Old 26th June 2007, 17:39   #16
Thanked: 1,172 Times
Interesting...
This attempt to make an in-house headlight washer is going to be an interesting learning for me...
anandpadhye is offline   Reply With Quote
Old 26th June 2007, 17:45   #17
Technocrat's Avatar
Thanked: 2,589 Times
Excellant Idea Kiran & great suggestion Rtec
keep us updated Kiran, if this one is successfull I am sure many people will be getting it done. So all the best
Old 26th June 2007, 17:52   #18
manikjeet's Avatar
Thanked: 110 Times
Originally Posted by moralfibre View Post
Good luck Manikjeet. Make sure you keep the nozzles flexible to turn so that if they do not wash the headlamps they can be used to assault like how me and N_C do. See posts 37 and 43 here - Assault (Red light honkers)
i know about it
its also common in chandigarh
lets hope the the pump has enough power to drive the three nozzle or else i have to get a new pump
manikjeet is offline   Reply With Quote
Old 26th June 2007, 21:42   #19
Mpower's Avatar
Thanked: 1,687 Times
Great idea. I'd say forget the RS and make one of your own.
Use the windsheild washer nozzle, motor and bottle. Pick a nozzle that has a cone spray pattern and use 2 nozzles per headlight. Test it out to make sure its cleaning the whole headlight.
Old 26th June 2007, 21:50   #20
gr8guzzler's Avatar
Thanked: 38 Times
I think you will need a more powerful pump since the pipe running from the reservoir to the nozzles would be pretty long.
Excellent Idea MF.
Cheers!!!
gr8guzzler is offline   Reply With Quote
Old 26th June 2007, 22:03   #21
manikjeet's Avatar
Thanked: 110 Times
Excellent Idea MF.
Cheers!!!
i hope it doesn't need a new pump
will constant a mechanic first
Old 26th June 2007, 22:31   #22
aah78's Avatar
Thanked: 1,746 Times
Originally Posted by anandpadhye View Post
What about the extremely high temperature of the headlight?
Of course this question is not specific to this mod but for any headlight wiper.
Is the wiper rubber special to survive the very very hot glass?
the headlight glass is maybe a few degrees higher than ambient. it doesn't affect the rubber on the wiper.
moralfibre -> washer nozzle's are easily available off ebay. better use these than windshield washer nozzles as you won't spend a whole lot of time getting the angle right. check online automotive parts stores. they'll have nozzles for different makes in stock for cheaper than retail.
needless to say, sharing the pump with your windshield washer isn't going to help with pressure. you're going to need a bigger reservoir. instead of using two seperate reservoirs, ditch your original for a bigger one.
get good quality tubing and clamps - lots of leakage otherwise.
also ditch the idea of fitting W124 wipers. it's not going to be a clean install.
aah78 is offline   Reply With Quote
Buying & Using a Pressure Washer jp1 Modifications & Accessories 995 15th July 2018 11:48
Windscreen Washer problem raja748 Technical Stuff 49 30th January 2018 23:41
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
(DIY) Head lamp washer manikjeet DIY - Do it yourself 34 15th August 2016 15:34
2007 Alto LXi: rear window demister, washer and wiper Ram Modifications & Accessories 2 23rd January 2007 18:06
