| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jul 2007 Location: trivandrum
| Instead of buying a new car I would like to get padmini body+chassis and put a new engine(available in indian market) in it. this car is for daily use on urban roads. so what engine will fit into its bay? have 2 engines on my list 1. honda city 2. santro xing is there a better engine that will be a direct fit? |
| | #2 (permalink) |
| BHPian | Your Padmini is rear-wheel drive, while the City & Santro are front-wheel drive. You would need to modify a lot of metal to effect the change, something on the lines of 'Bangla Bangers' on the Travel & Living channel ! You're better off getting a new car... |
| | #4 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Conti engine would be the best fit or you can try gypsy king
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #6 (permalink) |
| BHPian | why do you want to do this? i am not sure that will be reliable. you can very well go ahead and buy a used santro / city without much hassles. if you have already decided on this - 1. try out the 1.8ISZ engine, Conti differential & GB 2. Padmini Engine, S1 manifold, S1 Tailpipe & Glasspack, S1/118NE GB, S1/118NE differential. IMO - it will be better off to properly tune a Premier Padmini and running it. less hassels and reliable. Last edited by planet_rocker : 26th July 2007 at 14:56. |
| | #7 (permalink) |
| Senior - BHPian | esteem would be better than conti as contis would be heavy. Gonna be a bit expensive job and I doubt if any would do it right at Tvm. Modding the original engine would be a better choice. Santro/City engines would be costly and feasibility can be a problem. Conti engine should be easy to source ( even the Amby 1800Isz engine is the same ) and cheaper for mods. If you are successful then you can be the drift king ![]()
__________________ "She may not look like much, but she's got it where it counts, kid." Last edited by jkdas : 26th July 2007 at 14:52. |
| | #8 (permalink) | |
| Senior - BHPian | Quote:
The padmini will do good with the conti engine and the 1.8s inherent torque.
__________________ hindu.com/mp/2008/08/25/stories/2008082522220200.htm | |
| | #10 (permalink) |
| BHPian | anyways - meshing the engine and GB for a FWD and RWD - from what i hear is a night mare - do try and get your hands on a nice old conti engine - and do the works on it - like port, polish etc etc- and then throw that into the fiat. then u will have yourself one MEAN machine! ![]()
__________________ Taken the plunge! www. virtu. in __________________ 2002 Lancer | 2006 Palio | 2008 Trek 4300D |
| | #11 (permalink) |
| Super-Admin | Consider only stock RWD engines: 1. Conti 1.8 2. 118 nissan engine 3. A Padmini engine! Trust me, you can mod it to a level where is is enjoyably fast. Remember the S1?
__________________ GTO Change the way you think, and watch the world change around you.
| | #13 (permalink) |
| Team-BHP Moderator ![]() | If you really want to swap, I suggest you go for a 118NE engine and gearbox. The Conti ISZ engine is to powerful for it. The chassis, suspension, brakes and cooling system will need extensive work. If you're prepared to spend on that, you'll have a monster.
__________________ MH 01 T 1476 - Here we go again!!! |
| | #15 (permalink) |
| BHPian | no engine is a direct fit for the fiat except its own. and maybe the 118 is the simplest next choice but it wont be very fast. In fact the 1100 engine is more tuneable and faster than the 118. an 1100 engine with higher compression, twin solex carbs, full exhaust, Piper F3G cam mated to a 118 gearbox can be a pretty fast car even by modern small car standards (Im talking zen, santro and carb esteem here).
__________________ Miata Turbo Is GO!! |
« electronically adjustable ORVM : Alto
New Footwear & other Updates done on my car. EDIT- 5th Set of New Tyres Fitted! »
| Thread Tools | |
Similar Threads | ||||
| Performance Mods for Premier Padmini using the stock engine | D.V.R | Modifications & Accessories | 12 | 18th August 2008 13:18 |
| Used Maruti800, premier padmini , premier 118ne ? | sakharamcool | Hatchbacks | 8 | 27th May 2008 11:17 |
| Need a Premier Padmini S1 | kavesh55 | Shifting gears | 0 | 27th December 2007 13:48 |
| What replacement engine for FIAT-1100D (premier padmini) | hasopi | Modifications & Accessories | 15 | 23rd August 2005 23:17 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
