Old 11th August 2007, 23:57   #1
warchild's Avatar
Unhappy tachometer for palio EL
hey fellas
My 2002 palio EL_PS model does not have fatory fitted tachometer &
today i inquired @ the car accessories shop were i get most thing, they say for my model tacho's cant be fitted! is that true?
Has any one here got a tacho fitted on the same model as mine.
thanks
warchild is offline   Reply With Quote
Old 13th August 2007, 13:15   #2
warchild's Avatar
no responses yet, so it's true i cant fit in a tacho.
now have to dial Mr Psycho!
Old 13th August 2007, 13:58   #3
madan80's Avatar
Thanked: 73 Times
well - the tacho line is taken out from the ECU. Im in the process of getting it done for my palio - so will keep u posted on the same.
madan80 is offline   Reply With Quote
Old 13th September 2007, 08:31   #4
madan80's Avatar
Thanked: 73 Times
Update- I got the tacho attached. they took the lead from the Ecu, and ahve attached it on the dash. post pictures of it later.
but- this is just to prove that it can be doine. Also, if you approach fiat and ask them to "redo the wiring" they will do it and give you a lead for the tacho. but the manager told me it costs about 10K for wiring, and 30K for the Elx dashboard. so decided against it.
Old 13th September 2007, 10:02   #5
nitrous's Avatar
Thanked: 282 Times
All credit to Electra Automotive for patiently isolating the rpm signal.
Is a tachometer required on a CAR ? skamb Technical Stuff 72 6th December 2014 21:57
tachometer ... problems cooldude585 Modifications & Accessories 9 9th January 2009 15:23
tachometer-help!! hot_rod Modifications & Accessories 42 23rd September 2008 10:09
purpose of tachometer jagjeet Technical Stuff 3 27th June 2008 16:12
Tachometer Pricing dragger Modifications & Accessories 10 11th February 2005 17:47
