Old 4th September 2007, 00:37   #16
paras211's Avatar
Thanked: 57 Times
how much gain is expexted of the cam with stock compression?
paras211 is offline   Reply With Quote
Old 4th September 2007, 11:45   #17
adman77's Avatar
Cam installed
adman77 is offline   Reply With Quote
Old 4th September 2007, 12:12   #18
shazikon's Avatar
Thanked: 19 Times
Are you using a programmable ignition? and ECU mods?
shazikon is offline   Reply With Quote
Old 4th September 2007, 12:17   #19
adman77's Avatar
Some issues with the cam. Idling is a little weird as expected, but that's okay. Problem is, sometimes during pick up, the engine seems to be missing. As in, fuel supply during initial doesn't seem to be sufficient. Once the RPM crosses 2000, it flies, but before that, it seems to be lacking fuel pressure. Have increased the pressure on FPR but the problem remains. Spoke to my tuner and some tuners from Bangy too. Common consensus is that the ECU is not supplying enough fuel during the initial. It's not able to compensate. Advice I got was to either remap or wait for the standalone ECU. What do you guys think.
PS: Mclaren1885, Psycho, RDkarthik, please throw some light.
Old 4th September 2007, 12:40   #20
shazikon's Avatar
Thanked: 19 Times
Just the doubts i had, I feel the ignition timing is not set correct. your ignintion bust be retarded at lower RPMS and advanced at higher RPMs. Is your ignition handling that?
Old 4th September 2007, 12:56   #21
adman77's Avatar
Ignition timing is proper. No issues with that. No problems with idling whatsoever.
Ideal footwear for driving... balashome The Indian Car Scene 95 19th November 2013 16:45
Which ideal place from Mumbai within 500kms in March - May season? rudrah Route / Travel Queries 10 25th September 2009 18:44
Which tyre ideal for a trip to Ladakh? (for a Logan) ashutoshb Tyre & Alloy wheel Section 7 24th May 2009 13:57
Enfield Bullet:Cam gear backlash and solutions including adjustable cam spindles deepclutch Motorbikes 73 17th December 2008 00:47
What would be your ideal car?? v12 The Indian Car Scene 41 1st March 2005 21:17
