Closed Thread
Old 16th July 2007, 14:32   #46
amitoj's Avatar
Thanked: 1,691 Times
Hey Congrats Khaadu!
Seems ex670c knows his stuff... sadly he is in Chennai and you up in the mountains!
Enjoy the ride.
Amitoj
amitoj is offline
Old 16th July 2007, 14:45   #47
Khaadu, Congrats on your decision. You are getting a decent VFM vehicle.
//Please dont listen to comments from those frustrated people who owns 407 engined trucks and relatively flop Maruthi models.//
well, regarding modifications,
1. Good set of tyres and alloys
2. Performance filters (K&N or Greens)
3. Set of Rallye 3000's.
4. A reverse camera.
5. Bull Bar
chanapli is offline
Old 16th July 2007, 14:58   #48
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
You sense of humour (rather lack of it) shows!
Khaadu, you must totally listen to chanapli, lock this thread and PM him for further advice.
mclaren1885 is offline
Old 16th July 2007, 15:02   #49
Originally Posted by mclaren1885 View Post
You sense of humour shows!
Sorry to go out of subject.
Anytime better than giving cheap suggestions like below though.
1. Tractor tires, two smaller fronts and two LARGER rears.
2. Zillion fog lamps.
3. Seed sowing machine.
4. Plough connected to the rear end (not your's)! If you have enough torque you can do wheelies too. Now wouldn't you LOVE THAT!
5. Paint it green (no additives nothing, completely natural) .
6. Plonk in a kennel for shadow at the rear (let him also enjoy his stay in the car/suv/tractor or whatever that is you bought).
7. Sprinklers jutting out of all sides with a small size sintex tank on the roof.
8. Pesticide spraying machine ala Nitrous purge kits.
chanapli is offline
Old 16th July 2007, 15:04   #50
Thanked: 35 Times
Chanapli, read my post below. I have nothing more to say. Maybe you need to get a life and stop calling people names.
Old 16th July 2007, 15:14   #51
khaadu75's Avatar
Thanked: 11 Times
Chanapli , I do agree with you TOTALLY here ... what do these kids with lil cars know about which is the REAL SET of WHEELS ... !!!
As for these cheap mods suggested by them lil kids .... actually they must be jealous that their lil toys can't handle all these things .
Bull Bar with Hellas ..... just need a different kind of bull var -- any suggestions ???
khaadu75 is offline
Old 16th July 2007, 16:01   #52
Thanked: 53 Times
Yes, you are right but In a jeep modified with SOA setup I had problems at high speeds [ 80 kmph & above] it tends to be unstable, so had to go back to the old setup [m&m 750 DP soft top]....than modified the rear setup with springs from safari [removed the leaf springs,this was good] tried to get my hands on an IFS system with 4wd ,but could not find it than [sold the jeep about 5yrs back it was my dad's]. Now my friends 540 DP is the test bed and we have got IFS from the scorpio on it..still have to find the transfer case and front diff,axles,etc.
but with this setup it's comfier and much easier to handle than the old setup at high speeds.
The Bolero setup is a compromise between comfort and handling, The IFS can be made to work fine by using spring out of some other vehicle like tata, Force, etc. trial and error method as the weight of the vehicle is different from 540 DP and 750 DP.
If the vehicle is used on roads also then the IFS is better choice than solid axle, Experience with both the setups ,when overtaking with one wheel off the road and one on the road the jeep is much more controllable with IFS.
BY the way most of the good 4x4s have independent suspension....Hummer,Range Rover,Judo,even some of the big 4x4 trucks have them......reason better body control over uneven surfaces. with solid axle the body is at a much higher angel if one wheel is on a higher point than the other wheel as compared to Independent setup.
One thing is that solid axle setups are much easier to modify [big lift ] for big tires, and can handle a lot of power with almost no modifications and cheap to setup as compared to Independent suspension.
I personally like the IFS.
By the way nice Photos in the gallery, from where did you get the drivetrain setup[gear box,dana 44s,transfer case,etc]
dinar is offline
Old 16th July 2007, 19:48   #53
Please.. Someone is asking for help.
If I dont like / know a vehicle, I better keep quiet. Well, that is me.
FYI, I have done 71,000Kms on my 2WD 2004 Bolero sportz, and believe me it is a fantastic vehicle for that price. Of course one need to learn how to handle it as the way it is (like too sensitive power steering / soft suspension). And the maximum I spent on repair was within Rs 15K (excluding regular oil/filter changes and Tyre/Alloy modifications). I mean what else one need for his hard earned money?.
chanapli is offline
Old 16th July 2007, 20:55   #54
5. Bull Bar
Yeah right!! Chanapli(kind of rhymes with a certain chaplin )
I'm sure Saazid should really really(!?) go in for the reverse camera(rofllllllllllllllllllllllllllllll) and the performance filter(still roflllllllllllllllllllllllllllllllllllllllllll)
that was actually priceless. no offence though
rev
rev_hard is offline
Old 16th July 2007, 20:57   #55
Thanked: 35 Times
I did not want to carry on this argument, but just to set the record straight.
