Old 14th August 2007, 15:54   #1
adman77's Avatar
Default which is the ideal cam?
W\Wanted to know which is the ideal cam for a Corsa 1.4. BP275 or BP285? Some people suggest the first one while others suggest the latter. Please advice.
PS: Viper, MClaren, psycho, can you please contribute with your opinions?
adman77 is offline   Reply With Quote
Old 14th August 2007, 15:57   #2
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Higher the degree, higher are the chances that you will have a rough idle. My idling fluctuates between 750-1500 depending on my cars mood and I am running a 270 deg Crower.
If you are ready to put up with this, get an adjustable cam gear and go for the 285. Btw, how much is the price difference between the two cams? Is it a weld & reground? Or a brand new billet?
Old 14th August 2007, 16:01   #3
adman77's Avatar
From whatever I've heard right now, it's supposed to be a brand new billet. Spoke to guys from Piper UK. The Vauxhall Corsa B in UK and our Indian Corsa 1.4 share the same platform. Price for 285 is somewhere in the range of 18 to 20k. Don't mind the rough idling at all.
Old 14th August 2007, 19:21   #4
viper's Avatar
Thanked: 9 Times
I would suggest you go in for a BP 285 and make sure you have a adjustable Cam wheel.
Viper
viper is offline   Reply With Quote
Old 14th August 2007, 19:22   #5
Thanked: 35 Times
Then go for the 285 if you don't mind the idling. Also while you are at it could you figure out the prices for a 290 degree cam for the Baleno? A friend needs one.
Old 14th August 2007, 19:27   #6
adman77's Avatar
Not a proble Rahul, I'll find it out for you.
Old 16th August 2007, 16:39   #7
adman77's Avatar
Do I need to upgrade to bigger injectors if I'm going for a 285?
Old 16th August 2007, 16:53   #8
Thanked: 35 Times
I don't think that would be necessary. Rather if you want to supply additional fuel get yourself a FPR. Should suffice.
Old 16th August 2007, 16:58   #9
adman77's Avatar
I Already have an FPR
Old 16th August 2007, 20:31   #10
Ford Rocam's Avatar
Thanked: 16 Times
Also get a good Head job with 3 angle valve job done, raised compression with aftermarket pistons (expensive option) or shaved cyl head if you haven't got that done.
Also some turners tend to shave part of valve neck to increase the airflow during head porting/polishing, i highly recommend not to do that,instead get after market valves (flat top) nitride coated this will also contribute to raise compression a bit.
Hows the intake manifold design in a corsa? that will play a vital role in the air flow?
Ford Rocam is offline   Reply With Quote
Old 16th August 2007, 21:50   #11
adman77's Avatar
Done that already
Getting that done too
The intake manifold in the corsa is least restrictive. Where do you live by the way? If possible, can meet up and you can have a look.
PS: lemme have a look at the B16A too. Yummy yummy.
Old 17th August 2007, 23:32   #12
adman77's Avatar
Guys,
Just got my compression checked. It's running at 200. Good enough?
Old 30th August 2007, 15:41   #13
adman77's Avatar
Guys, the cam's finally here. Got a 270* fast road. Some pics for you guys.
Old 3rd September 2007, 22:38   #14
can anyone suggest a good cam upgrade for the new honda city... the 1.5 exi..??
amahesh is offline   Reply With Quote
Old 4th September 2007, 00:27   #15
BUSA's Avatar
its better not to mess up with the NHC, its not a car to be modded and parts are not available with ease.
Ideal footwear for driving... balashome The Indian Car Scene 95 19th November 2013 16:45
Which ideal place from Mumbai within 500kms in March - May season? rudrah Route / Travel Queries 10 25th September 2009 18:44
Which tyre ideal for a trip to Ladakh? (for a Logan) ashutoshb Tyre & Alloy wheel Section 7 24th May 2009 13:57
Enfield Bullet:Cam gear backlash and solutions including adjustable cam spindles deepclutch Motorbikes 73 17th December 2008 00:47
What would be your ideal car?? v12 The Indian Car Scene 41 1st March 2005 21:17
