Old 5th July 2007, 23:09   #1
paras211's Avatar
Thanked: 57 Times
Default Hot Cam for Corolla 1.8
how much do cams help??
i ve got a corolla with an intake and an exhaust ??
how much of a gain should i notice?
Stage 1: 264/264 duration, .379/.367" Lift
Stage 2: 272/272 duration, .396/.396" Lift
worth 20000???
paras211 is offline   Reply With Quote
Old 5th July 2007, 23:49   #2
Thanked: 11 Times
Hey paras..
Which intake and exhaust do you have ? I think for stages there are few other things to do also. you cant just change cams for performance.
Mugen_Power is offline   Reply With Quote
Old 5th July 2007, 23:51   #3
razor4077's Avatar
Thanked: 258 Times
Go through this thread. I think it's got what you're looking for:
http://www.team-bhp.com/forum/modify...-your-car.html (ARTICLE: How to Modify / Tune your car)
razor4077 is offline   Reply With Quote
Old 6th July 2007, 00:53   #4
veyron1's Avatar
Thanked: 38 Times
You could expect a gain of about 10% with 1. Stage 1's giving you lift of about 9.6mm I/T & 9.3mm E/X.
Supposedly 15% with stage 2. Lift of about 10.05mm at I/T & E/X. But I don't know if stage 2 would work great at 270 degree lift angles, for a Corolla. Corolla's factory tuned for midrange, not top end.
Erm...Jeetu bhai? Keshav bhai??
veyron1 is offline   Reply With Quote
Old 6th July 2007, 07:58   #5
viper's Avatar
Thanked: 9 Times
worth 20000???
You are getting a pair of cams in that price?????????????. Which brand. You can expect a 7-9 % gain if setup correctly.
Viper
viper is offline   Reply With Quote
Old 6th July 2007, 09:06   #6
ananthkamath's Avatar
Thanked: 63 Times
why is everyone talking in terms of percentage gain? How can you even quantify an engine component's effect in such general terms?
ananthkamath is offline   Reply With Quote
Old 6th July 2007, 10:44   #7
ported_head's Avatar
What are stock cam specs? Also if it is only advertised duration, then there is not much you can deduce from it.
ported_head is offline   Reply With Quote
Old 6th July 2007, 19:31   #8
veyron1's Avatar
Thanked: 38 Times
Ananth, cams that offer 10mm of lift with 270 degree duration & above would be classified as fast cams, and they usually bump up the output by a given percentage W.R.T engine capacity, if combined with appropriately rated springs, followers, etc....we cannot specify an "X" cam for "Y" bhp, right? Hence the approximate figures.
Old 6th July 2007, 20:07   #9
paras211's Avatar
Thanked: 57 Times
@mugen i ve got a k and n short ram intake and a 4 2 1 crappy automech header and
i didnt get you elaborate please
@viper the price is bout 17k 18k in the us i may be having a friend flying in from us so...and its crower
will the springs have to be changed also???
Old 6th July 2007, 20:45   #10
v1p3r's Avatar
Thanked: 27 Times
Your headers will be useless with a 272. You will probably need some headwork done to fully appreciate the cam. And maybe a rev-limiter change.
I think the stock Toyota valvetrain should be upto the task.
Old 6th July 2007, 20:55   #11
paras211's Avatar
Thanked: 57 Times
@ v1p3r so a 4 1 header would be suitable right?
headwork??
Old 6th July 2007, 22:30   #12
Psycho's Avatar
Thanked: 95 Times
with a 270 you wont need to change springs but try the current headers and see if they are too far out before changing them. Would also mention the 270 would be the best bet for a daily drive you might face a few idling issues though.
Old 7th July 2007, 17:00   #13
paras211's Avatar
Thanked: 57 Times
the stock ecu will work or i ill need some thing? would a device that controls the afr and and the vvti timing be enough or i would need a standalone? is it possible to get the rev limiter off in the corolla? right now the peak power is just before the limiter you can feel the power dip .
Old 7th July 2007, 17:01   #14
paras211's Avatar
Thanked: 57 Times
would this be ok
Brand new from Power Enterprise, the CamCon unit controls numerous Toyota/Lexus and Honda/Acura models equipped with variable valve timing (iVTEC or VVTi or VVTLi). It allows the user to modify valve timing and fuel mixture at 500RPM increments throughout the rev range. It also allows the user to change the crossover point on VTEC vehicles only. Take full advantage of your other mods by tuning your VVT, iVTEC, or VTEC and fuel mixture for maximum power.
Old 8th July 2007, 01:48   #15
BUSA's Avatar
What you are talking about is something similar to a Vtec Controller. Pointless on a car with stage one mods.
A red hot rapid install in a red hot (Skoda) Rapid Samridh In-Car Entertainment 28 18th August 2013 00:49
Enfield Bullet:Cam gear backlash and solutions including adjustable cam spindles deepclutch Motorbikes 73 17th December 2008 00:47
All new Corolla coming soon EDIT: Corolla Altis now Launched extreme_torque The Indian Car Scene 295 19th September 2008 23:48
corolla sucking hot air paras211 Modifications & Accessories 1 20th December 2006 22:45
