Old 9th August 2007, 17:45   #1
adman77's Avatar
Default High lift cam after porting
Hey guys,
Need some opinions from you guys. Sometime back, I wanted to get porting and polishing done for my Corsa. My tuner refused to do it and advised me not to get it done cause it would bring down the compression . That sounded quite crazy. But anyways, I went ahead and got it done through another friend of mine who's also a tuner. Ported and polished the head, valve grinding job, inlet porting and polishing etc. After all this, we checked the compression. It was running at around 205 (previously around 160-165). Now I'm getting a 280* high-lift cam. But once again, my previous tuner ( cause only he has cams for the Corsa) says there's no point in putting the cam cause it won't perform because I've done porting and polishing job. And he tells me I made a mistake by doing it against his advise. Personally, I feel the car performs much better after the porting job and I love it. even my friend 9whod did my porting job) feels there's no reason it shouldn't perform.
What do you guys think?
adman77 is offline   Reply With Quote
Old 9th August 2007, 18:17   #2
ported_head's Avatar
How about putting names to those tuners?
ported_head is offline   Reply With Quote
Old 9th August 2007, 18:58   #3
adman77's Avatar
Wouldn't be fair to both of them.
Old 9th August 2007, 19:01   #4
viper's Avatar
Thanked: 9 Times
I see no reason why your car would not perform. BTW who was your past tuner and who is your present one. I am intrigued by your remark ( cause only he has cams for the Corsa).
Anyways just make sure you have a adjustable cam wheel made so that you can set the Cam timing perfectly.
Viper
viper is offline   Reply With Quote
Old 9th August 2007, 23:31   #5
Ford Rocam's Avatar
Thanked: 16 Times
I really dont know where this kind of tuners gets their theories from? i dont feel like using the "frustration" smiley for this one!!!
Ford Rocam is offline   Reply With Quote
Old 10th August 2007, 04:01   #6
hey adman everything you've mentioned above sounds very interesting,please do mention the names of the tuner's im sure everyone will take it in the right spirit,also what is the current status have you installed the cam or not?
dragger is offline   Reply With Quote
Old 10th August 2007, 04:43   #7
v1p3r's Avatar
Thanked: 27 Times
Give us the names. We need a laugh.
Old 10th August 2007, 10:49   #8
adman77's Avatar
Can't give no names guys. Both are good friends. The first guy is still a good friend (although won't be taking my car to him for any further jobs). If anyone wants to know the name, ask Viper, he knows.
Cam is coming down this month end. It'll go in with the standalone ecu.
Porting and Polishing!!! Edmund Technical Stuff 61 22nd November 2012 20:56
High-Lift Jack Instruction Manual Shared (How to use one!) Sudarshan 4x4 Technical 14 18th May 2012 06:02
Enfield Bullet:Cam gear backlash and solutions including adjustable cam spindles deepclutch Motorbikes 73 17th December 2008 00:47
Piper High Lift cam for sale! adman77 Shifting gears 0 3rd January 2008 14:15
karizma porting redrage Motorbikes 1 27th April 2005 01:31
