| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | Guys any idea how much do the headlight washer modules on the Skoda RS retail for? Is it possible to fit them on the Palio or do they come as a part of the front bumper? I wouldn't mind connecting them the water pump that sprays water on my boot lid glass so that both of them operate in sync.
__________________ Ask not what your country can do for you, think of a way you can make them do it! |
| | #2 (permalink) | |
| BHPian Join Date: Apr 2007 Location: Pune
| Quote:
__________________ Aerodynamically speaking, a bumble bee should not be able to fly, but it does not know this, so it flies. | |
| | #3 (permalink) | |
| Senior - BHPian | Quote:
__________________ Ask not what your country can do for you, think of a way you can make them do it! | |
| | #4 (permalink) |
| Team-BHP Moderator ![]() | That would be a good thing to do moralF. Not sure on the prices, but a cheaper alternative would be to simply purchase the nozzels used for the windscreen on some other car (Esteem comes to mind or even the Palio itself), attach those to the front bumper after getting the angle right. Then simply put a splitter on the existing tube that carried the water, and there you have it. Your own headlight washers that will spray water everytime you spray it on the windscreen. No wiring, no nothing required. The whole thing could probably cost less than 200 bucks.
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ Last edited by Rtech : 26th June 2007 at 15:21. |
| | #5 (permalink) |
| Senior - BHPian | Wow the cheaper Idea sounds better and being smaller than the one that comes with the Skoda, they wouldn't stand in way of my light throw too. Will do this very soon and keep you guys posted. The Palio ones should serve well since they come with three jets in each nozzle. Easier to cover the entire headlamp. Thank you Robeeeeen! ![]()
__________________ Ask not what your country can do for you, think of a way you can make them do it! Last edited by moralfibre : 26th June 2007 at 15:29. |
| | #6 (permalink) | |
| BHPian | Quote:
...wat say![]() | |
| | #7 (permalink) | |
hey moralfibre i think if you get the palio one from the dealer it would cost a bomb but you could look at a the nozzle of the alto it to has 3 jets and it cost me around 30 bucks in the open market
__________________ MANIK NANDA | |
| | #8 (permalink) | ||
__________________ Ask not what your country can do for you, think of a way you can make them do it! | ||
| | #9 (permalink) |
| What about the extremely high temperature of the headlight? Of course this question is not specific to this mod but for any headlight wiper. Is the wiper rubber special to survive the very very hot glass?
| | #10 (permalink) |
| BHPian | one suggestion kiran...do not use the same reservoir and pump(motor) as one motor wont be able to handle all the load...buy a new set of reservoir and motor and place it somewhere in the engine bay....some 10-12 years ago, i had bought the Maruti reservoir and motor for 200 bucks and fitted it on my Padmini windshield..... |
| | #11 (permalink) | |
| | #12 (permalink) |
| Senior - BHPian | A headlamp washer has a very high pressure pump compared to the normal windscreen washer pumps. But if you put the nozzle very close to the Headlamps, then I think the pressure will suffice and hence there won't be a need for wipers. You can also try and source a high pressure pump from Honda or Toyota. Their pumps have a bit more pressure than Maruti/Hyundai etc..
__________________ The squeaking wheel doesn't always get the grease. Sometimes it gets replaced!! |
| | #13 (permalink) | |
__________________ 156.6 db, naa....time is coming to cross it...... | |
| | #14 (permalink) |
| Senior - BHPian | i got on the phone with my mechanic and he says the set(pines and the nozzle) is for max 50 bucks so for two i will pay 100 bucks and then fitting and all he says it will come to around 150 bucks i am getting it done in 2-3 days will keep you guys updated
| | #15 (permalink) |
| Senior - BHPian | Good luck Manikjeet. Make sure you keep the nozzles flexible to turn so that if they do not wash the headlamps they can be used to assault like how me and N_C do. See posts 37 and 43 here - Assault (Red light honkers)
| Thread Tools | |
Similar Threads | ||||
| (DIY) Head lamp washer | manikjeet | Modifications & Accessories | 33 | 31st July 2008 17:39 |
| Windscreen Washer problem | raja748 | Technical Stuff | 8 | 16th August 2007 13:30 |
| 2007 Alto LXi: rear window demister, washer and wiper | Ram | Modifications & Accessories | 2 | 23rd January 2007 17:06 |
| Portable pressure washer available? | jp1 | Modifications & Accessories | 17 | 10th July 2006 11:31 |
| Relay for headlight | Akkiben | Technical Stuff | 7 | 14th December 2005 08:46 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
...wat say
