 inch rims? any other suggestions will really be appreciated.. thanks.
Deepz is offline
Old 13th June 2007, 18:46   #2
n_aditya's Avatar
Thanked: 2,781 Times
Hope this link helps.
http://www.team-bhp.com/forum/techni...tml#post461287 (Brakes not working as they should be)
I suggest you get the brake bleeding done, fill in fresh brake fluids and then consider any upgrades as they can be very expensive.
n_aditya is offline
Old 13th June 2007, 18:52   #3
Deepz's Avatar
Hi aditya, i just went through the link you posted but there isnt much info on the topic yet.. although i will keep checking that thread regularly.I wanted to mainly know about upgrading the system.Thanks buddy.
Deepz is offline
Old 13th June 2007, 18:55   #4
Thanked: 103,711 Times
And another thread which will help : Linky (Improving your car's brakes: Options and costs)
GTO is offline
Closed Thread
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Bolero brakes failed - fixed. Now its not the same. Spinnerr Technical Stuff 12 4th February 2009 12:17
Why not a Single Lever - Double Brakes Concept for motorbikes? slipstream Motorbikes 26 15th January 2009 18:56
Brakes not working as desired in my Accent Peter Technical Stuff 11 17th October 2008 23:31
Brakes not working as they should be bruty Technical Stuff 12 23rd July 2007 23:08
