Old 26th July 2007, 21:25   #16
1100D's Avatar
Thanked: 2,503 Times
Good to see people going the padmini way rather than getting just another small car. But let me warn you, Padmini remains trouble free, only at the hands of a knowledgable owner and most garages try to do a con job on the owners.
Why do you need the engine swap? Just to get a feel of what you are looking for.
There is BEHRAM.DHABAR (t-bhpian) an ex-PAL person and knows every nut on the Padmini. Contact him.
And yes, our 1100d is very reliable and has never let us down. It talks.
But OEM parts are getting difficult to come by with every passing day . The fake parts dont last. For AC applications dont look at anything other than an S1.
1100D is online now   (1) Thanks Reply With Quote
Old 27th July 2007, 01:09   #17
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by kettavan View Post
Esteem engine can just propel the wafer-light esteem.
The padmini will do good with the conti engine and the 1.8s inherent torque.
If the esteem is wafer light, so is the padmini. a conti engine on a padmini would make it crumble.
Old 27th July 2007, 01:11   #18
v1p3r's Avatar
Thanked: 27 Times
You could put in a V6. It's something I've thought long and hard about. A nice V6 with 150 hp and 20 kgm , in a RWD under 1 tonne. Should be a hoot.
Old 27th July 2007, 01:43   #19
Thanked: 20 Times
Tvpm had few fiats with diahatsu diesel engines. It produced 65 bhp and had 3 cylinders. And there was a man who had great knowledge on doing these things, sorry to say that he is no more.
You will have to go as far as coimbatore to get it done properly . And in coimbatore you can source toyota 1.5 td diesel engine( similar to what manikjeet has for his zen) also.
swathyd is offline   (1) Thanks Reply With Quote
Old 27th July 2007, 03:21   #20
1100D's Avatar
There are a few Padmini's already running with conti engine. Its a different matter that , those require expertise to make.
1100D is online now   Reply With Quote
Old 27th July 2007, 03:32   #21
Mpower's Avatar
Thanked: 1,687 Times
Esteem engine wont fit. Gypsy King engine has possibilities.
Old 27th July 2007, 03:58   #22
ananthkamath's Avatar
Thanked: 63 Times
Both have the same block.
ananthkamath is offline   (1) Thanks Reply With Quote
Old 27th July 2007, 06:05   #23
Mpower's Avatar
Ananth, I recall we had this discussion a long time ago. You mentioned that the block has bosses where holes could be drilled for N-S mounting. But..I am wondering about the oil pan. The engine is at a certain angle for E-W and N-S mounting and the oil pan may not have the same pickup characteristics. another thing to think about is the drive for the fan which you would have for E-W. Take for example the 3.8 in Minivan...had to be rengineeried quite a bit for the new Wrangler. Anyways..I'm getting off topic.
Old 27th July 2007, 07:15   #24
Thanked: 63 Times
You're right I do recall that we talked about that. But I found out subsequently that the holes are in fact there on both blocks, meaning that they are pre-drilled from the factory. So the blocks are the same, but you may be right about the oil pan.
ananthkamath is offline   Reply With Quote
Old 27th July 2007, 08:50   #25
Thanked: 4,736 Times
Some Premier Padmini cars were released with the NISSAN A12 engine and the NISSAN F4W56A transmission (the 118NE powerplant) by PAL in 1997. There are a couple of taxis running merrily in Mumbai. The main change is that the centre pillar of the steering rod has been moved back by 15 mm by redesigning the cross member and the firewall. This is necessary to prevent fouling of the pillar with the top of the NISSAN bell housing. In almost all the conversions done in the field, the garage adopts the easy way of cutting the top mounting lugs on the bell housing which afects the structural rigidity of the powerplant and must not be attempted.
I am trying to lay my hands on one of those taxies, convert the registration and then restore.
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks Reply With Quote
Old 27th July 2007, 09:05   #26
Thanked: 53 Times
Hey you can put in a contessa engine [quit cheap to get ] or an king engine but you'll have to modify the mounts for both. it's quit easy to do that.
dinar is offline   Reply With Quote
Old 27th July 2007, 11:07   #27
flipsyde's Avatar
Thanked: 62 Times
O.T - you guys keep bringing up the issue of having to go ahead with extensive work in order to install the esteem engine on a RWD car as it would require mating plates etc etc.
why not rob some part off the maruti versa??
it has a de-tuned G13B motor. its a RWD (if i'm not wrong. clearly remember seeing a rear differential housing). or am i missing something here?
flipsyde is offline   Reply With Quote
Old 27th July 2007, 11:38   #28
nitrous's Avatar
Thanked: 285 Times
Can u find one for us,dude??
These things are very rare to come by!
Old 27th July 2007, 20:08   #29
Thanked: 63 Times
versa's engine is also laid over on its side almost....its not vertical with respect to the gearbox. so thats out.
Old 27th July 2007, 20:11   #30
pawan's Avatar
how about a silvia engine or a vtec if vtec with what gear box can it be fit .with a gypsy gear box???.
ot can a versa gear box and drive train be connected to a esteem.
pawan is offline   Reply With Quote
Performance Mods for Premier Padmini using the stock engine D.V.R Modifications & Accessories 14 20th April 2010 17:38
Ambassador, Premier Padmini Specs ?? Technocrat The Indian Car Scene 69 22nd February 2010 16:38
What replacement engine for FIAT-1100D (premier padmini) hasopi Modifications & Accessories 26 11th December 2009 23:26
Premier Padmini 137D Gearbox Swap mituadas Modifications & Accessories 12 5th August 2009 20:48
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
