Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 15th June 2008, 11:04   #346 (permalink)
HPP
Originally Posted by autopsyche View Post
HPP, right now stock sidemounts, ill be upgrading to the FMIC in the second phase of upgrades (sometime next year) alongwith bigger turbos and more fuelling. No money for that yet!
Cool, as long as you got it under control.. just wanted to throw out a bit of caution.
HPP is offline   Reply With Quote
Old 15th June 2008, 11:59   #347 (permalink)
autopsyche's Avatar
Yeah i know what you mean... although the stock sidemounts have been proven good for upto 400awhp, im sure itll be safe to run them here for the time being. We have another car which is running stock sidemounts and pushing close to that figures, never had any issues.
__________________
"I drive a Mitsubishi 3000GT, and I live a 1/4 tank at a time... For those 50kms or less, I'm free."
autopsyche is offline   Reply With Quote
Old 15th June 2008, 12:32   #348 (permalink)
badboyscad's Avatar
@rohan: I have no idea about how and where a side vent for an intercooler will be. Are the side mount ICs located on both sides of the front bumper instead of being at the center??. Anyways, i've quickly added some side vents but i believe these type of side vents mainly serve the purpose of venting out hot air from the engine bay.
PS: someone please post some pics (or links) of car with sidemount intercooler and vents
__________________
Im not the Best but im not like the rest
badboyscad is online now   Reply With Quote
Old 15th June 2008, 22:31   #349 (permalink)
rohan_fonseca's Avatar
Nope thats not it. Though the pics looking super cool. Vents on the bumpers. Am i right Arush?
rohan_fonseca is online now   Reply With Quote
Old 16th June 2008, 01:51   #350 (permalink)
furioussphinx's Avatar
Something like the slits or gills of fish?
__________________
...Go Hard or Go Home...
furioussphinx is offline   Reply With Quote
Old 16th June 2008, 19:57   #351 (permalink)
abhik's Avatar
Mesh Grill is what works for dual side mounted ICs(If its near the bumpers.), Thats what i think!
__________________
ABHIK
<<<If everything seems under control, you're just not going fast enough>>>
abhik is offline   Reply With Quote
Old 18th June 2008, 21:54   #352 (permalink)
autopsyche's Avatar
The vents have to be in the front grill on either side of the centre mesh.
__________________
Old 18th June 2008, 23:28   #353 (permalink)
abhik's Avatar
Arush why dont you go in for a larger single IC on the front, i guess like HPP mentioned, the ones available aftermarket and fabricate it to your needs(FMIC). Would'nt cost of 2 side mounted IC be equivalent to 1 FMIC?
__________________
ABHIK
Old 1st August 2008, 13:01   #354 (permalink)
autopsyche's Avatar
abhik, sorry for the late reply, but the single fmic setup would be more expensive in this case as it involves a complete change of piping as well (100% aftermarket).... the stock 2 x side mounted ICs with piping are considerably cheaper, and its not as if they lack in performance either so the gain vs cost is not justifiable unless im putting much bigger turbos.
Anyhow, the good news is that i have all the parts in my hand! And would you belive it, among 160kgs of engine parts i forgot to order new piston rings? Now thats downright dumb on my part.. hopefully they should be here in time by the time i open up the engine. So the TT conversion officially begins now.
__________________
Old 4th August 2008, 10:36   #355 (permalink)
abhik's Avatar
so finally they are through from customs!! Good! i am paying you a visit on wednesday so maybe i would get a look at the goodies!!
BTW the colour that you told me the other day is finalised but are you ready to disclose it? I bet Badboyscad has his hands itchin to do a photoshop trick.
__________________
ABHIK
Old 11th August 2008, 03:46   #356 (permalink)
autopsyche's Avatar
Alright so here is my part list that has been on the shelf for a few days now, some of it has aleady been installed, rest are waiting for the car to be stationed in the workshop...
Twin Turbo Conversion Parts:
TD04 9B Turbos x 2
Turbo Oil & Water Lines
Stock Intercoolers x 2
All Turbo Piping
Intake Plenum with Sensors
Oil Cooler & Pipes
Radiator Assembly
Exhaust Manifolds
ECU & Wiring Harness
Fuel Pump & Regulator
360cc Injectors
8.0:1 Pistons & Rods
Forged Crankshaft
Engine Mountings
General Maintenance Parts:
Driveshaft Carrier Bearings
Wheel Hub Assemblies with Bearings
Piston Rings & Engine Bearings
Engine Belts & Gasket Set
OEM Fuel & Oil Filter
Performance Upgrades:
AEM Tru Boost - Electronic Boost Controller
TurboXS RFL - Blow Off Valve
Scanmaster - Tuning Tool
Innovate LC1 - Wideband O2
AP Racing Front & Rear Brake Pads
Green Cotton Powerflow Air Filter
Magnaflow 3" Race Series Mufflers x 2
Hopefully, work shall start very soon!
__________________
Old 11th August 2008, 10:46   #357 (permalink)
abhik's Avatar
This one is going to be a killer!
__________________
ABHIK
Old 12th August 2008, 00:44   #358 (permalink)
HPP
I didn't realize you were going to be doing rod/pistons. Are you doing ARP head studs and some aftermarket(probably Cometic) head gaskets? If you need help getting these.. I can get you them.
Old 12th August 2008, 02:11   #359 (permalink)
v1p3r's Avatar
Forged Crankshaft
Engine Mountings
What sort of boost are you planning to run? 8:1 is a rather low comp ratio! And why the change in mounts?
__________________
Peace is a lie, there is only passion.
Old 12th August 2008, 03:02   #360 (permalink)
nishant_kingpin's Avatar
Excellent idea on the red. The time taken will be agonizingly long for us curious beings . Hope you can turn this around faster before most of us land up at your facility to give a helping hand with an idea of reducing turn around time
nishant_kingpin is offline   Reply With Quote
Thread Tools
1993 Mitsubishi 3000GT VR4 - 400bhp Monster! autopsyche Super-Cars & Imports in India 65 23rd October 2007 05:13
1996 Mitsubishi 3000GT SR autopsyche Modifications & Accessories 77 11th September 2007 22:02
Autopsyche's Mitsubishi 3000GT ICE... gunbir Sound Off and Show Off 50 11th April 2007 18:22
autopsyche autopsyche Introduce yourself 6 26th December 2004 22:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
