Old 14th June 2007, 13:03   #1
Deepz's Avatar
Default Need help for exhaust system(stock).
Hi guys, I have a 2001 Santro 1 litre. I had a free flow set up which is kind of worn out and i'm looking to revert to stock exhaust system. Problem is that when I got the free flow done, I did not retain the original headers or cat converter or anything .. But its done now.. anyways, can someone give me a list of parts that the exhaust system consist of. Should I buy original from Hyundai or are the parts available in market good enough? How much will the full system from Hyundai cost and how much will it cost in market? Do Stainless Steel headers make any difference if installed with stock system (Fuel Efficiency wise)? All replies are appreciated, thanks.
Deepz is offline   Reply With Quote
Old 14th June 2007, 14:55   #2
n_aditya's Avatar
Thanked: 2,779 Times
What do u mean you did not retain the original headers?
Did you salvage those pipes or bend them as needed for the "new" headers?
BTW an exhaust system consists of :
1. Header
2. expansion chamber
3. intermediate pipes
4. Center muffler (some cars i guess)
5. cat con
6. end muffler
SS headers serve no special purpose except for good looks IMO. A new exhaust system from the manufacturer can cost quite a bit.... almost twice the cost of a full free flow.
Get one from some chor bazar. That would be the cheapest option.
Old 14th June 2007, 15:15   #3
BUSA's Avatar
Why are you going back to the original setup, why not a free flow?
Old 14th June 2007, 15:19   #4
moralfibre's Avatar
Thanked: 6,532 Times
If you are in Bombay now, take a round of Chor Bazaar. There is a totalled Santro (old version) whose exhaust can be salvaged I assume.
Old 14th June 2007, 15:44   #5
Deepz's Avatar
Hi all, thanks for the inputs.. I'm most of the time in indonesia, my sister drives my car now, so i thought that since free flow has become really old and if I have to change only then might as well go back to stock.. but other option is to get a free flow only, but as silent as possible.. maybe one that gives a low-mid range kick, but absolutely muted.. what do you think? do stainless steel headers last longer than normal ones? how much would it cost? Thanks again guys.
Old 14th June 2007, 15:48   #6
Deepz's Avatar
Hi moralfibre , I wont be able to make it chor bazaar as i'm not in bombay. :-(
Hi aditya , actually I just assumed that when free flow is done the headers are changed.. ? are they?
Old 14th June 2007, 16:23   #7
lohithrao's Avatar
Thanked: 163 Times
Deepz you better not think of buying the complete set from Hyundai, it might cost a bomb. OHC's complete set would cost around 35k. my cars exhaust was getting rusted after i heard the price i went for a ffe.
btw how long back you got the ffe fixed? the present one and who did it for you?
lohithrao is online now   Reply With Quote
Old 14th June 2007, 16:33   #8
Deepz's Avatar
Lohithrao, the FFE is over 2 years old.. Dont remember the guys name who did it.. was a friend of someone I know.. 35k for OHC is crazy man.. If costs are such then I guess FFE is still a better option.. Just wanted to know how much would stainless steel cost though..
Old 14th June 2007, 17:21   #9
rjstyles69's Avatar
Thanked: 795 Times
Now I know why I was asked to keep my original OE exhaust .
Same question , why not get an FFE made again? If you want noise immunity then get it done as per your choice without a loud end can.
Yes they are.
Try contacting these chaps also : AutoMECH Engineers
Old 14th June 2007, 17:33   #10
Deepz's Avatar
@ lohithrao : 35k for full set up IS quite heavy man.. i dont remember the guys name who did it, he was someone a friend knew..
@ rjstyles69 : good thing you have kept your originals, as i've just learned, i should have done the same.. didn't know better at that time..oh well, we learn from our mistakes..
I've read a lot about viper being really good with exhausts, i'm just confused whether its 'viper' or 'v1p3r' .. they are 2 different people.. i guess i'll go to him for the FFE.. thanks a lot guys, really helped a lot..
Old 14th June 2007, 18:50   #11
lohithrao's Avatar
Thanked: 163 Times
Yes its Viper who does exhaust, i got it done from him and happy with his job.
Old 14th June 2007, 21:44   #12
aZa
aZa's Avatar
Thanked: 17 Times
Freeflow systems can be muted, but it will never be as quiet as a stock exhaust. The SS headers will be more durable than others.
Old 15th June 2007, 00:36   #13
Deepz's Avatar
Hi Aza, i'm really keen on getting SS headers if cost is not too much.. how much do you think it should cost? under normal driving (no ripping) how long should normal headers last before needing replacement? Thanks..
Old 15th June 2007, 11:06   #14
lohithrao's Avatar
Thanked: 163 Times
Depends on how you maintain it and also if you are in coastal area, then you will have to be little careful. should last you easy 2years atleast.
Old 15th June 2007, 16:16   #15
Deepz's Avatar
Thats the problem, I live on mount mary, above band stand.. stuff gets rusted quite fast because of caostal area.. Thats why i'm interested in SS headers..
Fiat Palio 1.2- Rusted Exhaust replacement: Stock/ FFE?(Cochin) aravindwarrier Technical Stuff 11 28th April 2014 19:05
Help Needed regarding the ZEN Exhaust system xenxer Technical Stuff 2 26th December 2007 22:00
Need Help! Problem after changing to K&N stock filter in Swift ZXi Lotusking Modifications & Accessories 8 26th November 2007 15:09
Help me for Free Flow Exhaust System malvechaitanya Modifications & Accessories 10 24th February 2007 16:58
