Old 21st February 2008, 09:43   #61
Awaiting Email Confirmation
Thanked: 19 Times
Originally Posted by kkr2k2 View Post
i loved the torque it produced. It never required to be put into 1st gear. But the car used to understeer in the turns if accelerated.
dont you mean oversteer? RWDs with lots of torque oversteer in corners if one stomps the pedal. did happen quite a few times in our 138D.
Old 21st February 2008, 10:57   #62
planet_rocker's Avatar
Thanked: 366 Times
you mean the 137D right?
The gear box was tough, but it never missed any gear. I forgot whether it had the stock gearbox or not. I will find more details and put it here.
it has synchromesh on all 4 gears IIRC. thats why changing gears was easier.
Originally Posted by youngbloodz View Post
guys i hv a 97 diesel fiat and has run over 3lakh kms and still running.but now its bit slow and lots of black smoke after changing the oil also and does a top speed of 95-97.can i do somthing to this engine to get it back to healthy condition.help me
i am not much into tuning but i think the car needs to be tuned properly - i think its running rich - also check if the engine oil / radiator water has any "soapy" thingy - if yes - then i guess the head gasket needs to be changed - also get the brakes checked - see if any one of the brakes are fouling with the drums - you dont wanna put load on the engine.
i think it will be better if Mr. Dhabhar pin-points the problem.
planet_rocker is offline   Reply With Quote
Old 21st February 2008, 12:05   #63
jkdas's Avatar
Thanked: 1,389 Times
138D is our 118NE with the diesel engine.
Old 21st February 2008, 12:07   #64
Thanked: 19 Times
sorry it was the 137 D
Old 21st February 2008, 13:13   #65
Thanked: 366 Times
thanks Jyothi - got that twenty twenty
Old 21st February 2008, 13:20   #66
youngbloodz's Avatar
my mechanic told that the pistons rings are gone and has to be replaced.and where can get new pistons for my car if i want to redo the engine.
youngbloodz is offline   Reply With Quote
Old 24th February 2008, 23:42   #67
silverado's Avatar
Thanked: 636 Times
i believe the BEST fit for padmini would be an esteem engine, parts are available in plenty and its easy to repair ( the carb one of course ).
silverado is offline   Reply With Quote
Old 4th April 2008, 14:38   #68
tez
tez's Avatar
Thanked: 16 Times
guys, the post looked interesting and i wanted to know, it is possible to swap the padmini engine with a diesel one. Which ones would be possible?
tez is offline   Reply With Quote
Old 4th April 2008, 17:23   #69
JayD's Avatar
Thanked: 1,996 Times
If u MUST do it, then look for the 137D engine. I used to hear a lot about jaya diesel engines in padminis in the 90s. What happened to them??
Old 4th April 2008, 17:27   #70
jkdas's Avatar
I think there are lot of Toyota diesels engine that can be plonked into the Padmini.
Old 4th April 2008, 17:44   #71
JayD's Avatar
The one used in the starlet i think??
Also, some time back, there was one here with a daihatsu engine in it.
Old 4th April 2008, 21:59   #72
Thanked: 147 Times
Put a gypsy engine in the fiat with a gypsy gearbox. Convert it to Floor Shift. If you have an S1 even better. Less cutting to do.
Cyrus43 is offline   Reply With Quote
Old 16th June 2009, 13:00   #73
eatdust's Avatar
Thanked: 19 Times
http://www.team-bhp.com/forum/vintag...tml#post887654
isn't datsun1200 aka nissan sunny. wasn,t its engine used in premier 118ne? doesnt it hav the same gear box too, except this one has 5ht gear.
eatdust is offline   Reply With Quote
Old 17th June 2009, 15:30   #74
eatdust's Avatar
Thanked: 19 Times
http://www.team-bhp.com/forum/modifi...tml#post916562 (The old FIAT 1100 body with a Palio 1.6 engine)
could you get me more info on that. what all to be done? my friend is goin to swap his gypsy's engine with baleno engine.
Old 19th February 2013, 17:08   #75
eatdust's Avatar
Thanked: 19 Times
How about Diesel engines from
1) ICML Rhino 2.0
2) Premier Rio 1.5/1.3
3) Maruti Ertiga 1.3
4) Mahindra Quanto 1.5.
Suggestions please?
Any other modern Diesel engines??
Performance Mods for Premier Padmini using the stock engine D.V.R Modifications & Accessories 14 20th April 2010 17:38
Ambassador, Premier Padmini Specs ?? Technocrat The Indian Car Scene 69 22nd February 2010 16:38
What replacement engine for FIAT-1100D (premier padmini) hasopi Modifications & Accessories 26 11th December 2009 23:26
Premier Padmini 137D Gearbox Swap mituadas Modifications & Accessories 12 5th August 2009 20:48
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
