Old 18th June 2007, 16:09   #1
k36
k36's Avatar
Thanked: 19 Times
Default Swift ORVM Cowl
Hello there,
I lost my right ORVM cowl yesterday in a dash against tempo coming in opposite side. Just the plastic part covering the mirror from back side is lost. Rest of the assembly as well as the mirror is intact and working.
Now the dealers (2 of them here) say that the cowl is not available separately and I'll have to buy the full mirror costing Rs 1450/-. I just want to check out if this is true.
Has anyone here been able to buy just the orvm cowl separately? If yes, from where? OEM or otherwise? Cost ... ?
Thanks in advance
k36 is offline   Reply With Quote
Old 18th June 2007, 16:17   #2
Surprise's Avatar
Thanked: 272 Times
I too had replaced the entire assembly @Rs.1400/-. But that was before 1.5 yrs.
Iam sure you can get it in some shops where they deal with accident parts.
Surprise is offline   Reply With Quote
Old 18th June 2007, 16:22   #3
abhilashvk's Avatar
Thanked: 31 Times
Yes, my colleague broke the same part of the OVRM when a cycle wala kissed the mirror. Had to get a complete assembly..and then paint it the body colour...I dont know hat price he paid though..
abhilashvk is offline   Reply With Quote
Old 18th June 2007, 16:25   #4
nikkibike's Avatar
Default try car accessory shop!
If you sure bout its "working" status, try getting the fancy-chrome finish ORVM cover in accessory shops and try covering the broken area with it. Guess it will turn cheaper and classy too!!
Dulicate ones are yet to hit the markets I guess!
nikkibike is offline   Reply With Quote
Old 18th June 2007, 16:32   #5
Nope, you dont get the cowl alone. Atleast not in MASS shops. Been through that.
To its credit, the cowl takes a real battering to snap.
ballkey is offline   Reply With Quote
Old 18th June 2007, 16:38   #6
Thanked: 11,067 Times
Unfortunately true. Even if you did get the cover only, you will find that the internal design has changed. In my case, the mirror broke but cover survived but alas, it did not fit the new mirror.
Old 20th June 2007, 11:36   #7
Thanked: 7 Times
I just survived spending this amount for the replacement. A drunkard barged into my left A pillar while i was driving at about 60 kmph. He hit the left ORVM bang and was knocked off. After ensuring he was back to his senses in the hospital with minor injuries, when I returned i observed the ORVM naked without cowling. As luck would have it, the cowling was lying in the dust where hundreds of pedestrians moving around it. I could fit it back without much problem except for a bent inner clip.
I am not sure whether the design of the ORVM is really strong, bec. the cowling is its weak point and complete replacement is so costly.
emkay456 is offline   Reply With Quote
Old 22nd October 2008, 13:53   #8
Thanked: 196 Times
Default Swift - ORVM Shroud broken
Hi all. . . this is my first posting in Team-BHP. I have a Swift vdi which my wife uses and is the apple of her eye. She was driving home from work yesterday braving the monsoon in the crawling trafic of when the left ORVM was scraped on by a MTC bus. She reached home and then to her horror found the shroud alone missing! The car is sunset copper in colour and so are the shrouds. SHe wants the shroud to be replaced. Is the shroud alone available or do I have to change the entire ORVM? Please advise.....
sunsetorange is offline   Reply With Quote
Old 22nd October 2008, 14:38   #9
Bad news is you most probably need to change entire OVRM - Rs 1600. Add to the fact that the design changed internally, so the replacement shroud may not fit!
It happened to me
Old 22nd October 2008, 14:53   #10
theMAG's Avatar
Thanked: 1,574 Times
Yeah - you'll need to replace the entire RVM unit - its an integrated piece. I learnt this last week when a charming 3 wheeler goods-carrier swerved into my path to avoid a pothole on his side of the road, swiped my right ORVM and shattered the mirror while the casing remained intact.
My subsequent descent towards the poverty line : Rs 1400.
Details: New MGA right OVRM at Mandovi Service Station, Bannerghatta Road.
Old 22nd October 2008, 14:58   #11
Ramsagar's Avatar
Thanked: 62 Times
As told by Ajmat you need to replace the entire set.there is one option, check out any maruti surakshaa garrage,if you are lucky you may find them and get them painted.
Ramsagar is offline   Reply With Quote
Old 22nd October 2008, 15:11   #12
theEnd's Avatar
Now that finally explains why there are so many Swifts going around with missing mirror shrouds.
You might be able to get an aftermarket shroud from an accessory store. I've seen a lot of Swifts with shiny chrome-type mirror shrouds. These should be cheaper than the whole mirror assembly. You could also get one of those aftermarket shrouds with built-in turn-indicator lights (although wiring would be a hassle).
theEnd is offline   Reply With Quote
Old 22nd October 2008, 15:14   #13
menonrajesh's Avatar
For Swift, its around 1500/-, though not sure of SX4. Can it be so high as 7000/-?
menonrajesh is offline   Reply With Quote
Old 22nd October 2008, 15:29   #14
vikram_d's Avatar
Thanked: 940 Times
Yeah I have two swifts at home withe the same problem.
The cheap after market things are just shroud covers. They are just covers which are stuck onto the shroud with double sided tape. They cannot be replace the shroud itself.
Old 22nd October 2008, 15:51   #15
This thing keeps coming back, doesnt it?
http://www.team-bhp.com/forum/modifi...orvm-cowl.html (Swift ORVM Cowl)
I wonder what happens to other bigger,broader cars. Dont they suffer the same fa te? Or is it a Swift-only curse?
How to DIY clean the wiper cowl vents? MunnabhaiMBBS DIY - Do it yourself 4 28th November 2015 21:41
Skoda wanted to change cowl for 6K. But only the drain required cleaning Red's Technical Stuff 7 26th October 2011 07:43
orvm and door handle painting binz Modifications & Accessories 1 27th August 2006 01:02
Swift - Electric ORVM pillainp Modifications & Accessories 2 25th July 2006 22:58
