Old 31st August 2007, 17:04   #91
flipsyde's Avatar
Thanked: 62 Times
Originally Posted by 16v100bhp View Post
Well my car is running on 15" 205/50 profile tyres and its got all the prelim mods that you have mentioned above and its showing 140@6000 rpm in 4th.
But still a slight slope and may be if he is running on a 16"/17" wheels with higher profile tyres will make a difference, but not quite convincing enough for me to close the case
damn! i totally forgot you car wasnt completely stock!!!!!!!! anyway point made.....
flipsyde is offline   Reply With Quote
Old 31st August 2007, 18:07   #92
madan80's Avatar
Thanked: 73 Times
Originally Posted by moralfibre View Post
Yes I saw it last night. It was in my dream and was running a Quad-cam and quad-turbo setup running at 310kmph when my clients Maserati overtook me on the Mum-Pune expressway and I called him up (at the same speed mind you) and asked him his speedo read. He claimed 330kmph.
And time to add a smiley
i agree- thats either too much petrol mixed in the vodka or too much vodka mixed in the petrol!
madan80 is offline   Reply With Quote
Old 1st September 2007, 01:57   #93
16v100bhp's Avatar
The snap in your handle is finally making some sense..
16v100bhp is offline   Reply With Quote
Old 1st September 2007, 04:36   #94
A S H V I N's Avatar
people??? any news of our man with the possessed palio 1.6 TC ???
A S H V I N is offline   Reply With Quote
Old 10th September 2007, 19:05   #95
Default some info!
most of the cars have speedo sensors on differential /gear box.
and the reading is caliberated to the stock tyres with stock gears .
so even if u put the tyre which has 10 inch more circumference. the speedometer will not show the difference< or the actual> .it will show the distance/speed which would have been traveled if the stock tyres with stock gear ratios would have attended. so
changing tyres with bigger circumference will definately run faster than the stock one with the same ratio but the speedo wont show it !!!
TURBOSAM is offline   Reply With Quote
Old 10th September 2007, 22:38   #96
hellspawn's Avatar
Infractions: 0/1 (10)
Originally Posted by TURBOSAM View Post
s10 and gtx both have same ecu programming same ecu, same top gear ratio ,same diff ratio and should atteain same top speeds in same driving conditions. s10 has better wing-reduces drag from top as well as top halfs of lhs as well as rhs . where as gtx has the one with only the top drag cutter! so minor handling /stability benifits will be aparent in s 10 at 100+kmph and possibily 2 or 6 kmph more at the top end in stationary air!
all the 1596 cc engines hit @7200 rpm though i never tried that in 5th gear.
but the last time i heard,the s10 had overdrive on 5th gear whereas in the gtx,the 4th and the 5th gear,both are overdrives.i'm not really sure.
hellspawn is offline   Reply With Quote
Old 11th September 2007, 07:25   #97
16v100bhp's Avatar
Even i had heard the same and there was a link actually pointing out more things different in the S10 gearbox.
Old 11th September 2007, 07:34   #98
16v100bhp's Avatar
Check this out..
Even better, a 220kmph run
Old 11th September 2007, 08:27   #99
clevermax's Avatar
Thanked: 445 Times
May be its just a speedo mod he he... I personally know one guy who knows in and out of speedos of any car.... Make the speedo start from 100, and 220 is easily achievable :-)
I seriously doubt whether that's a 1.6 engine!
clevermax is offline   Reply With Quote
Old 11th September 2007, 12:04   #100
Default hi!
it seems to be an authentic speedo+authentic rpm meter but the gear ratio seem to be different as all 1.1,1.2,1.6,1.9 palios attain 117 kmph at 3000 rpm in top gear. ... plus the car seems to be a lhd one , + ,the firing note sounds different too + the camming is way different ... it seems to be a different engine .. a brazilian one .
and yes there are many things which i dont know .....
Old 11th September 2007, 13:16   #101
Default yes !!
best of my knoledge its not an indian palio 1.6 .
its a brazilian palio and in brazil there are hunderds of palios who can touch 22kmph ..
if u care to search the u tube @ palio ull be surprised with the outputs the people are getting out of the 1.6 16 v engines !
Old 11th September 2007, 14:17   #102
shazikon's Avatar
Thanked: 19 Times
Default Its not a RHD car
It sure is a LHD vehicle.. look at the position of the wiper in this pic. the wiper arm seems to be originating from the left..the rivit on the wiper blade is a giveaway. Now if it was a RHD vehicle, the wiper cannot come down somuch to the right while in use. It has to be a LHD vehicle i am also not sure if its a Palio.
shazikon is offline   Reply With Quote
Old 11th September 2007, 18:47   #103
extreme_torque's Avatar
Thanked: 1,489 Times
Ditto... In S10 only the 5th is an overdrive unlike the regular GTX where 4th and 5th both are overdrive ratio's.
extreme_torque is offline   Reply With Quote
Old 11th September 2007, 18:50   #104
binz's Avatar
Thanked: 412 Times
Since mclarens is taking time getting the info,i will check tomorrow and let you know.Pukka
Old 12th October 2007, 20:58   #105
JayD's Avatar
Thanked: 2,008 Times
err... any updates binz?
Turbo charged INDIA Vulken Auto Modifications & Accessories 24 19th May 2006 11:00
Of Turbo-charged Lancers and Honda City Vtecs... GTO The Indian Car Scene 32 17th May 2006 14:35
Turbo charged Mondeo with a awesome audio system FORDLOVER In-Car Entertainment 23 3rd October 2005 10:52
Turbo Charged City!! iomega Modifications & Accessories 13 17th March 2005 16:37
