Old 16th October 2007, 11:13   #46
pawan's Avatar
how about the baleno engine with the gypsy or versa gear box should be a killer.
pawan is offline   Reply With Quote
Old 17th October 2007, 16:05   #47
eatdust's Avatar
Thanked: 19 Times
Originally Posted by v1p3r View Post
You could put in a V6. It's something I've thought long and hard about. A nice V6 with 150 hp and 20 kgm , in a RWD under 1 tonne. Should be a hoot.
which v6 engine would u suggest?
eatdust is offline   Reply With Quote
Old 18th October 2007, 14:51   #48
prabhuav's Avatar
Thanked: 112 Times
I am in the process of hotrodding my 87 padmini.
Putting in a Baleno engine + a Gypsyking gearbox into . Yes it will take considerable modifications to make this happen.
I tried the Conti engine + engine combo, but the gearbox bell housing is too large and dont want to endanger the structural integrity of the frontend. Additonally the added 100kgs of weight in the front will make it handle even worse..
Currently in the process of procuring the engine.. Will post more details after I do so..
Vijay
prabhuav is offline   Reply With Quote
Old 18th October 2007, 20:53   #49
headers's Avatar
Thanked: 454 Times
Any mods done with Pictures would be helpful..especially in the areas of engine mounting and gearbox used..etc..
An easy option as already suggested is the esteem engine..It transforms the character of the Fiat..Drive one to believe it..
Old 18th October 2007, 23:32   #50
Blue Thunder's Avatar
Thanked: 330 Times
The Jaya diesel used to be a good Diesel option for the Premier Padmini. You can check Relocate for further info.
Blue Thunder is offline   Reply With Quote
Old 21st October 2007, 11:27   #51
headers's Avatar
Thanked: 454 Times
Good Link BT..I didnt know that..
Their Jaya Diesel Engines in Coimbatore used to be a great fit onto ambys and give a good performance too.. Have driven some modded ambys that used to do 120 effortless..way back in the early 90s..
Will need to find out about the Fiat engine though!!. Good link ..thanks
Old 22nd October 2007, 12:38   #52
prabhuav's Avatar
Thanked: 112 Times
Default Diesel engine in a Fiat
Although a mordern diesel is the most practical in a Fiat, getting RTO permission in Bangalore is a pain...
Old 22nd October 2007, 13:05   #53
turbolader's Avatar
The S1 executive Padminis were pretty quick, smooth, 13 km/litre in normal driving conditions so the S1 engine is good for ur day to day use.
Hey wat bout the TATA indicas engine??? the Honda engine will fit physically, but again these are FWD engines so gettin ur drive to the RW's means a lot of differences n tat means a lot of work will be required.
turbolader is offline   Reply With Quote
Old 22nd October 2007, 13:35   #54
prabhuav's Avatar
Thanked: 112 Times
Default Honda and Tata Indica engine
The Indica engine is too crude for what I am looking for... Hoda has possibilities, but no matching rwd gearbox.. with the marutis, we have a gearbox that will fit..
Old 22nd October 2007, 16:53   #55
adheesh's Avatar
Thanked: 34 Times
I think you should first try tweaking the stock engine by head polishing, etc. If you still are unsatisfied with the performance, you could try engine swapping which is surely going to be a tediously process
You could also contact Mr. Behram Dhabhar (DHABHAR.BEHERAM) and 1100D for they have thier expertise with FIATS.
adheesh is offline   Reply With Quote
Old 20th February 2008, 18:20   #56
prabuddhadg's Avatar
Thanked: 45 Times
Just came across this thread. Any updates on the mods you guys were planning? The Premier Padmini is a nice car for any level of driving, and pretty easy to maintain. Every once in a while I think of getting one (my father drives one too). These threads stir that dream every time.
prabuddhadg is offline   Reply With Quote
Old 20th February 2008, 18:38   #57
jkdas's Avatar
Thanked: 1,389 Times
My 2 paisee...Keep the S1 engine as it is. Maybe some polishing and sorts.
Old 20th February 2008, 18:49   #58
planet_rocker's Avatar
Thanked: 365 Times
prabhuav's Restoration Project - http://www.team-bhp.com/forum/modifi...ni-1989-a.html (Resto-mordernizing my first love - my Dad's Premier Padmini 1989)
i frankly dont like the idea of engine swap in the Padmini - i am out of this thread.
planet_rocker is offline   Reply With Quote
Old 20th February 2008, 22:21   #59
youngbloodz's Avatar
guys i hv a 97 diesel fiat and has run over 3lakh kms and still running.but now its bit slow and lots of black smoke after changing the oil also and does a top speed of 95-97.can i do somthing to this engine to get it back to healthy condition.help me
youngbloodz is offline   Reply With Quote
Old 21st February 2008, 08:09   #60
Thanked: 23 Times
My cousin has put in a NISSAN 2.1 diesel engine into a padmini. I think its '87 model. Anyhow, the whole project set him back by 30k!
btw, after the engine swap, the car gives 16 - 17 kmpl in the city and 20 - 22 on the highway. We had this car at our place for a month and i loved the torque it produced. It never required to be put into 1st gear. But the car used to understeer in the turns if accelerated. The gear box was tough, but it never missed any gear. I forgot whether it had the stock gearbox or not. I will find more details and put it here.
kkr2k2 is offline   Reply With Quote
Performance Mods for Premier Padmini using the stock engine D.V.R Modifications & Accessories 14 20th April 2010 17:38
Ambassador, Premier Padmini Specs ?? Technocrat The Indian Car Scene 69 22nd February 2010 16:38
What replacement engine for FIAT-1100D (premier padmini) hasopi Modifications & Accessories 26 11th December 2009 23:26
Premier Padmini 137D Gearbox Swap mituadas Modifications & Accessories 12 5th August 2009 20:48
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
