Old 28th June 2007, 17:45   #1
Default Power window addition for Swift Ldi
Hi Folks,
I am getting a new Swift Ldi and wanted to know if I can add power windows to it ?
swifty is offline   Reply With Quote
Old 28th June 2007, 20:11   #2
CrAzY dRiVeR's Avatar
Thanked: 17,945 Times
Originally Posted by swifty View Post
Hi Folks,
You can have it as MGA from the dealer.
Congrats on the purchase. A real- wise decision, although the waiting periods can be irritating.
Old 28th June 2007, 20:32   #3
mail4ajo's Avatar
Thanked: 248 Times
MGA is reasonably priced. Should be the RD brand. Another option is the Xenos brand. All Maruti OE power windows tend to have problems after some time. Both brands offer only 1 year warranty. MGA would be safer to maintain and service. Plus no crying about warranty by the dealers.
mail4ajo is offline   Reply With Quote
Old 28th June 2007, 22:57   #4
manikjeet's Avatar
Thanked: 109 Times
few days ago i went to check out about power windows for my car from the M.A.S.S
they told me they only do the front and not the rear
meaning if you get it done from them they will only power the front windows
is it true for all M.A.S.S and the price given was around rs5200 and from outside its rs 4800( only front)
manikjeet is offline   Reply With Quote
Old 28th June 2007, 23:18   #5
mail4ajo's Avatar
Thanked: 248 Times
Maruti advises only a front power window retrofitment. Maybe due to the wiring to the rear doors.
Xenos has a 4 door kit with a upmodule. cost about 11K. I personally dont like the kit as the switches doesnt gel with the interiors.
Old 28th June 2007, 23:27   #6
is it the case with Swift???
Its the case with Alto/ WagonR cause they have front power windows only as OE
Old 28th June 2007, 23:30   #7
razor4077's Avatar
Thanked: 252 Times
I've seen Swifts with aftermarket power windows (all 4). Xenos and Autocop are 2 manufacturers. Must be more...
razor4077 is offline   Reply With Quote
Old 29th June 2007, 10:53   #8
shailu's Avatar
Thanked: 17 Times
Fix autocop power window as the switch matches with the interiors
shailu is offline   Reply With Quote
Old 29th June 2007, 18:42   #9
I have fitted autocop with power windows( all 4) for Rs.13,500.Is it overcharged?
neel12345 is offline   Reply With Quote
Old 30th June 2007, 02:10   #10
hellspawn's Avatar
Infractions: 0/1 (10)
a kit for the front two windows costs 4k and is branded as autocop scorpio.i think you might have been overcharged.
but what matters is the quality of the work done.if they havent spliced any wires,and used the connectors provided in the kit,then you have less chances of the power windows malfunctioning as aftermarket power windows are very prone to damage due to water going inside the window sills.
hellspawn is offline   Reply With Quote
Old 30th June 2007, 16:07   #11
Their job is very neat.No wires here and there, all connected neatly and tied together with a little plastic wire. BTW my power windows will not get damaged by water entry because,because,because I have done cavity works on all five doors(dickey included).
Old 2nd July 2007, 12:19   #12
Thanks everyone for the responses. The Dealer is offering 4 windows power for 13000 and front only for 6500.
I have a side Q. I am interested in the reverse assist. Which one is the best to get for the Swift ? The dealer showed me a xenos model which he said was MGA and quoted Rs4200
Old 2nd July 2007, 12:45   #13
DonVilano's Avatar
As far as I know, the 4 door power window kit is only 11k. My cousin had installed a 2 door kit in his Alto and he didn't want to spend 11k for the 4 door one.
Reverse assist on a small vehicle like Swift? Not really needed.
DonVilano is offline   Reply With Quote
Old 3rd July 2007, 10:26   #14
I have been reading on the forums here that the rear view on the swift is a little lacking.
Has anyone here installed reverse assist on their swift ? Any positive or negative feedback ?
Old 6th April 2009, 19:28   #15
Default RD Power Windows
I think its a bit late but for anyone who bumps into the thread now, its suggested you go in for RD auto window closure relay with T-Joint. This does not require tempering with wiring harness of the vehicle. So, no problems with electrical warranty. Costs +200-250 INR extra over and above normal relay prices but its worth every penny that goes into it+ 1 year warranty. Website: Rajatdeep Overseas Pvt. Ltd. : One Stop for all your Automobile Accessories
prateekool is offline   Reply With Quote
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Swift Ldi - Power Windows, Central Lock , Fog Lamps- Pls help nikunj_cal Modifications & Accessories 16 16th August 2008 23:28
Maruti Swift Vxi or Ldi? EDIT: Bought Ldi Gurudatta Nayak Hatchbacks 27 14th May 2008 20:09
is warranty void on installing power window in swift Lxi?? sameer551 Modifications & Accessories 7 7th November 2007 09:23
