Old 20th August 2007, 18:29   #46
rocksterraghu's Avatar
Thanked: 95 Times
Originally Posted by CARtik View Post
hydra
whats the Nertz device on your door? some kind of speaker equipment?
It's "Hertz" and it is a crossover, a part of the component speaker kit used to channel the right frequencies to the tweeters and Mid-basses.
Old 20th August 2007, 20:22   #47
I agree. Not only should the stereo controls be on the steering wheel, but a button for the horn should be as well.
After they started putting airbags in the middle of the steering wheel, why keep the horn control in the same place as the airbag? Think about an emergency incident: you'll normally hit the horn. If you hit another vehicle the airbag will go off while your hand is still on the horn control, thereby possibly ripping off your hand.
caliper is offline   Reply With Quote
Old 21st August 2007, 12:09   #48
wanderernomad's Avatar
Thanked: 804 Times
Originally Posted by suren181 View Post
Hello guys, would anybody be able to tell me where I could pick up these controls for a JVC DVD HU which did read steering remote ready? Would the interface run on Infra or does it involve wires? Dumb question but had to ask.
Check out the JVC RM RK-39. I am getting one for myself and will let you know once I have it installed.
wanderernomad is offline   Reply With Quote
Old 21st August 2007, 12:47   #49
thanks 'ram' and 'hydrashok' for the info and pics.
where can i get this,for how much and can i do a DIY install?
thanks a bunch guys!
doctorkats is offline   Reply With Quote
Old 21st August 2007, 13:40   #50
Ram
Ram's Avatar
Thanked: 149 Times
What a thought! I agree with you completely.
Remembering cars from my past, I can think of at least four cars that did not have the horn button on the steering wheel-boss.
My 1977 Ford Taunus had the horn button on a stalk.
My 1979 Ford Mustang had the horn button on a stalk.
My friend's 1969 Ford Mustang Mach-1 had a "rim-blow" steering wheel. The Mach-1's steering wheel had a thin metal strip on the inside of the rim, which sounded the horn when pressed.
I had upgraded by 1988 Mahindra MM-540 with the combination switches of a newer model. The new combination switch had the horn button on the light switch stalk too.
Does anybody know any newer cars that don't have the the horn button on the steering wheel-boss?
Ram
Ram is offline   Reply With Quote
Old 21st August 2007, 14:47   #51
Ram,
If I remember right the Opel Astra [was that the name?] had the horn on a stalk. Took a bit getting used to.
deepakvrao is offline   Reply With Quote
Old 21st August 2007, 15:13   #52
bottle's Avatar
Thanked: 138 Times
i think peugeots also had horn on the stalk
bottle is offline   Reply With Quote
Old 22nd August 2007, 08:51   #53
hydrashok's Avatar
You can buy it fom any Blau showroom. They will install it for you for no additional cost. It runs to 1700/- or 1800/-. The model no. is RC-10, I think. You'll need to confirm compatibility with your HU (I think all models, post 2004 are compatible).
Installation takes just a few minutes. The Remote needs to be clipped to the steering wheel, the IR sensor's wire needs to be plugged-into the HU's back, and the sensor needs to be stuck on the dash (or between the steering wheel and the instrument console) and that's it.
I guess it is real easy to DIY too (the install, I mean).
Old 22nd August 2007, 12:07   #54
kaushik_s's Avatar
Thanked: 156 Times
Is the Blaupunkt RC-10 available in grey market ? if so what's the price?and it's just a small mod so I think going for grey is ok here ;-)
kaushik_s is offline   Reply With Quote
Old 22nd August 2007, 14:02   #55
Thanked: 804 Times
I got a JVC RK RM39 for about 700 Rs. Will posta pic soon but its almost similar to the pic posted above.
Old 22nd August 2007, 15:04   #56
suren181's Avatar
Finally I see one response on a JVC. wander, I wonder if you could as mentioned please post more details on this steering remote alongwith the pic.
suren181 is offline   Reply With Quote
Old 23rd August 2007, 09:14   #57
revtech's Avatar
Thanked: 35 Times
this is what i have on my pontiac and something all manufacturers should do...makes it all so much easier...
rev
revtech is offline   Reply With Quote
Old 23rd August 2007, 10:11   #58
Thanked: 804 Times
@suren I will do it very soon n send them to you. But look wise scroll up there is a pic of a Pioneer remote (I think). Mine is very similar to that. For a detailed pic and specs google JVC RM RK-39 and a few pages will come up. Check them out too.
Old 23rd August 2007, 11:37   #59
thanks hydrashok!will post a pic when its done.
Old 23rd August 2007, 12:38   #60
saumil's Avatar
Lightbulb
Is the pioneer steering remote compatible with other make audio systems? like alpine in a NHC?
saumil is offline   Reply With Quote
DIY: Steering mounted Audio Controls. Ripper DIY - Do it yourself 51 30th January 2017 09:10
Stock Steering Wheel with Audio Controls Connected to After Market Headunit? Epic In-Car Entertainment 34 24th July 2014 12:36
Polo with bluetooth HU & steering audio controls spotted edit:1.5L, 94bhp Diesel also Arkin evoisrevo The Indian Car Scene 183 4th September 2012 22:53
