Old 29th July 2014, 12:01   #31
deetjohn's Avatar
Thanked: 8,000 Times
Default Re: Rain repellent..how effective is this
I bought Formula 1 Glass Cleaner With Rain Repellent from ebay. Its easy to apply and makes the life of wipers very easy. The water beads and one wipe will leave the windscreen with no streaks or water marks. But I could see a bit of haze during the night which is affects visibility when the oncoming traffic is on high beam. So, not recommended for night use. Its perfect for windows as the beads will roll off when the vehicle gathers speed.
http://www.ebay.in/itm/Formula-1-Hig...-/171314645133
deetjohn is offline   Reply With Quote
Old 14th September 2016, 16:57   #32
IndigoXLGrandDi's Avatar
Thanked: 161 Times
Default Visibility Problem through ORVMs in Rains due water droplets on them and Door Glasses
Mods, please move this to appropriate thread if required (Searched but could not find relevant thread or may be my Search Terms were not accurate to find one)
There would be many here (I guess ) who might be facing problem similar to mine. So what exactly is the problem?
When the rains pour, the Door Glasses and ORVMs get wet along with the Front and Rear Windshield. There are Wipers for Front Windshield as well as Rear Windshield (Though Rear Wiper is available on Top-End Trim only) to clear the water droplets.
But what about the water droplets on Door Glasses and ORVMs.
Okay, some cars have heating ORVMs. What about the cars which don't have this luxury?
The water droplets affect visibility by a great margin as seen through the below pictures-
What can be done to clear the water droplets from Door Glasses and ORVMs?
IndigoXLGrandDi is offline   (3) Thanks Reply With Quote
Old 14th September 2016, 17:06   #33
dezrskb's Avatar
Thanked: 121 Times
I haven't tried it but have an idea. I have been watching videos on YouTube about applying wax to front windshield (same paste wax you apply to metal parts). I guess same should work on driver side glass and ORVM too. In absence of Wipers only option is to make water bead off logically. Also heating the mirror is no good as it helps only when it fogs. Not when so many water droplets are on it I feel
dezrskb is offline   Reply With Quote
Old 14th September 2016, 17:09   #34
shady_lawyer's Avatar
Thanked: 288 Times
Default Re: Visibility Problem through ORVMs in Rains due water droplets on them and Door Glasses
Roll the window down, wipe the mirror, roll the window up. The rolling will take care of the water on the window glass itself I do this all the time, my right hand and sleeve does get wet but what choice do we have?
Also try rubbing some tobacco on the glass rumor has it that it helps in repelling water. Atleast, you'll have a really cool reason to buy ciggys!
shady_lawyer is offline   Reply With Quote
Old 14th September 2016, 17:11   #35
Kaumad's Avatar
Thanked: 153 Times
I have used Glaco water repellent in the past.
https://www.amazon.com/JDM-Chemicals.../dp/B003B2UOX2
It is quite effective for the first few days of usage. Water droplets effortlessly roll off the surface. Significantly improves visibility.
The challenge is simple - as you wipe your car every day / morning, the effectiveness reduces. Unless you have a dedicated parking space and you can manage to have a separate micro fibre cloth to wipe the glass every morning, the effect wears off soon.
I live in an apartment and I cannot expect the cleaner-boy to use a separate cloth to wipe the glass alone on my car.
As a product, it is indeed effective. Maintenance, unfortunately in India is a challenge.
Kaumad is offline   Reply With Quote
Old 14th September 2016, 17:22   #36
libranof1987's Avatar
Thanked: 4,087 Times
There's not much you can for the OVRMs but the windows: turn the a/c temp. to heat and direct the outward blowers (the ones on the extreme ends of the dashboard) towards the windows. Although not significantly and not immediately, but there will be some respite.
libranof1987 is offline   Reply With Quote
Old 14th September 2016, 17:26   #37
lamborghini's Avatar
Thanked: 1,642 Times
Try using RainX or a similar product. I used them on the Skoda Laura, and driving has been a breeze in the monsoons as the water drops just roll off, especially as speeds pick up.
lamborghini is offline   Reply With Quote
Old 14th September 2016, 17:39   #38
mpksuhas's Avatar
Thanked: 4,099 Times
Clean your ORVM's and window glass using any shampoo / glass cleaner used for windsheld. This will help in water rolling off the glass and not causing much of obstruction. Useful especially in night when situation is compounded due to headlight from vehicles following you.
mpksuhas is online now   (2) Thanks Reply With Quote
Old 14th September 2016, 17:49   #39
Sree73's Avatar
Thanked: 763 Times
There is a home grown technology for the ORVM water issue. Cut a potato and rub the cut portion on the ORVM glass before you start the journey during the monsoon season (This was suggested by one friend and I had tried couple of times). This will act a water repellent to some extend in the ORVM. The window glasses, as shady_lawyer has suggested, roll down / up and it will take care to a great degree.
Sree73 is offline   Reply With Quote
Old 14th September 2016, 18:02   #40
Want to know another one? The driver of our school auto, then tempo and then bus had this habit of washing down the windshield with tobacco: he'd smear it across the pane and then wash it off. Even in heavy rain, the water just trickled down.
libranof1987 is offline   (3) Thanks Reply With Quote
Old 17th July 2017, 21:35   #41
Thanked: 756 Times
Infractions: 0/1 (9)
Can these rain repellents be done by an untrained person? Or does it required some expert hands. I made an inquiry and that chap said the procedure is to do a "water mark removal" first & then do the "rain repellent coating".
sachinpk is offline   Reply With Quote
Old 21st October 2017, 22:43   #42
Dr.Naren's Avatar
Thanked: 7,891 Times
Maruti Suzuki has got this new product from Japan. It is priced at Rs 450. It helps in repelling water and also reduces the glare at night.
Initial impressions are good and it's working as claimed. Let's see how long it would last
Dr.Naren is online now   (4) Thanks Reply With Quote
Old 22nd October 2017, 00:49   #43
theexperthand's Avatar
Thanked: 1,223 Times
I have used Proklear Nano earlier and it was good - but unfortunately I had to change the front glass due to a stone hit, so I could not test the longevity.
I was thinking of buying it again, but this one looks more easy to apply.
Can you please let me know few details:
Is it a one time application pack? Or, can we use it for multiple times?
Did you buy it from the ASC, or from Maruti genuine spare parts shops?
--Anoop
theexperthand is online now   Reply With Quote
Old 22nd October 2017, 02:01   #44
Leoshashi's Avatar
Thanked: 14,626 Times
I guess Doc has got it from the showroom. It should be easily available in MGA section. Having said that, since it has a part number too, it can be ordered from both ASC/MGP stores.
Shashi
Leoshashi is offline   (3) Thanks Reply With Quote
Old 22nd October 2017, 02:51   #45
Captain Slow's Avatar
Thanked: 664 Times
Guys 2-3 coats of cheap colin glass cleaner does the same thing as these expensive big brands! Been using this for ages and really good results, I will try and post a video of the results.
Captain Slow is offline   (1) Thanks Reply With Quote
Which is more effective Turbocharger or Supercharger ? Shan2nu Technical Stuff 120 25th February 2015 13:34
Rain, rain & even more rain...at Chandipur, Orissa gmhossain Travelogues 11 8th November 2014 22:46
Trip De Goa - Rain, More Rain traveloholic Travelogues 43 3rd November 2009 10:34
How effective is the auto-cut mechanism of the fuel service stations? Zappo Technical Stuff 35 27th March 2009 14:34