Did I ever mention anywhere that I do not like the vehicle? Well I am not you, neither do I wish to be. Also, do you have any clue on the kind of relationship that I share with Khaadu or a million others ON & OFF the forum? I suggest you do a background check once before shouting your mouth off. We know each other quite well both ON & OFF the forum and often find making fun of each other thus bringing some humour into our lives (and on the forum) too. This was just one such instance.
I sincerely request you to stop being so judgemental and come to conclusions. We have fun at times and at times I have sat for hours together with khaadu explaining him the technical details. You can PM him for the details.
The fact is I appreciate his purchase, but you failed to see the humour in my posts and the subsequent few by others too. You need to lurk around a bit more to know how this works.
I'm off from this pointless debate now. I suggest you get back to topic or PM me for further details. We have a very good discussion going on between dinar and ex670c. Either add to the fun or the tech part and stop trying to be a party pooper.
Old 16th July 2007, 21:14   #56
Hi Saazid,
Sorry for not looking up your previous posts, but, is your new jeep a hard-top/soft-top/forward-4-cab version?
I'd suggest a tyre upgrade up-first, followed by an interior upgrade. Basically, better bolstered seats with grab-handles retro-fitted on the top part of a-pillar. looks neat IMO. Also, IIRC, the mahindra jeeps come with steering wheels the size of a bath-tub. Think of replacing that too.
Will post if have any other suggestion.
Oh, and i too once had the pik-up version(forward-2-cab - soft top - with all glasses almost painted black(really really dark tints)) of the Gypsy King, white in color. Still dream about it and those days sometimes .
Cheers to your new purchase.
rev
p.s.: if your reputation as the true-blue KF lover is indeed true, a car fridge should be the first upgrade !!
rev_hard is offline
Old 16th July 2007, 21:17   #57
khaadu75's Avatar
Thanked: 11 Times
Dinar @ Are you by any chance part of the Jeep club that does off roading regularly in Goa ??? Ive seen some pics of a Ferrari yellow gypsy that turned turtle in a stream and almost got swept away had it not been for the ropes !!!
I still havn't collected the Bolero .. will be doing so tomorrow sometime . Unfortunately the Euro III doesn't come with the option of a 4WD , though I cud have gotten it in the EUro II but then the Euro II can't be registered in Delhi ... thus ending up with a 2WD .
Just drove the vehicle for about 10 kms .... eats up the bad roads pretty well .. engine seemed ok but can't say much yet as after being used to the Swift it will take me some time to give the right feed back about the engine and its capabilities . Another BIG flaw which I felt was the positioning of the gear lever -- reminded me of the positioning of the lever in the Contessa -- AWKWARD !!!
It comes shod with 215/75 R 15 ..... seemed to give decent grip though an upsize should be a bonus .
Ill let the vehicle clock about 10000 kms on the odo and then start to think about what all can be done .... keeping in mind that it wud be used as a daily machine around town as well . For the Macho look --- Im looking out for a decent and solid bull bar to give it some character at teh front ( any suggestion wud be welcome here ) and a set of lights along with the Bull Bar and then maybe something for the roof .
Lets see how it goes ......
I am a true blue KF luver ... but Id rather let the others do the chilling for me as that space is reserved for Shadow -- also the Bolero has come into teh family so that it may go around doing the rounds at 4 am -- DELIVERING FRESH MILK !!! Now you know why I went in for the BOLERO -- mix of work and pleasure
khaadu75 is offline
Old 16th July 2007, 21:18   #58
Thanked: 35 Times
Its not a rumour, infact KF must be surviving solely on him only . Now why didn't I think of the fridge thing before?
Old 16th July 2007, 22:06   #59
Mpower's Avatar
Thanked: 1,687 Times
Never liked a Bolero until I saw this.
https://www.team-bhp.com/forum/india...cture-485.html
Mpower is offline
Old 16th July 2007, 23:44   #60
some bullbar designs:
^^ Slightly blingesque.
^^ most sober looking but still MEAN!
^^^^ GETTHE#E((OUTTAMYWAYNOWesque. This might require Arush's help to procure but WoW!!!
rev_hard
p.s.: i know the bullbars look great AND that the bullbars AND the reference 4x4's are not available in India.. but whats the harm in dreaming. hehehe
rev_hard is offline
Closed Thread
Bolero XDP Engine Vs Bolero DI Turbo Red Liner What Car? 34 30th September 2015 21:37
Experience of buying a used Bolero. And modifications Phase 1 AslamHussain Test-Drives & Initial Ownership Reports 69 20th February 2012 02:09
Bolero Mid Row Modifications B_T SUVs, MUVs & 4x4s 7 17th April 2010 20:41
Modifications for Gypsy King - Does the sequence of modifications matter? khan_sultan Modifications & Accessories 18 6th September 2009 14:02
Modifications for Bolero Sportz 2004 BolBolero Modifications & Accessories 11 28th November 2008 18:11
